Question about Maytag Refrigerators
Maytag model number 12830906 Why will ice not dipence
3 Suggested Answers
  • 93 Answers
SOURCE: Water will not dipence from door
Most of the time when this happens it is because the water line to the dispenser is frozen. Most refrigerators have a plastic tank or a large coil of plastic line located behind the food drawers and shelves in the refrigerator side. Try to locate yours and heat it up with a hair dryer to defrost it. There is two other things it could be but they are way more rare........The first is the water valve in back of the fridge, but if you hear a noise when you press the water lever on the door then it is not the water valve. The second thing is the button that the water lever presses when you want water. It is located behind the dispenser cover, but they rarely go bad. I would bet on a frozen water line.
Posted on Sep 15, 2009
2coolrick
  • 560 Answers
SOURCE: my maytag is model MFD2560HES serial number
does the water dispenser work OK ? if yes , a try this : pour 3/4 of a cup of water into the ice maker, right into where the ejection fingers are. also , take all of the ice out of the ice bin. then , give the freezer time to freeze the water you have poured into the ice maker and see if the ice maker ejects the ice into the bin. if it does, it might reset itself and refill the unit and work normally.
Posted on Mar 17, 2010
Maytag ice maker floods the kitchen when water does not shut off when filling the ice tray. What's the reason and fix?
What is the refrigerator model number? In most cases the dual water control valve with have a mechanical defect and cause the water to flow by the valve even when off. W10408179 Water Inlet Valve
If you can find your model number around the fresh food section door frame please post so I can insure I give you the correct part numbers, Thanks Sea Breeze
Dec 04, 2012 | GALAXY Microsystems 25.4 cu. ft....
Ice maker will not make ice,have water but no ice.
Many people see this as a problem but if you take a look you have two separate controls for the ice and water system. So what's next? Look for a model number around the fresh food section door and sometimes your model number you may have looked at it every time you open the door and did not realize that is what that is. Locating Your Model Number or lets go to Maytag=> HERE and in the pull down choose if your model is a side by side or other than a side by side. Neat Tool! So now back to your ice maker and being the way most ice makers are they have a side to the water valve on their own somewhere near the water control valve on back of your refrigerator and near floor on most. The ice maker in most cases tells that water valve when the ice maker needs water again so many times it is the problem anyway. If your ice maker has cubes in it and still will not drop the cubes then it is the possibly the ice maker causing the problem but if you fill the ice maker with tap water and it freezes and then dumps cubes into the ice bin then the problem is the water control valve on the back of your refrigerator. Here is a short clip below. And here is a search for=> Maytag Refrigerator Water Control Valves and a search for=> Maytag Refrigerator Ice Makers I hope this has helped, Thanks, Sea Breeze
Here is how to=> Replacing The Water Valve on my Refrigerator
Apr 19, 2011 | Maytag Refrigerators
Maytag refrigerator
IF BOTH WATER AND ICE MAKER ARE NOT WORKING YOU MAIN NEED THE MAIN BOARD. THERE IS NO FUSE.
Apr 24, 2010 | Maytag MFI2568AES Stainless Steel Bottom...
My maytag is model MFD2560HES serial number
Mar 17, 2010 | Refrigerators
Sep 15, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
My maytag refrigerator will not drop ice cubes or crushed ice or water
OK, The most likely reason is the water control valve is defective for the ice maker or the ice maker thermostat is not working and will not tell the control valve to open for water. If ice is just sitting in the ice maker and it will not cycle then I believe the ice maker may be the problem. Now if you could tell me the model number of your Maytag I can send you a manual and tell you the part numbers. Try this, if the ice maker is empty and turned on fill with tap water and allow to freeze. If the water freezes and then dumps I will know that the water valve is not working. If the water just freezes and sits there then again it is the ice maker. Problem is I'm not sure if yours is the mechanical ice maker or has a control board in the front. They just made too may different models. Let me know and I will check back and if you find the model number the service manual I will upload to you.
Sep 07, 2009 | Maytag Refrigerators
Ice maker is not working anymore. Water doesn't fill the tub. Water dispenser out of the door is still working
I need you to double check the model number. Maytag has a service library at this link. http://www.servicematters.com/maytag_library/html/index.html
By placing the first 3 letters in the search feature it will take you to models like yours. Chose the correct model that you have and enter the number in the search. I believe that the water control valve on back of your refrigerator is the problem. Maytag is very good about helping their customers. Let me know if you have problems gettting the information you need, Thanks, Sea Breeze
May 26, 2009 | Maytag MFI2568AES Stainless Steel Bottom...
May tag m2260i side by side
that is not a good model number the model number is in the refrig section post serial also they are together.
May 12, 2008 | Maytag MSD2656G Side by Side Refrigerator
Refrigerators Logo
186 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
