Question about Vizio SV470XVT 47 in. LCD TV
Remove base to install wall mount brackets on vizio sv47oxvt1a
3 Suggested Answers
SOURCE: I just buy a vizio
I've got the same problem. There are three screws in the neck and I don't want to remove them if that's not how to remove the neck. The manual says to remove the base and neck but only describes removing the base. Leaving the neck would be unsightly, to say the least.
Posted on Dec 23, 2010
SOURCE: I have a 42 in. Vizio Galleria and need to remove
1. Unplug all of the cables and cords from your GV42L FHDTV10A.
2. Place the GV42L FHDTV10A face down on a soft and flat surface (blanket, foam, cloth, etc) to prevent any damage to the TV.
3. Pull the stand cover off by squeezing the sides to release the retaining plastic tabs.
(This is probably the trickiest part to find this, just feel around and don't be too rough with the plastic)
4. Remove the four (4) screws (screw's specs: M4, 0.7 Pitch, 15mm long) so that the stand base can be removed.
5. Gently remove the stand base
6. Now, the GV42L FHDTV10A can fit securely to a mount (sold separately) by utilizing the mounting holes in the center of the back panel of the TV. Please make sure to read the instructions of your specific mount to properly hang the GV42L FHDTV10A
Posted on Mar 13, 2011
Is there a special bracket to mount the 50 inch D series vizio to the wall?
Many aftermarket mounting brackets are virtually universal in application provided your 50-inch Vizio TV can meet the size and weight limitations stated.
Nov 29, 2014 | Vizio VP504F 50-inch 1080P Plasma TV...
How to remove mounting bracket from base
It just snaps on. Here's the manual for that phone, the mounting bracket is shown on page 42
http://service.us.panasonic.com/OPERMANPDF/KXTG6431-MUL.PDF
Jul 31, 2014 | Panasonic KX-TG6431M Dect 6.0 Dark Grey...
How to install the base
This direct link will take you to the manual for your TV:
http://www.manualowl.com/m/Vizio/P50HDTV10A/Manual/230976
You will need Adobe Reader installed on your computer to view it, since this is a .PDF file.
Page 6 illustrates the removal of the base for wall mounting; of course you need to reverse the process for the base mount.
Feb 16, 2012 | Vizio P50HDTV10A 50 in. Plasma HDTV
There are no holes in the back of my 22 inch VIZIO TV, so how do I attach a wall mount to it?
Without any holes on the rear of the set it either has some sort of base mount or a specialized hanging mount. Best advise is contact Vizio and ask their customer service (877-698-4946). They would also be able to sell whatever you need to complete the installation.
Sep 17, 2011 | Televison & Video
How do you get the mounting bracket apart from actual holder piece? My holder pulled out from the wall
The technical specifications and installation instruction for your product are available here.
http://www.moen.ca/shared/pdf/yb2208sp.pdf
At the base of each post; likey facing down to the floor there should be a small square hole. You will need to insert a small flat screwdriver to release the locking tabs to allow the mount to come free from the mounting post.
You will then likely need to remove the mounting posts from the wall; install new wall anchors (suggest you use toggle mounts designed for sheetrock) and then reattach the mounting posts and then the mounts with the paper holder in place.
Nov 15, 2010 | Moen YB2208CH Brantford Toilet Paper...
Remove base to wall mount
Place the TV face down on cushioning. There are four short hex head screws that hold the TV to the stand. There are two on each side of the mounting point (close to the bottom of the TV). (Turn counter-clockwise to loosen.) Next slide the base down from the bottom of the TV. The appropriate sized hex key was supplied with the TV (and the base was installed). If you want to, you can unscrew the support post from the base - it has 4 long hex head screws. This will let you put the base parts into an appropriate container for storage.
For a clear picture, see the manual for installing the base and work the steps in reverse. See here for a copy of the manual: http://www.managemylife.com/mmh/owner_manuals/search?query=LC46SB54U+ .
To put on the wall mount, you will need to remove the covers from the 4 mounting locations on the back of the TV and use the screws from the wall mount bracket kit.
I hope this helps.
Sep 16, 2010 | Sharp LC46SB54U 46 in. LCD TV
We would like to mount our L37 HDTV 10A on the wall.
a wall bracket plate must be installed.
check with your local radio shach.
Jan 11, 2009 | Vizio L37 Television
I want to take off the base of my flat screen tv.
lay tv down on a flat soft surface remove 4 philips screws on back on either side of signal brd inputs base will pull out of bottom
Oct 15, 2008 | Westinghouse LTV-40w1 HDC 40.02 in. LCD...
Remove base from TV
Remove 4 screws holding the vertical metal bracket in place. These are located just above the bottom of the rear centre of the TV. The bracket will then slide out.
You might find it easier to remove the footplate first. Simply remove all screws from the bottom of the base. The metal plate and the plastic shield will then detach.
May 27, 2008 | Televison & Video
Swivel Base for a 42LC2D
Hi there is normally a set of 4 to 6 screws that hold the base to the tv set that you remove , you can then possibly use the same screws to attach the wall bracket to the back of the tv before mounting on the wall
hope this helps
cheers John
Dec 25, 2007 | LG 42LC2D 42 in. LCD HDTV
Vizio SV470XVT 47 in. LCD TV Logo
65 people viewed this question
Top Vizio Televison & Video Experts
pzarnold
Level 1 Expert
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
