Question about Brother PE770 Computerized Sewing Machine
Brother pe770 F06
Our brother pe770 starts to beep and displays "F06 NP Sensor Break". The only way to continue is to turn off the machine and turn it back on. It happens many times whether you are sewing or not. We checked the needle and for jammed thread.
  • tgovin
    tgovin Nov 28, 2012
    If anyone one knows what the f06 means let me know. Also, how would you fix the problem?
3 Suggested Answers
  • 46 Answers
SOURCE: Error message on Brother SE-270D sewing machine
The safety device will activate if the machine has a bind or is unable to run at correct speed. If you turn the handwheel is it tight/hard to turn? if it is than thats it. Now what is binding the machine has to be diagnosed.
Posted on Jul 25, 2009
  • 96 Answers
SOURCE: stitching loose. won't thread the fabric
try to rethread the machine all the way back to the spool of thread and check the top and bottom tensions on scrap of same fabric
Posted on Dec 13, 2009
My CS 770 displays a flashing F4 Brother sewing machine
Perhaps this will help:
https://answers.yahoo.com/question/index?qid=20120713084921AAH7Vxl
Not much information on a Brother C4 error. You might try contacting Brother Support. Support Center
Jun 13, 2016 | Brother PE770 PE 770 Embroidery Machine w/...
Model PE770. Why does the needle keep getting stuck and the hand "crank" is really hard to turn?
could be a timing problem or a broken part, if the problem continues the machine needs to be checked
Feb 21, 2016 | Brother Sewing Machines
What does this error message mean?
Dear BreeAnn,
I would reboot the machine. That means. Turn it off pull the plug and restart or cold Boot Strap. Further open your manual and look for a factory reset. Remove the disc if it came with one and reinstall it.
Save all your creations to file if special programs are developed before the new startup. Manually assist the machine through a hand cycle. Moreover, check to see if all the e-stops are satisfied. That means switches stuck open or closed.
Blow out dust from working areas. It appears from a remote view. Having worked fine. It is a matter of oversight. I hope you get back into creating soon.
The rest of the links are search sites. If you become stumped.
Here is the most direct answer I can find for you. Become a member and place you direct information into the link after reading the reflection.
What is F06 Np Sensor Break on Baby Lock Sewing Machine Yahoo Answers
Here is an E HOW site others are drawn too for answers on that subject as well to expand an accomplishable solution.
Troubleshooting Brother Sewing Machine eHow
Here is another member offering contact sources and a direction on procedure on our network.
F06 np sensor break on brother se400
They are general links. I recommend tech support directly with a talk through. The information should reside in the manual. Fare. Well.
Jun 25, 2014 | Brother SE400 Computerized Embroidery and...
My brother PE770 will not turn on what can be wrong with it
Check that the cord is plugged all the way in at the machine. It's easy to have it look like it was plugged in but it's not really seated properly. Also if you have it plugged into a extension cord check that the strip is turned on or if it has a reset button push it and try again.
Feb 09, 2013 | Brother PE770 Computerized Sewing Machine
The safety device continues to activate on my Brother PE 770
it sounds like the machine needs to be serviced to see that wrong
with the machine
Jan 10, 2013 | Brother PE770 Computerized Sewing Machine
When using the cutting thread button on the brother pe770, it's pulling the shirt down and wont release
the machine may need to be checked to see if there is something
wrong with the connection between the button & the cutter
Sep 13, 2012 | Brother PE770 Computerized Sewing Machine
Brother pe-770 f05 speed sensor error - How to fix?
F05 error, speed sensor. I fixed successfully 2 of those. Speed sensor is located on a small board, under a protective plastic, located over the main front board. Remove front panel and bobin winder assembly. Remove the 2 screws of the small board. Remve CAREFULLY the small bord. Under, on the main shaft, are located the needle positionning sensors and the wheel of the speed sensor (left wheel on the shaft). The speed sensor is located on the board itself, it's very small. Clean carefully both the wheel and the sensor with Q-Tips and alchool, reassemble the whole thing and it should restart.
While U are there, take a thin nozzle oiler and lubrificate all the suppots of upper and lower shaft, all the needle bar mechanism and rotary hook central shaft and gears WITH VERY THICK oil. Needle bas assembly is the most critical point. I have 14 of those machines, almost all of those seized there before I learn how to lubrificate it. Also seized on the bottom shaft and on rotary hook pin
Jun 26, 2012 | Brother PE770 Computerized Sewing Machine
Brother SE-270D dispaly just F06 in LCD Panel
Contact Brother
http://www.brother-usa.com/homesewing/
To the left on the above site is a software download page.
If you need further help.. email brother...they will tell you how to fix this. Takes them a day or so to answer.
Sounds like the technician may have put in a wrong fuse himself. Hoping it was a Brother authorized dealer.
Jul 29, 2008 | Brother SE-270D Computerized Sewing...
Brother PE770 Computerized Sewing Machine Logo
100 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
