AKAI 37" LD with DVD I put in a DVD and changed input source to DVD and the TV went off. The power light is blinking red. TV is non responsive.
  • 8 more comments
  • sealeprice Jan 10, 2009
    All connections are good. THE TV WILL NOT POWER UP
    cAN'T CHANGE THE INPUT WITHOUT POWER AND IT WILL NOT POWER UP
    tHE ONLY THING CONNECTED TO THE tv IS A CABLE FROM THE DIRECT TV BOX THE dvd IS BUILT INTO THE TV. NOTHING CHANGES WHEN DISCONNECTING THE DIRECT TV. I GOT NO POWER
    DID IT NO CHANGE THE ONLY SIGN OF LIFE IS THE BLINKING RED LIGHT
    PLEASE UNDERSTAND "dvd IS BUILT INTO THE TV"
    IT WILL BE 11:15 CST BEFORE THE HOUR IS UP. WILL ADVISE THEN
    WHAT ARE YOU SMOKING?
    WHAT PART OF NO POWER DO YOU NOT UNDERSTAND?
    I AM WELL AWARE THAT THERE IS A PROBLEM. I AM LOOKING FO A SOLUTION
    i HAVE ALREADY TAKEN THE dvd DRIV OUT TO REMOVED THE DISK. I TRYED T POWER UP WITH THE DVD DISCONNECTED AND THE PROBLEM WAS STILL THERE
  • 70 Answers
Try to unplug the tv and wait two minutes then retry see if the dvd will eject
Posted on Jan 10, 2009
    Sergeant:
    Champion:
  • 435 Answers
Hi, what happens when the DVD is not inserted and you switch to DVD mode ?
Since, its built in, you can open the TV and try disconnecting the DVD player unit and see how the response is. This will let us know if the problem is with the DVD player unit.
    Sergeant:
  • 378 Answers
Remove that cd from the dvd drive.and play any other disc and check out.and again try to set the dvd input setting.try to press the device button twice in your remote.
    President:
  • 1,952 Answers
Unplug the unit for a couple of hours, that should reset the internal CPU. I would guess that there was a short duration spike that confused the system. A complete reset may take care of it.
  • 3 more comments
  • mohammed marika thambi
    mohammed marika thambi Jan 10, 2009
    I believe that the problem may reside inside the DVD at the receiver.
    If you can open up the unit, you should see where the remote receiver
    resides on the front panel board. It will either be a small metal can
    with an opening in the front or what appears to be a dark LED. Try
    resoldering teh connections for that receiver. There are times when
    the receiver connections have a high enough resistance to prevent clear
    reading of the infra-red flashes.
    You have failure of the main power supply. THis could be a simple
    component failure or something further down the line that is preventing
    the pwoer suply from working properly.
    Even when off, the SCART port should be allowing the signals to pass.
    the DVD when off originally, remains in the
    mode where it controls the output port. I'd be looking at the default
    DVD settings for the SCART ports. .
    All electronics are somewhat sensitive to power surges or dropouts. It
    is possible that you had a slight drop in power at your house that
    caused the internal 5V power line to drop to 4.2V or so. Once that
    level is reached, some CPUs have a tough time differentiating between 0
    and 1. Basically your set entered the state of confusion and the
    digital processing section was generating some bad analog info.
    Anytime this happens, a hard reset (unplugging long enough to drain
    the internal battery) will often cure the problem.
    http://www.dvdnews.nl/dvdfaq/dvdfaq.html
  • 916 Answers
This sounds like a bad tube inside the tv itself especially if the tv is making a clicking sound.
    Master:
  • 505 Answers
Turn tv off for 1 hour bye the power point press the on button to drain the rest of the power while the power point is turn off after 1hour turn back on that's should reset the tv and the functions plz let me know how this Geo's thanks
    Sergeant:
    Scholar:
  • 199 Answers
Just disconnect the dvd from the tv and try.and if ther tv work properly.again connect the dvd and check.if same problem presists it the problem in your dvd.do not connect it.get it repaired.
    President:
  • 2,110 Answers
Try this
unplug the tv and hold the power button down. then replug it
    Sergeant:
    Novelist:
  • 326 Answers
Remove all the connections and turn the tv off for a minute,then only on the tv without connecting any exterdevice to the tv like vcd,dvd.vcr,or any thing else.just only tv.
  • 124 Answers
You tv is telling you that it is either over heating or the input has a problem and shouldnt be used try normal television as see if tv will respond let it try to turn on for 3-6min some tvs take a long time to turn on if it is still unresponsive call the manufacturer
    President:
  • 1,990 Answers
Welcome to Fixya! Be sure and Check all of your Connections. This very well could be the Cause of a "Smart" Remote or a Loose Cable.
  • Travis Humphries
    Travis Humphries Jan 10, 2009
    After some more Research on this TV--The Flashing Power Light is a Trouble code that is telling you to have it Serviced
Will not power on, blinking red "power on" light
The power supply might have a shorted/defective diode(s), blown resistors, capacitors if the light is blinking on the front of the LCD.
I repair these power supplies, write to jah2mil@hotmail.com if you need further assistance.
Jun 24, 2009 | Akai LCT2701TD Television
I have a Akai DVDrw125. I've never been able to connect it between the cable signal in and the TV. It has S-Video in and S-Video out. The manual is worthless. I shouldn't have to switch the S-video cable...
The way I have it set up - cable box out to AKAI cable in, video and audio out of AKAI into TV via RCA. AKAI on channel 3, tv on RCA input. Change channels on Cable box, works fine. To watch a video, just put it in an hit play. Might have to change sources on AKAI if this is not working for u.
Mar 03, 2009 | Akai DVDRW120 DVD Recorder
TV ON STANDBY MODE
The blinking light on the front indicates a shorted part in the power supply. The power board will need to be replace or repair to restore the LCD functionality.
Let me know if you required further assistance.
Oct 06, 2008 | Akai LCT3701AD 37 in. LCD Television
Mintex 37 inch wide screen. remote is working however cannot change channel, input source or volum. only turns tv off. The buttone on tv doesnot work connot change input source or volume
Check if the remote is in TV position, that is, because most of the remote controllers have the feature that you can program them for use with another devices. Make shure that one button that says "TV" in pressed and released once before you try to change any function on the TV.
Jun 27, 2008 | Mintek DTV-373-D 37 in. LCD HDTV
Red blinking light on a Magnavox Plasma TV
Here is the solution. For less that 100$ your Magnavox Plasma TV. Model # 50MF2310/37 will be running like a champ.
Issue:
Magnavox Plasma TV. Model # 50MF2310/37 screen has no picture. There is no sound, TV comes on and then after a few seconds clicks and screen remains blank.
Cause:
On the main power circuit board to Capacitors are prone to failure from over load. The caps are 3300uf 10v 105+c capacitors located to the left of the AC power input.
Service:
Magnavox will refer you to a service center. They will advise $$$ for an inspection. They will also want to charge upwards of 500$ to replace the entire board.
Solution:
1. Unplug your TV
2. Disconnect all connections from your TV
3. With assistance lay your TV on its face on a non-scratching service
4. Remove the back panel screws.
5. Lift back panel off
6. The central board is your main power board.
7. Remove all wire harnesses from the main board.
8. Remove all screws that are holding the main board in place.
9. Lift the main board out and carefully place it into a non electromagnetic pouch.
10. Take the board to a Circuit Board repair shop.
11. Have them replace the the above mentioned Caps.
12. Re-install the board in your TV.
NOTE: Replace the caps with 3300uf 16v 105+ high temp caps(preferrably Japanese caps)
This fix cost me 80$ and my time to search for other who had the same issue. Try searching for Magnavox Plasma TV. Model # 50MF2310/37 bad circuit board or Magnavox Plasma TV bad capacitors or Magnavox Plasma TV bad ciruit board.
Hope this all help, Magnavox is should take ownership for this problem and recall any tv's that have these caps in them. The worst part about this is that teh **** from the repair center that was paid 100$ to check the TV, stripped out the screw holes and damaged the case for the TV.
Portland Laptop Repair was awesome. They repaired the board and it looked like new. Check them out at http://www.laptopportland.com/
Jeff G
Portland, OR
Feb 10, 2008 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Won't turn on
If you're using a DVD player or other component using the Component cable hookup, try unplugging that from the mix, unplug the power cord for the TV from the wall and wait 15 seconds and plug it back in, then power the TV back on. Mine used to do this and I gave up on the component cable option and went back to composite (RCA).
Feb 09, 2008 | Akai PT5598HD 55" Rear Projection...
Akai Plasma TV's screen suddenly went blank -model PDP4294
Same thing for me. TV just turned off one day and won't come back on. LED flashes red. Someone said it's because a cooling fan went out. If I can't find someone to fix it I'll take it apart and tinker myself. 32" with dvd built in was barely over a year old.
Nov 04, 2007 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Akai model pdp4249g
Hello drifter,The design of the tv enables the auto search to detect any input signal you have selected. It could be TV (off air, video signals etc) so just switch on whatever inputs to the akai plasma befote you switch the Akai plasma on and let it do the work for you. just relax and watch the tv. recap 1. switch on the input eg video deck, DVD, VCD, or satellite dish. 2. switch on your AKAI PLASMA and 3. wait for the akai to search for your input signals. TRy this simple procedure and if it doesnt work just post back the message. The DON
Jun 15, 2007 | Akai PDP-4249G 42 in. EDTV-Ready Plasma...
Televison & Video Logo
Top Televison & Video Experts
