Question about Kenmore 22422 Top Load Washer
Water won't drain won't spin Kenmore front loader
Washer about 9 years old. had timer problems and board problems both replaced about 1 year ago. If i drain water it will spin, but won't spin afteray cycle or pump out water. I have a new timer and board I can install. Thanks.
  • 1 more comment
  • rkpowens Jan 10, 2009
    Thanks for you response. The washer will go thru first wash cycle then stop. If I lower the drain hose and drain water it will go thru next cycle, until spin. If i keep draining the washer will eventually go into spin. After final spin clothes are still more damp than normal. Thank you.
  • rkpowens Jan 11, 2009
    With the help of this site, and especially appldoctom, I pulled the drain pump and removed a nickel and a pebble. I replaced the pump and it works great. Thank you.
  • Thomas Malailua
    Thomas Malailua May 11, 2010
    so are you draining water by hand,[may be droping the drain hose].if it spins, because you have to get the water out to spin .we are talking top loader? if will spin lid switch ok, then pump, on the other side of motor.soooooo,sock in pump or the coupler in the pump where it attaches to the motor is rounded out.
    Sergeant:
  • 311 Answers
Glad i could help.if you have a chance ,i thank you for you great rating
Posted on Jan 11, 2009
Whirlpool top loader washer will not spin
Could be one of several different things depending on the age and model. If its less than 10 years old and is a top load washer its probably a motor coupling (connects the motor to the transmission kinda like a belt) or lid switch. If the water is draining out but the washer is not spinning its probably the motor coupling. If it still has water in it and won't spin, its probably the lid switch. If your washer is a front loader there could be several things going on. Hope that helps.
Aug 29, 2011 | Whirlpool Washing Machines
Front loader won't spin and is filled up with water. Won't drain.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
May 15, 2011 | Kenmore Energy Star 44092 Front Load...
My kenmore 800 washer is off cycle for example when i start a load of clothes it starts agitating before filling, and doesn't always spin all the water out of the clothes
I have the exact same problem with my Kenmore 800 top loader, Model # 110.29822800. It is only 1.5 years old. Any suggestions?
Jan 19, 2011 | Kenmore 22422 Top Load Washer
I have a Kenmore top load washer model 20692. The washer won't drain and whenever the washer is supposed to turn all I hear is a hum. What could be the problem and is it worth fixing in a 10 year old...
Sounds like you have multiple problems...you are right... probably not worth fixing...
Look at the front loaders... they use way less water and are more gentile on your clothing...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Aug 08, 2010 | Kenmore Washing Machines
GE Top Loader 10 years old. won't drain
Timer is faulty and should be replaced.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 10, 2009 | GE WBSR3140DW Top Load Washer
Front loader wont agitate or spin, but it fills with water and pumps water out
likely the lid switch is bad - if not the ECU/timer is.
May 28, 2009 | Kenmore 43042 Front Load Washer
Frigidaire front loader washing machine won't spin...
The problem is a faulty Door Latch Assembly. The same thing happened to my Frigidaire front load washer. The part is easy to install, costs about 60 dollars and can be picked up at most appliance repair stores . To access the switch just remove the wire around the front drum gasket, peel back the rubber gasket beside the switch assembly then remove the two screws holding it in place. remove the three wire connector blocks and swap in the new switch. My washer was giving me error code 41 witch is a faulty control board. But the problem was in fact only the switch...
Sep 02, 2008 | Frigidaire GLTF2940ES Front Load Washer
Kenmore Front Loader-Doesnt Aggitate nor Spin
the speed control board needs to be replaced in the lower rirght corner of the washer
Sep 12, 2007 | Kenmore 44102 Front Load Washer
Kenmore 22422 Top Load Washer Logo
71 people viewed this question
Sal De GO PATS
fordexpert
Ed Mac
