Question about Optics
Parts list for ruger blackhawk .177 pellet rifle
I need to buy a spring for ruger blackhawk .177 cal.
  • 10 Answers
SOURCE: air rifle?
Most rifles will hit whithin at least one inch across a normal back yard. You're quality is going to come from the manufacturer. CO2 and Air Pump is a personal choice, I have noticed no difference in performance, though some say CO2 is more reliable. Daisy is a classic manufacturer and has some modern, good weighted rifles that will shoot dependably. Anything with a Walther barrel or the Walther name is a good investment when it comes to rifles (not so much for pistols). Break barrel actions are prone to jam, be difficult to open once lead shavings build up, and pinch nastilly, and if you have a child or are a novice shooter yourself, a traditional action will help you learn proper habits early on. You really shouldnt spend 300$ for an Air Rifle, or even 200...Maybe even 100.
Posted on Mar 26, 2009
fps353535
  • 99 Answers
SOURCE: Ruger 10/22 Scope problem
This happens will all firearms. what happens when the bullet leaves the bullet is a decieving "rise" of the bullet. The reason for this is the Line of Sight (Scope View), angles down and away from the Line of Departure (Barrel). The bullet actually never rises and is in fact continally falling away from your rifles Line of Departure but because this is higher than the Line of Sight the bullet seems to Rise than fall to the set distance in the scope (i mention set distance and not zero because you can change your Minutes of Angle on your scope to increase and decrease range)
http://www.rifleshootermag.com/shooting_tips/ballistics_0303/
this is a chart that illustrates what i just said.
now that you understand that you should take a good read into Exterior Ballistics. this is the Mathematics of your fireamrs trajectory ( I say your firearms because your bullet's flight depends on the length of the barel which will vary from gun to gun) this science of shooting will teach you how to understand bullet Grain and Volume relations. understanding the Feet per second of your rounds and how the affects you. teach you about shooting in high pressure and low pressure environments and extremly windy environment.
now there is alot of math to all of this and its hard to find it all on the net and if your not that great at math you can do what i do bc im lazy and im not a sniper im just a hobby kinda guy. '
Sierra Infinity V 6 Ballistics Software. I dl'd mine off the net you might have to buy it depending on how resourceful you are. it is well worth the buy. You can punch in the daily variables (Barometric Pressure, Temp, Humidity, and Altitude) (of couse with your bullet as well) and it will give you a "Cheat Sheet" for those conditions stating Windage and Elevation adjustments per decided incriment (50 yrds is standard) then you take that to the range and (bring a laptop if you got it and arent embarrased (som1 might even help you tune in the variables) hope this helps if not ill check back in a bit to see how you did
Posted on Apr 07, 2009
fawkwindows
  • 96 Answers
SOURCE: My wife has a Ruger Mini-14 patrol rifle with the
If your wife wants to use it for defense and, etc have her cowitness the optic 4moa sight with what Solution #1 suggested, instead of the normal position of the optic. Co-witnessing optics is better suited for quicker reactions, snapshots with the pekiti take off "advanced version of getting off the x"
Posted on Dec 13, 2009
erpaalai
  • 999 Answers
SOURCE: need help putting back together my air rifle.
http://www.crosman.com/pdf/manuals/CS1K77_CS1K77X%20EVP%20&%20PARTS%20LIST.pdf
If this is not your model the list is here
http://www.crosman.com/airguns/service/manuals/crosman-rifles
Eric
Posted on Jan 16, 2010
SOURCE: I own a 40 year old crosman 140, .177 cal air
REMOVE THE FOREARM PUMP ASSY SEE IF THE CUP IS WORN OR SHRUNK
PUT SOME LIGHT OIL ON THE CUP AND SPREAD
IT OPEN AND FLEX IT SOME SO THAT IT SPREADS OUT TIGHTER IN THE TUBE
YOU CAN ORDER PARTS FROM CROSSMAN
Posted on Jan 29, 2010
I was told there was no such thing as Benjamin Franklin mod 312 Ser h322837 but is in enshrined on the barrel, I need to know
Definitely exists and looks collectible.
  • Benjamin Franklin 312 .22 ' Gun Values Board www.gunvaluesboard.com/benjamin-franklin-312-.22-2923214.html My father has a Benjamin Franklin , model 312 .22 cal. Lever pump rifle , ... A Benjamin 22cal air rifle with a ser ... .22 cal Mod. 312, ...
  • i have a benjamin franklin 312 air rifle with no serial ... https://answers.yahoo.com/question/index?qid=20110411133733AAHQmgM
    • RESOLVED
    • 4 POSTS
    • 3 TOTAL ANSWERS
    2011-04-11 · I have a benjamin franklin 312 air rifle with no serial numbers on ... What you have is a Benjamin model 312, ... I have a benjamin franklin 312 air ...
  • Advice on what to do with Benjamin 312? - Airguns & Guns ... www.gatewaytoairguns.org/GTA/index.php?topic=25607.0 Advice on what to do with Benjamin 312?, ... Benjamin Pump mod. 397 ... SE CT; Beeman C1 .177 Daisy 230 (Milbro)
  • Related searches for Benjamin Franklin mod 312 Ser h322837
  • I Have A Benjamin Franklin Model #312 - Lever Pump Air ... www.gunvaluesboard.com/i-have-a-benjamin-franklin-model-312...rifle... I have a Benjamin Franklin Model #312 - lever pump air rifle in .22 cal. The stock is broken & I would like to get it fixed. ... A Benjamin 22cal air rifle with a ser ...
  • Benjamin Franklin Brass Mod 312 22 Cal Pump Pellet Rifle ... www.ebay.com/sch/sis.html?_nkw=Benjamin+Franklin+Brass+Mod+312+22... Find best value and selection for your Benjamin Franklin Brass Mod 312 22 Cal Pump Pellet Rifle Gun For Parts search on ... Benjamin Franklin Air Rifle for parts . $ ...
  • Item:8679966 Benjamin Franklin 312 AIR RIFLE PARTS .22 For ... classic.gunauction.com/search/displayitem.cfm?itemnum=8679966 Seller's Description: Benjamin Franklin 312 AIR RIFLE PARTS .22 Nice old Benjamin 312 barrel, receiver and stock Pumps air okay but there is no way to release it as ...
  • benjamin franklin 312 - Airguns & Guns Forum www.gatewaytoairguns.org/GTA/index.php?topic=37115.0 benjamin franklin 312, Air guns, Airgun Forum ... 2 RWS mod. 48s, 177, & 22 2 Benjamin Marauders 22, & 25 Benjamin Trail NPXL1100 Benjamin Pump mod. 397, ...
  • Benjamin 312 strip, tear down & dis-assembly - YouTube www.youtube.com/watch?v=W1_DGNaaAs0
    • BY NORTHWESTAIRGUN
    • 17 MIN
    • 45K VIEWS
    2014-02-06 · Video embedded · Video of the dis-assembly of the Benjamin, or Benjamin Franklin, model 312. This is similar to the model 310, 317, 342, 347, and ...
  • Ben franklin air rifle mod 312 parts diagram - fnsxowf.gq fnsxowf.gq/zeuimpooku I have come across a Benjamin Franklin Mod.340 Cal.Buy Benjamin & Sheridan ... Benjamin Franklin 312 Pump air rifle.New airguns and vintage are available in our ...
  • Need A Repair Kit For A Benjamin Air Rifle Model 312 ' Gun ... www.gunvaluesboard.com/need-a-repair-kit-for-a-benjamin-air-rifle... need a repair kit for a benjamin air rifle model 312 ... I bought an old Benjamin air rifle model # 312. ... I have a Benjamin Franklin Model #312 ...
  • What is my Benjamin Franklin model 312 cal 22 h148881 man in USA
    May 20, 2016 | Optics
    Can i but a new barrel how much
    Bone Collector .177 and .22 cal special edition air rifles ...
    www.gamousa.com > Air Rifle
    The "BONE COLLECTOR" .177 and .22 caliber air rifles. ... blast reducer integrated into a bull barrel, and utilize the advanced IGT (Inert Gas Technology).
    images for Bone Collector .177 Caliber barrel
    Nov 07, 2015 | Gamo Bone Collector .177 Caliber Hunting...
    What types of pellets is used in Beeman Sportsman Series Air Riffle Cal .55?
    The only Beeman Sportsman Rifle I can find takes either .177 or .22 caliber pellets depending on which barrel is fitted.
    If the pellet you tried was a .177 try a .22.
    Otherwise try emailing help@beeman.com and see what they say.
    Feb 01, 2015 | Beeman Optics
    How can I get an owners manual?
    Do an on-line search, companies will often allow you to download the whole manual to save them the time. Type into the search box the whole name and model and add manual.
    Nov 03, 2014 | Umarex Ruger Explorer Youth .177 Cal...
    How to repair a ruger air hawk .177
    well for starters, there is no firing pin, second, without major machinery, you can't fix a spring powered air rifle, any of them. It is impossible, major jigs and fixtures hold these things while the spring is removed and replaced. You might try crossman, they do a lot of repairs.
    Jul 30, 2012 | Umarex Air Ruger Air Hawk Air Rifle .177...
    Ilive in indiana and i have a problem with ratcoons . so i set out to buy a good air rifle , i though i had one then i put a bb .177 cal , in my brandnew BEEMAN air gun ,the the bb feel out the barel ......
    Are you sure its a bb gun and not a pellet gun? Usually bb guns have a magnet on the bolt, that keep the bbs from falling out. Pellets don't roll so the won't roll out the barrell.
    Mar 03, 2011 | Beeman 1024 Takedown Rifle, Scope, Rings &...
    Will not chamber a pellet for Crossman 357 .177 cal pellet gun
    http://www.pyramydair.com/site/manuals/Crosman-2100.pdf ,
    Read this and make a decision based on the information contained within.
    Feb 06, 2010 | Crosman Phantom .177 Caliber Break Barrel...
    Optics Logo
    248 people viewed this question
    Top Optics Experts
    james laughton
    james laughton
    Andrew Taylor
    Andrew Taylor
    Are you an Optic Expert? Answer questions, earn points and help others
