Kenmore dryer 970-c85062-00
No heat sqelling noise
5 Suggested Answers
megarza
  • 88 Answers
SOURCE: need to instructions on how to stack a kenmore
to stack you will need the stacking kit. It can be order through Sears Parts/Product Repair Service department.
Posted on Sep 23, 2009
housejess
  • 317 Answers
SOURCE: Buying a used Kenmore stackable washer/dryer
stackables are convenient..small but work great.....youll find what you need at lowes or home depot
Posted on Nov 04, 2009
heatman101
  • 43501 Answers
SOURCE: can i shorten
The blowing of the breaker has nothing to do with the hose.....
The problem you have is that you only have a 15 amp. circut to the washer... this is okay for many washers, but some will pull too much surge current especially when the motor starts.... this can trip a 15 amp. breaker...
You also could have a weak or slightly bad breaker there....
the first thing i would do is to change the breaker with a new one...do not change it to a higher amperage breaker if you do not have 12 ga wire....14 ga wire can only handle a 15 amp. breaker and 12 ga wire can handle a 20 amp. breaker....
If you only have 14 ga. wire to the washer and a new breaker does not fix the problem, then you may have to run a new 12 ga. wire to the washer...
heatman101
Posted on Dec 16, 2010
TheMobilian
  • 8220 Answers
SOURCE: DRYER RUNS BUT NO HEAT.WHERE
If it runs but no heat that is probably your heating element.
I recently worked on one of theses and got my grandson to snap a few photos of the repair.
417.91702000 Broken dryer belt and felt replacement
Posted on Jan 30, 2011
Why won't my kenmore dryer 970-c85092-00 heat?
check the heating element to see if the coils are still intact (not burnt or brake). if it is fine,then check the T-STAT and the T-CUTOFF switch. one of those is your problem. if it is the T-STAT or T-CUTOFF, replace them both, they are inexpensive and easy to replace. here is a link to a video that explains this fix thoroughly. i think you will find it helpful.
Whirlpool Kenmore Dryer Repair Won Heat Test Fuse Thermostat 279816 or...
Jul 23, 2014 | Kenmore Dryers
Kenmore dryer model 970-C85092-00 no heat
element or stats........cheers
Apr 15, 2014 | Dryers
My kenmore dryer is making a loud noise when it is going\model #970-C8909700 serial #4D02001824 it is 14 months old
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Aug 02, 2011 | Kenmore Dryers
How do i find a thermal fuse on a 970-C85042-00 dyer
take off the back panel,, you'll see it attached to the inside panel,, it looks like this http://www.partselect.com/dryer+dryer-wont-heat+repair.htm
Jul 12, 2011 | Kenmore 63942 Dryer
DRYER RUNS BUT NO HEAT.WHERE CAN THE FUSES BE ?MODEL NO 970-17802-20.SERIAL NO XE73210031.KENMORE
Jan 30, 2011 | Kenmore 98702 Stacked Washer/Dryer
Can you stack a kenmore washer / dryer model # 970-c84102-00 and 970-c44102-00?
  • yes you can stack 970 c84 10200 mine is. I just wish i could repair it, first youe have to take the cover off and thats as far as i got
Oct 19, 2010 | Kenmore Dryers
Model #970-c81032-20. Dryer makes high pitched squeal
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Aug 21, 2010 | Kenmore 83042 Electric Dryer
Nov 04, 2009 | Kenmore 98702 Stacked Washer/Dryer
No Heat
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Jul 21, 2009 | Kenmore 73952 Gas Dryer
Kenmore 970 C81062 10 Electric Dyer WILL NOT
It sounds like the drum may be stuck. Turn the dryer on with the door open, just keep the button pushed. Then try to turn the drum by hand, and see if it will start to turn.
Jun 04, 2009 | Dryers
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
