Question about Eastern Tools & Equipment ETQ IN1800I 1,800 Watt 3.4 HP 4-Stroke OHV Portable Digital Inverter
My etq in1800i generator will run for 2 minutes then quit . it will start right back up run for 2 min and quit
ETQ generator DG4LE cut off value under tank broke and no fuel comes thru
syphon the gas out,tip it up so whats left will not come out of the hole for the shut off,unbolt the shut off and it should be part number,ETQ 17150,,,or whats on the pic
http://theportablegenerators.org/manuals/ETQ/Diesel-ETQ-Gen-178F.pdf
http://theportablegenerators.org/manuals/ETQ/Diesel-engine-DG4LE-DG6LE-manual.pdf
May 12, 2015 | Eastern Tools & Equipment ETQ DG4LE 4,900...
I have an ETQ 4000. New carb, new plug. Will only start with starter fluid then die.
You know you have ignition. It isn't getting correct fuel. CHeck fuel to carb. If confirmed fuel to carb, carb is not adjusted properly.
Jan 08, 2015 | ETQ 4000 Watt Generator
I have a etq 1200 generator that runs but doesnt have ac. what could be the problem?
Check that the GFI receptical is not tripped
Check that there are no blown fuses or tripped breakers
Verify that the engine is running at full RPM
If there is still no output, then either the field needs to be flashed (look on line to find a video on how to do this - YouTube), or the generator will need further diagnostics.
Sep 04, 2014 | Eastern Tools & Equipment ETQ Tg1200 1200...
Can,t get carb off to clean ETQIN1800i
There are two plastic nipples that are pressed into rubber grommets, just grab the bottom and pull straight out while wiggling the air box assembly. Make sure you pull the rubber fuel lines out of the way so that the air box cam come straight out. The resistance you are feeling is either the rubber grommets or the fuel lines in the way. I have had mine apart a dozen times!
Dec 28, 2013 | Eastern Tools & Equipment ETQ IN1800I...
Owners manual
no, you just have to dig into it further to find your issue. sorry but these generators I don't see very often. Like I've worked on 5 in the last 6 years yet they aren't all the same
Etq in1800i will not start
Did you just clean the Bowl in the Carburetor or did you make sure the tiny holes in the Jet was clean too? Not familiar with this model but I doubt it is anything more than Gravity fed.
Dec 01, 2013 | Eastern Tools & Equipment ETQ IN1800I...
Need Owners Manual for an ETQ 1800 w inverter/Generator
Northern tools has it here, even though it's a discontinued product:
http://www.northerntool.com/images/downloads/manuals/166520.pdf
Apr 11, 2013 | ETQ IN1800i Generator Digital Inverter...
Gas in crankcase while running
Probable cause would be a carburetor that is over-filling, Possibly from a sticking float, or an over-pressurized fuel tank.
Make sure that the vent on your fuel tank is working properly, and remove the bowl from the carburetor to make sure that the float moves up and down freely.
Mar 08, 2013 | ETQ IN1800i Generator Digital Inverter...
Starts runs for a minutes quits but if you keep pushing the start button it keeps running
Check rotor slip rings for cleanliness, brushes, stator resistance, rotor resistance. Then replace control board if they check out.
Feb 15, 2013 | Onan Cummins 4.0 KY-FA/26100 RV QG 4000...
GENERATOR WILL RUN ABOUT TEN MINS WITH LOAD THEN QUITS
You may have a 'TEST" mode on your Generator. Ten Minutes is usually the duration of the 'Exercise' function of most units, so I'd like to determine what mode you are starting your generator in. Please comment.
Mar 18, 2009 | Electronics - Others
Eastern Tools & Equipment ETQ IN1800I 1,800 Watt 3.4 HP 4-Stroke OHV Portable Digital Inverter Logo
182 people viewed this question
Top Eastern Tools & Equipment Electrical Supplies Experts
Bernie Knutson
Bernie Knutson
Level 1 Expert
jhnolson
wadingriver
wadingriver
Are you an Eastern Tools & Equipment Electrical Supply Expert? Answer questions, earn points and help others
