Question about Samsung HCL5515W 55" Rear Projection Television
Red lines and strong red tint to picture
After almost 6 years of no problems all of the sudden my Samsung 42 in HCL552W got red lines all over the picture. The picture is blury and has a red tint to it. When we took the back off and put my hand in front of the red tube it cleared up. Is this going to be outragious to fix? Thanks
  • nurskyden May 26, 2008
    my 3 yrs. old 50" samsung DLP has strong red tint when switched to hdtv but picture is normal when playing regular dvd movies.. when i play with my xbox 360 the picture is normal when the xbox console is swithed to TV but tinted red when switched to hdtv.. whats going on?
  • 934 Answers
By placing your hand over the red lens you stop it's convergence with the other two colors by stopping it's light emmission. That tells you two things, (1) convergence of the red tube is way off; (2) it hasn't yet placed any load on the 20+/- supply line or the unit would be in shutdown. You'll need to have the convergence amps replaced though. ICz103 and ICz104 are a Samsung p/n#BP13-00006A or the more common equivlent Sanyo STK394-250 and you'll need two of those. Good idea to test and replace any of the feed resistors that may have changed in value also. If any of this sounds complicated take it to a reputable shop. Most shops may have the parts on-hand and it's not too expensive a repair. With the above info you'll at least be on some higher ground with the repair shops you call to see if they have the parts and how much they generally charge for convergence repair for your model. Good Luck Bill
Posted on Jun 05, 2007
Red tint in dlp picture
A red tint in a DLP usually means a issue with the optical light engine it uses. A faint chance if a high pitched whine or fan like sound is the color wheel.......
Jun 07, 2012 | Samsung HCP4252W 42" Rear Projection...
Orange tint on the picture all channels
You might fix this problem by adjusting your color, contrast and brightness settings.
Apr 07, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
Grainy and red tint on component video inputs from
Usually when you have a red tint when using the component input i'ts because the wires are switched on one end or one of the 3 video wires is bad. See if blue and green are switched.I see this all the time. Is your picture grainy on all input?
Nov 22, 2009 | Panasonic TH-42PX75U 42 in. Plasma...
Hpr4262 samsung plasma picture problem
You need to call a technician.The problem lies in the board [internal].
Jun 25, 2009 | Samsung SP-R4232 42 in. Plasma HDTV
Samsung hcl552w picture leans in on top and bottom
bad convergence ic's
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 09, 2008 | Samsung HCL552W 55" Rear Projection...
Red tint on the entire picture
Always try your extended warranty!.....Probable cause = bad
red tube. One adjustment may help---turn down red screen
control, located behind technician access panel in front of set.
Nov 04, 2007 | Mitsubishi WT-42311 42" Rear Projection...
Red Lines
Red convergence IC defective===Replace Stk392-040 IC's.
Change both for reliability.I use Panasonic brand with no recalls.
let me know how it goes....T.
Oct 23, 2007 | Samsung HCL552W 55" Rear Projection...
I have 47 inch with double color in picture, reds and green
convergence amp ic bad
Oct 14, 2007 | Samsung HCL552W 55" Rear Projection...
Strong red tint with horizontal lines across screen
if you have warrenty, return it. if not, then buya new one...the video fuses are dying...hard to fix it.
Oct 06, 2007 | Akai PT4799HD Rear Projection Television
Sanyo Tv color problem
I would check the green signal all the wat to the display screen to determine is this is a signal problem or a system short. I would recommend that you take this set to a qualified electronics technician
Sep 10, 2007 | Sanyo DS27910 27" TV
Samsung HCL5515W 55" Rear Projection Television Logo
110 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
