Question about Tablets & eReaders
How do i get rid of a force close message
A message saying the process.android.process.acore has stopped unexpectedly. please try again.
4 Suggested Answers
SOURCE: Hi, I bought Smart Epad 7" I had error of The
You can restore your epad to factory settings by going to the settings menu > privacy > Factory data reset. and then your epad should be running normally again.
Posted on Mar 04, 2011
  • 14 Answers
SOURCE: everytime i turn on my
Link
phandroid.com/2008/10/25/how-to-reset-your-g1-and-start-from-scratch
"It came time to part with my review unit of the G1 (Thanks T-Mobile!) and send the phone back to its rightful owner. But what about all the personal info on the phone? The apps, texts, e-mails, AIMs and all that jazz? A quick search of AndroidForums.com turned up an easy way of restoring your G1 to factory settings:
if you power off your phone and hold the home (shaped like a house) and the end (red hangup button) for about 20 seconds you get a triangle with an exclamation point and a picture of the G1.
Now all you have to do is pop open that pretty QWERTY keyboard and there are several keyboard shortcuts you can use to accomplish what you want to do:
Home+Back reboot system now - (Soft Reboot)
Alt+L - Toggle log text display - (Toggles between the exclamation and menu options)
Alt+S - apply sdcard:update.zip - (Not brave enough yet)
Alt+W - Wipe data/factory reset - (What I chose, had to re-register, out of the box settings)
thee last option (Alt + W) and restored my borrowed G1 to factory settings. I'm sure the soft reboot could be helpful too, should you run into problems a troubled application may have caused. We didn't try the other 2 options so use at your own risk.
By the way, I couldn't live without a G1 so I made the leap and purcahsed a G1 with a T-Mobile service plan. I'm still a loyal Verizon customer and will simply have to keep both plans... but I NEEDED the G1. So basically, you can expect the application reviews and insight you've gotten at phandroid.com to cotinue since we've got our very own device now!
[Via Android Forums]
Posted on Apr 08, 2011
gopakumarg43
  • 74468 Answers
SOURCE: DISGO 6000 COMES UP WITH , THE PROCESS ANDRIOD.PROCESS.ACORE HAS STOPPED UNEXPECTEDLY.PLEASE TRY AGAIN.I HAVE TRIED MANY TIMES ANYONE NO HOW TO FIX.THANKS.
Hello Colin
The probelm to your Tablet is not related to my expertise. Please get helped from an other. OK.
Posted on Dec 05, 2011
My pandigital has a box pop up that says "Sorry" The process android.process.acore has stopped unexpectedly. Please try again. Force close." It just keeps popping up and won't let me do anything....
Try holding down the power and volume up buttons down for several seconds to try and soft reset your device. Power down and restart it. You don't state your model of Pandigital-that makes it hard to determine exact reset procedure. Also look for a small hole on the back or sides of the device, into which you can push a toothpick or paper clip to push a reset button (check your manual for location and reset procedure for your device). You can also try powering down, then press the volume down button and while holding that down, press the power button to turn the device back on. The error indicates a major problem with the base android software - did you recently upgrade software or install some new app? If it was a new app, try uninstalling it and see if the problem goes away.
Jan 02, 2015 | PANDIGITAL Novel Color Multimedia eReader
I have a galaxy pro tab 10.1 that keeps rep the same error msg. ( unfortunately the process android, process.acore has stopped) and I can't do anything , I press OK and it goes away only to come right back...
I would recommend following the steps in the below link. It has detail information on how to fix this issue. Mine was same as you and it fixed. Though I lost a few apps and contacts. But did have a back up in my SD card and re installed them. Watch out and test your phone when installing the apps one by one and you could narrow down the culprit.
Force close error or process stops unexpectedly Android
Good luck and Merry Christmas.
Dec 20, 2014 | Tablets & eReaders
Keep getting pop- up that says sorry the process.android.acore has stopped unexpectedly.please try again
seems like the firmware is crashed. have u tried backing up and doing a soft reset ? 2_24_2014_2_30_41_pm.jpg
Jul 25, 2013 | Tablets & eReaders
I keep getting a pop up that says sorry the process android.process.acore has stopped unexpectedly.please try again
That only happen when android is rooted the way to fix that is to get gapp updates 11_23_2013_2_34_37_am.png
Problem!!! I need help!!
That is the home screen. Have you installed a different launcher or home screen. If so remove that. If you havent do a factory reset. Unless your device is rooted, You wouldnt have access to fix that error
May 12, 2013 | Google Android Sowill oioi s7 7 inch...
Have a 10 magni tablet model SYTAB10ST screen shows sorry! the process android.process.acore has stopped unexpectedly please try again . it has a force close tab on screen but the error still pop up t
this means that the program you were running has crashed. If it happens everytime you launch a particular application then I would advise removing the program from the tablet and then reloading it
Dec 20, 2012 | Tablets & eReaders
Why viewsonic viewpad 7e android process won't work?
if you're using a custom ROM re-flash GAPPS. Otherwise try to factory reset
Jun 03, 2017 | ViewSonic ViewPad 7e
On my pandigital nivek 9inch the application browser(process com.android.browser) has stopped unexpectedly and it says try again, but when you try again it still doesn't work
I also had this problem. What I did was hooked my pandigital up to my computer and put videos on there that would take up alot of room. After I unplugged it I got a message saying that my memory was low. I clicked on the message and it showed me all the default applications instead of the applications I download. I clicked on my browser and pressed force stop and clear cache and it had worked fine. If you dont feel like doing all that work I suggest you download another browser such as Opera Mini or Dolphin Browser mini.
Dec 24, 2011 | Tablets & eReaders
Tablets & eReaders Logo
59 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
