Question about UTStarcom Blitz Cell Phone
My iphone 4 turns off when i unplug the charger.
My phone is acting weird. it turns off every time i unplug the charger and it wont turn back on unless i connect it to the charger again. i need help i don't know what to do?
3 Suggested Answers
SOURCE: phone shuts off right when i unplug the charger
It's a problem with the cpu. It cannot switch over to battery power after the charger is unplugged. its not a hardware problem. I chased every contact point with a multimeter and it all reads as it should. I re-soldered everything, used a diffrent charger, new battery, erased everything on the phone and it still does it. the only constant is the prosessor in the phone. It's a design flaw that pantech built into the phone.
Posted on Jun 03, 2010
  • 33 Answers
SOURCE: I accidentally turned my phone's
try taking your battery sim and memory cards out wait a few minutes and replace turn off the phone first, you might also try your provider and they will run through the sequence , if you have your manual you should be able to go through it blind, hope this helps good luck,regards terry
Posted on May 17, 2011
Cant turn iphone4 on?
plug in your charger and try to turn it on, if nothing then check the battery. Check the voltage on your battery with a meter. If voltage isn't present or lower than it says then try a new battery. If that doesn't work it will need professional repair.
Dec 17, 2011 | Apple iPhone4 4G iPhone 4
My iphone 3g wont turn back on. the facebook app was acting up so i did a hard reset. once i turned the phone back on facebook was still acting up so i did the hard reset again within 5 mins. when i tried...
You could try putting the phone into recovery mode, then resetting the firmware through iTunes. To enter recovery mode you must: 1) Open iTunes and connect your iPhone 2) Press and hold the home button and the sleep button at the same time. 3) After 10 seconds, release the sleep button but continue holding the home button After following these steps, your iPhone should now be in recovery mode and ready to be restored using iTunes. Good luck!
Mar 12, 2011 | Apple iPhone 3G
My iphone 4 didnot charge while charger is ok
If you are certain that the charger is not defective, the solution is as simple.
1. Turn your device completely off and turn it back on again.
2. Plug in charging cable.
3. If this does not solve the problem, unplug the cable again and use a dust remover (the type that comes in a pressurized can) and spray it into the charging port.
Feb 22, 2011 | Apple iPhone Smartphone
My iphone turned off by itself and it wont turn back on
hold the home and lock button at the same time and it should turn back on, have it charging when doing this
Jan 18, 2011 | Apple iPhone Smartphone
My iphone turned itself off and wont turn on, ive had it on charge but still wont turn on
try holding down the home and sleep/wake buttons until you see the apple logo cycle.
sometimes it has to be held for longer than 30 seconds.
Sep 12, 2010 | Apple iPhone Smartphone
It's fully charged and had turned its self off, but wont turn it's self on again
connect the iphone to the wall charger. Hold down both the sleep/wake button at the top right and the home button at the same time. Hold both of those buttons down while iphone is connected to the wall charger, hold them down until you see the white apple logo appear. Once you see the logo, let go. It will take a minute or two, but the phone should be powered on and back to normal. Leave plugged in to the wall charger for at least 10 minutes before disconnecting
Dec 04, 2009 | Apple iPhone Smartphone
Iphone Battery died now it wont charge or turn on
Hello ! I was in panic attack !!! did everthing and nothing seems to wake up my iphone. I forgot to charge it so battery went full empty, then I plug it on the wall charger, and nothing happend. I let it all nite, and next morning,... surprise !!!!! still the red icon, No battery, the iphone didnt restart!!!! How I fix it?
1-unplug it from the wall charger 2- press middle button and startup button, same time 3-when red battery dissapear, plug the charger. 4_ do this many times. Didnt work for me the first time, but at the end it works !!!!
NOW MY IPHONE IS WORKING GREAT !!!!! GOD BLESS YOU ALL !!!!!!!!
Aug 21, 2009 | Apple iPhone Smartphone
IPhone dont turn on
Keep the home and power button pressed for 10 seconds, then, leave power and keep the home button pressed...shud be able to see the charging cable logo...then restore it...
Jul 05, 2009 | Apple iPhone 3G
Iphone wont start
Sounds like an internal fuse that Apple has in place to protect against overcharging ...... been there ... have that t-shirt ....
Since it is still under warranty, they obviously feel that you have voided the warranty ... by say, "unlocking" the iPhone ....... been there too .....
Somebody should be able to replace that fuse ... Apple can ....
Jan 27, 2008 | Apple iPhone Smartphone
My iphone does not turn on
********************** SOLUTION!!!! **************************
If you just see an apple logo or your phone does not turn on, there is a software problem and you will need to restore your iPhone. I didn't want to hear it, because now I had to redo everything; but it's the only solution.
Put your iPhone into recovery mode.
To put your iPhone in recovery mode:
Step 1: Plug in your iPhone to your computer, make sure your sound is turned on and not muted.
Step 2: Hold the top corner button for two seconds. You should hear a sound.
Step 3: Now, still holding the top power button, immediately press the home button and hold both buttons for 10 seconds. You should hear another sound from your computer.
Step 4: Release the power button but *continue holding the home button*, for another 30 seconds.
Step 5: Meanwhile, continue holding the Home button and open iTunes. Wait for it to tell you that it’s in restore mode. You should also hear a third sound from your computer during this time.
Step 6: Click on your iPhone in iTunes. It should say it's in recovery mode and need to be restored. Step 7: Click OK and restore it.
Now you will need to re-jailbreak it, and restore your backup, and also put your music back in.
Good Luck!
Nov 29, 2007 | Apple iPhone Smartphone
UTStarcom Blitz Cell Phone Logo
1,451 people viewed this question
Top UTStarcom Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you an UTStarcom Cell Phone Expert? Answer questions, earn points and help others
