How do i hook up my surround sound pioneer XV-HTD340 to an optical port on my samsung LN40B500P3FXZA
Im hooking it up to a samsung LN40B500P3FXZA TV
satscoop
  • 59 Answers
SOURCE: hooking up to digital cable box
Darth,
There are 2 ways you can accomplish this.First is the least quality which is via coax.What you want to do is connect the cable service coming from the wall to the input on your cable box.Then the TV output on the cable box goes to the input on your surround sound then the coax goes from the surround sound to the coax input on the TV.The second is to Connect using the RCA AV1 input.what you want to do is look at the back of the digital cable box and locate the OUTPUTS for the RCA jacks(or AV output)connect RCA cables (yellow red white) to the 1st INPUT on your surround sound.depending on models you should have a couple of different INPUTS for a signal.Choose one and plug it in.After that take a second pair of RCA cables and connect them to video OUTPUT on the surround sound and connect them to your AV1 OUTPUT on your TV.With the original remote for your TV,NOT the cable universal one,Look for an INPUT button on the remote.Some are called input some are called SOURCE,TV/VIDEO basically it tells the TV what signal source to look at on the back of the TV.If you dont have the remote put the TV on channel 3 then press the channel down button and when the TV gets to channel 1 press it again and it should start cycling through the AV inputs,choose AV1.
Once you have done this you have correctly
hooked everything up,BUT Like I said depending on the model of surround sound you are going to have to CHOOSE or physically select or "tell" the surround sound receiver which input to RECEIVE the sound through.In general the INPUT on the back of the surround sound will be labeled with something like Video IN,VCR IN, DVD IN and so forth.Make sure the surround sound is selected to Receive the sound coming from the digital box.Sometimes there is a dial on the front of the surround sound that allows you to select which INPUT on on the back becomes active .make sure that what you have selected matches what you have your cable box is connected to.Hope this helps!
Posted on Nov 03, 2007
SOURCE: Sony surround sound hookup
In short, the answer is: Hook up all three to each other. I have a Samsung DLP HDTV, and I was trying to hook up a Sony DAV-HDX500 home-theater system and a Comcast HD set-top box, but I found that the Sony user guide is helpful only for setting up the speakers. Most of what it had to say about HDMI and getting the TV sound or cable sound to go through the speaker system was wrong (or, at least, it didn't work for me). So, here's what I did. I connected Component video cables (Y/Pb/Pr out) from the Cable box to the TV (Y/Pb/Pr in), audio cables from the Cable box (audio out) to the Sony system ("SAT/Cable" audio in), and an HDMI cable from the Sony system (HDMI out) to the TV (HDMI in). This allows me to 1) watch DVDs with surround sound through the TV's HDMI source (when the "DVD" format is selected on the Sony system), 2) watch cable with surround sound through the TV's Component source (when the "SAT/Cable" format is selected on the Sony system), and 3) watch cable WITHOUT the surround sound, as I did before I ever had the Sony system. One item of note: When watching a non-HD channel with the surrond sound on, the audio is slightly out of synch with the video; thankfully, there's no such problem on HD channels. Anyway, I hope this helps. It drove me crazy for two days straight!
Posted on Jun 20, 2008
  • 20 Answers
SOURCE: Samsung HT-TQ85 HDMI Input not working
I rember reading an article stating that the HDMI does not suppory audio
Posted on Sep 23, 2008
  • 151 Answers
SOURCE: no surround sound on ps3
Set the sound out put on ps3 to the optical out put then set sound on ps3 to give you dolby digital,dts,aac etc.
PS, do not set the hrtz range above 100 as this can damage your speakers.
hope this helps.
CABLE GUY.
Posted on Jan 06, 2009
SOURCE: hooking up sony dav-hdx 475 with digital cable box and hdtv
Plug the digital cable box audio strait into the dvd player. Plug video from the digital box into your tv.
Thats what i did and it works perfectly.
Posted on Jan 24, 2009
Cant get any sound from the speakers new samsung 4k tv with optical chord hooked up
The Samsung does not have an optical audio IN to the TV. It only has an optical audio OUT. Meaning the audio would leave the TV to a receiver or sound bar instead of the TV speakers. Optical audio is for surround sound systems. I hope this helps.
Apr 05, 2016 | Samsung Televison & Video
I have no sound through my surround sound when playing ps3
The optical audio out from the TV only works for the TV's tuner, probably. Hook-up optical from Cable/SAT and from PS3 boxes to DVD/Receiver.
Apr 20, 2010 | Pioneer PDP-LX508A 50 in. Plasma TV
Can I use my Pioneer VSX-D412 receiver to hook up my surround system to my new Samsung HDTV?
Yes, both receiver and tv have optical/digital connectors, or alternatively, the S-video connector. The Pioneer will decode the compressed 5.1 signal coming from the tv unit.
Feb 15, 2010 | Pioneer VSX-D412 Receiver
I bought the sony bdv e500w surround sound and hooked up a optical audio to my tv and that is a sony bravia but it will not work with the surround sound when i hook it up using regular audio cords it works...
im having the same problem, except im connected via audio components and hdmi...cant get sound through the speakers when the TV is on, it doesnt make any sense.
Feb 14, 2010 | Sony Audio Players & Recorders
Ibought samsung surround sound and hooked it to the tv,but it only works when i play dvd.how can i connect to my tv so i can surround sound from tv or drem box
connect audio cables from the audio out jacks on your tv to the audio in jacks on your samsung surround. they may be labeled video 1,2 or aux. if your using a cable box the cable box may have optical or digital input jacks. your samsung surround should have a digital in jack which requires an optical cable.
Oct 21, 2009 | Samsung HT-Z310T Theater System
No surround sound like the movies
HOOK IT UP FROM A DVD PLAYER OR BLU RAY,,, WITH EITHER COMPONENT OR A OPTICAL CABLE ,,MAKE SURE YOU HAVE ALL OF IT TURNED ON ON THE RECIER SETUP
May 14, 2009 | Pioneer SX-315
Help getting sound from New Sony LCD Television Model XV HTD520 DVD Player with Surround Sound S HTD520
While I could not find it in the manual, I found that you must
go to the menu, open Sound Options and set Speakers to "Fixed".
Note: If you turn off the Surround Sound or DVD player combination you must then go back to the menu and turn the speakers back to Televsion.
Jul 21, 2008 | Audio Players & Recorders
Need hook up diagram for Samsung HDTV using HDMI with Cable box and Samsung 5.1 Surround Theater System
you can run a fiber optic cable out of the tv into the surround system if the sytem has a fiber optic input, or your tv should at least have red and white rca cables for audio out, then you just pick any input on the surround sound and any audio from dvd players ect thats hooked up to the tv will be sent through that one input on the surround sound. The only thing you'll have to do is turn the volume up or down on your sound system.
Jul 09, 2008 | Televison & Video
Hook up surround sound system to entire system
Is the 42 inch a lcd tv. is the blueray player & ps3 hooked up in the hdmi inputs?
Jun 01, 2008 | Samsung 1200W 5.1-Ch. XM-Ready Home...
48 people viewed this question
 Grubhead
Grubhead
