Question about Swarovski Elis Bangle watch
Elis bangle set time
How do I set the time
Where Can I Find Patterns For Crochet Jewelry?
The particularwayregardingoutfitbraceletsis undoubtedly amove toregular. This particulardevelopmenthas becomeongoingfor thatultimatenumber ofagesandaccording to Henrik Vejlgaard inAnatomyof theCraze, recordrevealsdevelopmentssimilar to thisgo up and downlittle by little, commonlymore than aten years.
Fashion Lady Crystal Bangle (Green)
Sep 02, 2013 | Ultrak Watches
The strap is buckled at one of the hinges on the stainless steel bangle this has happened before and the jeweller fixed it within minutes. does anybody know the technique of how to fix it? thanks mandy
mcdevito75 here, Hi Mandy, a special Spring bar remover / installer tool is needed then the spring bar itself, the spring bar holds the band onto the watch, best bet, return to the jeweler for repair.
Oct 16, 2010 | Gucci 112 Twirl Small Mother Of Pearl Dial...
Hi My daughter has a silicone bangle watch which has been fiddled with and has lost the time. We can only see the word 'sports' along with a 60 second timer in the display window. Do you have instructions...
I couldn't find any guide to the watch but perhaps you could try the following:-
Apply pressure to the edges at the top and bottom of the watch (looking for hidden buttons).
Is it possible to pop the mechanism out of the bangle, if so the setting buttons may be on the reverse.
Mar 05, 2010 | Watches
Larger clasp
Unfortunately, I do not think this is going to be an easy fix. You may want to take it to a local independent watchmaker. Gucci may sell larger clasps but they may be difficult to find even from them directly. I have looked at the watch you have. It it was solid gold a Jeweler could just make it a touch larger.
Looking at the clasps the options i see is
Have the bangle removed and wear it on a leather strap,
Possibly remove the clasp where it says gucci and have the pins laser welded so that the clasp stays in a fixed position similar to a bangle.
mike --consumerwatchguide.com
Jan 02, 2009 | Gucci 1500 YA015512 Watch
Date setting of Frederique constant
hi
never change week or date when day is on "sun" or "mon" also never change date or week or day when time is between 9 pm and 5 am.
to change day, move time back and forth between 10 pm and 2 am.
moon will change only after 24 hr round (not during quick day change)
hope this helps
eli
Oct 17, 2008 | Watches
Eco-drive watch
Try http://www.citizenwatch.com/CUK/English/settings.asp
Jan 12, 2008 | Citizen Bangle EH9430-56E Wrist Watch
Swarovski Elis Bangle  watch Logo
Top Swarovski Watches Experts
k24674
ray gallant
Are you a Swarovski Watch Expert? Answer questions, earn points and help others
