Curtis Klu 7-inch Touch Screen Mobile Internet Device Logo
Posted on Nov 27, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do you download apps?
How do you dowmload apps?
Justin
Level 3:
  • Curtis Master 2,072 Answers
  • Posted on Nov 27, 2012
Justin
Curtis Master
Level 3:
Answers
2072
Questions
0
Helped
431646
Points
5629
This tablet is running Android 2.1 and doesn't support the Android App Market.
1helpful
How do I download the google play store app.
you can not download google play store app because google app store application have different extension then iphone apple app store for google app store application extension : .apk for iphone app store entension : .ipa so you cannot download a apple store app on i devices
Why I can't download any apps
sounds like your cellphone has dumped all of the DOWNLOADED apps because there was too many for the size of the SD card, and they were clogging up the system , simple answer is get a bigger micro SD card then go to Playstore and look for ' my apps ' in the menu . you will see all of the apps you have downloaded , now you can download them again to the bigger micro SD card. try not to overload the micro SD card, leave about 15% free
How do I download free Netflix app that is compatible with apple ipad1 first generation iOS 5.1?
install netflix on ipad first gen.:
first make sure your iPad 1st. gen is on iOS 5.1.1 !
It is possible, a bit tricky, but possible. First, you'll need to download the Netflix app through iTunes on your computer, this will make it show up as "purchased" in your library. After that, open up the App Store on your iPad 1 and go to the 'purchased' tab. When you try to install it this way it will tell you that you need iOS 6 or higher, but will also ask if you would like to download an older version of the app. then click on download.
- again step by step:
1) Open up iTunes on your computer
2) Go to Store (left hand column) ->iTunes Store
3) Search for Netflix; - download the app
4) then open App Store on your iPad
5) Click on 'Purchased'
- you will have to install NetFlix by clicking on it as usual.
App Store will ask you: "Download an older version of this app. The current version requires iOS 6.0 or later, but you can download the last compatible version.",
then click on Download and it should finally work.
download-free-netflix-app-compatible-ucocffsbdgqp14shduy2nfxr-3-0.jpg download-free-netflix-app-compatible-ucocffsbdgqp14shduy2nfxr-3-2.jpg download-free-netflix-app-compatible-ucocffsbdgqp14shduy2nfxr-3-5.jpg
Android tablet problems
i need help to unlock my android tablet , it just says visit google.com/recovery/accounts and i did that but it still dosent work what is the problem ???
2helpful
How to download apps on my 7" ematic pro series tablet
Find the "Ematic App Shop" in your list of applications. There isn't a google app store but it does have apps for download. You may need to set up an account before you are able to download the apps, but the shop should give you the instructions. If for some reason you cannot enter your country of origin during the sign-in process, you'll need to install a different App Shop. Go here to find it.
What does code 912 mean? i get this when downloading apps from apps store
There are a few reasons why you would get a 912 error when downloading apps.
  • Downloading apps directly to an SD card
  • Play Store (app store) needs to be updated
  • Bad cache
The following methods could help solve the problem
Clear Cache and Reboot
  • Go to Setting >> Go to Application Setting (In some devices application setting is named as apps).
  • Go to, All the apps > >Find the Google Play Store >> Clear Data and Cache
  • Once you have clear everything, Next you need to Force Stop the application
  • Also, try to clear Cache and data of Download Manager and Google Service Framework.
  • Now, Restart your device and try to download the app.
Unmount SD Card
  • Go to Setting >> Storage >> Scroll down and select "Unmount SD card"
  • Open Google Play Store >> Download the app again that was giving you the error message
  • After successful installation, Go back to Settings >> Storage >> tap on "mount SD card"
  • If above steps didn't work, also try removing your SD card before installing.
Move app to phone
  • Go to Settings >> Go to Apps >> Select, All the apps
  • Scroll down and select the app that was giving you the error during update
  • Select "Move to phone"
  • Open Google Play Store and update the app
  • After successful installation, you can move the app back to SD card
3answers
Why wont safari let open office download?
You have to download an app for documents like Open Office to download and open on your iPad. Safari won't let you download certain files from the internet. Apps like Downloads HD are one of those apps that lets you download almost anything from your iPad and open it from within the app or from another app that can open that file you downloaded.
Top Curtis Tablets & eReaders Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Curtis Tablet and eReader Expert? Answer questions, earn points and help others
