Question about Westinghouse Televison & Video
Only green color when on vga/ computer input
Brand new tv, color works fine except when on the vga/ computer input. Then it is only green!
  • 26 Answers
It sounds like you have A broke pin in your cable
Posted on Nov 27, 2012
3 Suggested Answers
  • 54 Answers
SOURCE: VGA connection just reads "no signal" Brand new TV and VGA cable.
i have a 26" insignia lcd tv that i use as a montor uou musr set the screen resolution on your computer to 1024x768. if you use a higher resolution it will say no signal.so use your montor to set the resolution to 1024x768 then hook it to the vga and it should work. bob griggs
Posted on Jul 07, 2009
SOURCE: My desktop computer worked fine,but hooked my
mine just did the same how did u fix it kevinbailey7141@hotmail.com
Posted on Dec 31, 2009
Sharp Notevision PG-C30XE problem with computer display
There are 3 different types of analog video signal ports on your projector; s-video, composite video, and RGB. Which one of the three are you using to connect your PC to?
The projector's resolution rate is XGA [1024 x 768]
If you are using a VGA cable designed and capable of handling 640 x 480 resolution; then it will not support XGAs 1024 x 768 signal. On the other hand, if the coaxial cable you are using is a multi band one that is capable of supporting VGA and XGA resolution signals, most likely the problem is not with the cable- although I have come across brand new cables that are defective.
Please let me know if this helps or else we'll try another approach :)
Nov 25, 2013 | Sharp Notevision PG-C30XE Multimedia...
How i hook it to my computer
i am assuming your tv has a vga plug and you have a desktop computer you just run cable to computer vga out to your tv and change your tv input to vga or computer input . if you have a laptop you do the same thing except you have to hit f7 on most computers to toggle the dual monitor option
Aug 05, 2012 | Televison & Video
My screen is revolving colors blue, green, white, and red and will not stop
Display of color strips on the screen is the default behaviour of the LCD screens when there is NO INPUT. This means that the LCD is working fine but there is no input/ signal from the PC. So, make sure that your PC is working fine and the video (VGA) cable properly connected to the LCD.
Let me know if any further clarification/ assistance is required.
Good Luck!
Hope this helps!
CreativeTECH
Jan 10, 2011 | Acer H233H bmid Monitor
My dell inspiron 530 shows a block with red, white, green, and read, can't get to the my programs????
That "red white green and blue" block is a color pattern tester. that means the monitor is on, but is not receiving a signal, so its running tests. If your monitor has Digital input and VGA input, you may just need to switch inputs. Look for 1 or VGA if youre using the blue hook up. look for 2 or digital or dvi if youre using the larger white hook up. Some monitors also have 'auto detect'. If you are in "auto detect' bbut the color box is still there, then your monitor is not receiving video signal from the computer. It could indicate a bad cable or no signal being sent by the machine. If you try another monitor, you can see if the machine is working. I would try a monitor setting for VGA-1 first, since thats most common.
Jun 25, 2010 | Dell Inspiron 530 Desktop Computer
How do I hook my tv up to my acer netbook? I dont have a tv port but do have a port for a second moniter and have the cord to hook it up but it will not work...
If the TV doesn't have a VGA input, you have two options. If the TV has component video inputs (3 RCA jacks color-coded red, green and blue, not just a single video jack coded yellow), you can use a simple adapter cable. Here is an example.
If your TV only has a single yellow video input jack (called composite video) you can't use the simple cable. But you can get a VGA to video converter. This device takes the VGA signals and converts them to the form the TV can use.
Hope this helps. Thanks for using Fixya!
Mar 30, 2010 | Acer Aspire One PC Notebook
Insignia LCD tv 32".....
It's either the VGA cable you are using has a bad pin or the RGB/Color Scheme is set wrong. So try another VGA cable or try the LCDTV on another PC.
Feb 22, 2008 | Insignia LCDTV26 26 in. Television
Mitsubishi WS-65905 DTV is green
A compatibility issue rears its ugly head. The format that was to be back then has changed slightly over the years and this is what it's come to...Sorry...accordianman
Jan 04, 2008 | Mitsubishi WS-65869 65" Rear Projection...
Red lamp issue
the color which you see has problem i think you might be seeing white slanting lines also with this. it mainly due to 1 supply to green video supply 2 loose cuntact in g.video section 3 green tr. defective 4 ckt from ic to green input is defective 5 chroma ic defective if supply is ok. regards
Sep 14, 2007 | Pioneer SD-533HD5 53" Rear Projection HDTV
Televison & Video Logo
88 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
