Question about Mackie CFX12 Compact Mixer with Effects (12x4x1)
My Mackie cfx12 will only work when the effects are on. What might be the problem?
I took the back off and checked the fuses which are good. I didnt see anything obviously burnt, missing or broken. No funny smells. I am about to take all the nobs etc. off so I can take the top cover off. Could it be a bad ribbon cable? anybody heard of this problem before?
    Scholar:
    New Friend:
  • 125 Answers
Are you able to get a dry mix under these circumstances? If it is simply a dry version of the wet signal as you have turned the effects off yes it is possible a ribbon cable has come loose but it is more likely that an IC has died, this is not uncommon in these and they exhibit a range of symptoms including yours. If yea are happy to take apart and have a tame service centre this should save you quite a bit as the biggest cost is dismantling and rebuilding. As this is not unusual issue they should be able to fix quite easily
Posted on Feb 18, 2014
soundchasr
  • 8 Answers
SOURCE: Ch. 10 does not work - Mackie 1604-VLZ PRO
Yes, the ribbon cable is the 1st thing I would check. You can check the ribbon like this: Disconnect said cable from the channels. Connect cable connector from a known good channel to the problem channel. If channel sounds the same trace a signal through the channel op-amps.
Posted on May 29, 2009
  • 5603 Answers
SOURCE: Odd channels go out 1,3,5.....
Unless you are in super humid environment, this is more likely a crack in the circuit board OR a bad connector on a ribbon cable. Also BROKEN or cold solder joint for a connector pin through the circuit board.
Good way to cause this with ribbon cables is to NOT distribute the load when pulling them off. Often the wires near the edge are stretched and make poor contact with the little forks that pierce the insulation.
CRC226 is a good product to use for contacts. Available at Home Depot in the electrical department. Blue spray can. Use sparingly.
Posted on Oct 08, 2009
  • 5603 Answers
SOURCE: Connection of two sound boards
Refer to your EV user manual, page 23, part 2.
You run the outputs of the Mackie into the stereo "returns" on the EV.
Use TRS interconnect cables as these are balanced lines.
Posted on Jul 23, 2010
  • 5603 Answers
SOURCE: No sound
Your power amp should be connected to MAIN OUT left and right. NOT the MAIN "in".
The CD is connected correctely as you described. Make sure the CD has a line level output to match the input expected by the mixer.
Note:Walkman style CD players require a special cable to go between 1/8 inch stereo to dual RCA plugs.
You have to advance the MAIN fader.
You should be using TRS interconnect cables from the mixer to your amps OR using XLR cables.
Posted on Jul 24, 2010
  • 4234 Answers
SOURCE: Took apart and cleaned all my ribbon cable
A few questions first:
1) Does this effect the functioning of the "solo" at all? (ie is the light on always but without effect and can you select solo using the pushbutton?) We need to determine whether or not the problem is a funcitonal one or just the indicators being lit when they shouldn't be.
2) Are there any other symptoms at all? Any other lights effected at all or any functions not working as expected?
I will look up the prints for this, but I need to narrow down the search a bit. Gaining access to the board is not quick as all of the knobs need to be removed and all of the control nuts removed as well. If we can narrow this down a bit, you may be able to avoid that.
Please post up the info requested and I'll pull up the prints.
Thanks,
Dan
Posted on Nov 07, 2010
Why does my mackie cfx12 mkii have low output across all 8 xlr inputs at unity gain with distortion above that?
Where are you getting the low output? It would be very strange if all channels failed in the same way so it is probably something common to them all. Can you get the clip light to illuminate at all by turning the gain up on a mic channel and shouting into the mic? You are referring to the gain at the top of the strip not the slider aren't you? What happens if you assign a channel to the other sub channel, does the level come up through that? What happens if you take the output from the aux send and you send signal there, is it the same issue?
I may be completely wrong but I suspect if it is only mics that are causing a problem you may have the routing set up wrong or not set a level somewhere else right.
Aug 10, 2014 | Mackie CFX 12 mkII 12 Ch. Compact SR Mixer...
Repair mackie mixer
This board seems to have some bad electrolytic capacitors. The noise you hear is the lack of filtration that they provide. It should be gone through by a technican. If you want to look into this, I can help if you let me know, you may can spot these if you open it up. They look like little cans with an X on top. I'm sure it has many.
Nov 27, 2013 | Music
Mackie CFX12, right side output not working? Help!
Assuming if you pan hard left on an input it comes out the left and panning hard right goes nowhere and as you say the tape input feeds through to both sides OK there is a very limited number of places where the problem can be. If you are confident open it up and check all the connectors and cables. If anything has come loose this may find it, otherwise it's a trip to the repair shop. The largest cost will be the taking apart and putting back together as the repair itself should be a simple one and diagnostics easy.
Apr 11, 2013 | Mackie CFX 12 mkII 12 Ch. Compact SR Mixer...
I own a Mackie CFX20. It isn't the MKII. The effects are very weak, and they buzz a little when you try to use them. How can I fix them, and is a service manual available?
I would spend some time with contact cleaner, apply it to the switch contacts of any 1/4 inch jacks, and all of the connectors to the effects boards- it will entail some disassembly. Check all chassis ground connections you may have one that is a bit loose, broken, or corroded.
The Mackie support downloads for manuals has 2 sections- you needed to look at the top at the "discontinued products" Where these are.
http://www.mackie.com/support/downloads/discontinued.html
http://www.mackie.com/pdf/cfx_om.pdf
http://www.mackie.com/pdf/cfxseries_ss.pdf
http://www.mackie.com/pdf/cfxseries_hu.pdf
http://www.mackie.com/de/pdf/CFXSeries_OM_German.pdf
Feb 21, 2012 | Music
I have a mackie cfx12 mixer with mackie powered speakers.At a gig tonight i set up as usual and had strange highly amplified sounds coming thru speakers from microphone when reverb was on-the effects had...
Make sure you are using BALANCED interconnection cables to the speakers, either XLR or TRS connections. ALSO make sure all interconnected equipment such as the speakers AND the mixer are powered from the SAME receptacle at the venue... yes you have to run extension cords... the pro's do it so they don't have hum and other noise and don't damage their equipment.
Aug 14, 2011 | Innovative Concepts Corporation Odyssey...
I have a mackie cfx12 mixer. I just added an eq with sub woffer crossover via the main inserts using the proper insert cables. System works great, however when Using a CD player the subs will not work. any...
Sorry, I have looked at the schematics and the TAPE IN jacks are mixed into the MAIN outs AFTER the insert jacks, so your subs will NOT receive signal via the insert from the TAPE IN jacks.
You could make a small passive mixer merging the TAPE/CD before going to the crossover. This would require some non-standard cabling.... The other option is to run the CD into a regular stereo channel rather than the TAPE IN jacks... then the CD will go through the insert/crossover and to the subs as you desire. The last option is to use the crossover at the MAIN outputs instead of as an insert... which would be the CONVENTIONAL way... use BALANCED cables wherever possible.
Jul 22, 2011 | Mackie CFX 12 mkII 12 Ch. Compact SR Mixer...
Hi im sorry if this sounds a little dumb!!! last weekend while i was on a gig i tried to hook up my lap top to my mackie mixer (cfx12) but i wasnt able to get winamp to play through it, which channels...
With a stereo splitter cable that takes the stereo 1/8 plug of the computer into two RCA plugs you could go into the "Tape Input" of the mixer... OR take a 1/8 stereo splitter cable from the PC splitting to a pair of 1/4 inch plugs go into one of the 4 stereo input pairs on the mixer... like 7 and 8 or 9 and 10 for example.
Dec 22, 2010 | Mackie 1202vlz3 12 Channel Mixer
I have Mackie mixer cfx12 all the channels work except for channels 2 & 3, I turn the pre amp trim pot all the way up but no input is present, I also tried solo PFL for these two channels and no...
I suspect one of the upfront IC amps has been damaged. This can happen if people power the mixer from a receptacle that is different from where other connected equipment is powered such as amp. For example, mixer is at one end of the hall and other inouts such as an output of a guitar amp is plugged in. If a ground fault or spike occurs, teh ground bounce can exceed the common mode voltage of the input amps.
In your case, the inpout amps are discrete transistor types.
A voltage surge into the inputs of your unit would LIKELY pop two bypass caps that are 330pf. For channel 2 these are C205 and C206. Check those for shorts.
VERIFY audio is available at the "send" (tip) of the channel insert connector... this verifies the preamp stage. You can PROBABLY plug a set of headphones in to check this... ONLY one side will have sound of course. Verify this is a good test by checking a working channel. The level will be quite low and we are looking for just some signal.
IF you do have signal on the channel insert send which is the "tip" of the channel insert with the trim turned up, let me know and I will check the schematic for the next thing to check farther down the line.
Sep 15, 2010 | Mackie 1604 Vlz3 16 Channel Mixer
No sound
Jul 24, 2010 | Mackie 1202vlz3 12 Channel Mixer
Jul 23, 2010 | Mackie 1202vlz3 12 Channel Mixer
Mackie CFX12 Compact Mixer with Effects (12x4x1) Logo
53 people viewed this question
Top Mackie Music Experts
Matthew Spark
Matthew Spark
Vito Vacirca Jr.
Lawrence Nentwig
Lawrence Nentwig
Level 1 Expert
Are you a Mackie Music Expert? Answer questions, earn points and help others
