SEN R4400 the subwoofer in the bottom box is blown and i have no idea how to remove it to replace it
2 Suggested Answers
  • 3 Answers
SOURCE: AR1 Subwoofer Keeps Blowing the 5 Amp Fuse
Well, so far so good. I reinstalled the newly repaired amp and fired it up and so far, so good. Ran it through about an hour of fairly intense break-in tracks and then ran it through about 2 dozen power up and down cycles to try to get it to fail (better now than a month from now and have to fight them on backing it up).
Posted on Nov 13, 2008
Boot light and clock not working
HI, Both these are usually run through the same fuse. Check the fuse box for a blown fuse. Probably a 10 Amp or less. When you remove the fuse cover it shows an index of all the fuses so you can see which one it is. Remove and replace with same rated fuse.
May 12, 2011 | Car Audio & Video
I have an AR s112ps subwoofer. I woofer is blown and i would like to find a replacement woofer. I havent had any luck looking on the net so far. any ideas?
all you need is an 8 ohm subwoofer or a Dual Voice Coil (DVC) 4 ohm subwoofer wired in series that can handle 120 Watts rms. I Went with a Rockford Fosgate Punch P1 P1S812 12-Inch 150-Watt Subwoofer - 8 Ohm
it was only $35 from amazon and is probably nicer quality than the original driver. Good Luck
Dec 24, 2010 | Audio Players & Recorders
My 13w7 pops loudly when i turn it up. it is in a 2 cu ft sealed box. what do i set my amp at to fix this? the amp is a 1000/1 jl
If your Subwoofer is popping it could possibly be blown. when your radio is off slightly push in on your speaker if it kinda crackles it is blown. If you are using a sealed box put it in the middle of the box. if it is ported it needs to be on the opposite side from the port
Feb 14, 2010 | Jl Audio 13W7 Car Subwoofer
2002 Ford Explorer Sport - Blown Subwoofer
yes you can replace it but is gonna be costly,because your gonna need a box plus the new woofer,any after market will not fit plus will require more power ,so your gonna need a bigger amp,plus wiring etc,,,,,re consider using a factory sub again or replace the sub plus the amp..check the replacements and amps at crutchfield..good luck
Jul 10, 2009 | Car Audio & Video
Subwoofers
they sound like there blown to me
Jul 09, 2008 | Car Audio & Video
Replacing all season blower motor
six screws hold the glove box two at bottom four at the inside when u open the box after the screws are out pull on the box to remove and three hold the blower motor.its not hard at all.
Jun 14, 2008 | 2004 Infiniti I35
Jun 01, 2008 | Acoustic Research AR1 Speaker
Gemsound power speaker
have no idea but what kinda speaker is it for a car or a house if for a car then u might have hooked it up wrong or the coil is blown hopes this helps
Apr 06, 2008 | Gem Sound Gemsound Concert Series...
Bottoming out
Well, If you're sure they're not blown, they're either bottoming out because you're overpowering them, or your box is not the best. I'd recommend putting them in a sealed box. even run some caulk inside where every peice of wood meets another, just to make sure it's sealed. If your box isn't sealed well at the edges, or your ports are too big, the speaker will have excessive excursion (in & out movement), causing bottoming out, and voice coil damage. Plus, I just like the nice tight bass from a sealed enclosure. Hope this helps.
Nov 25, 2007 | Pyramid PWFX107 Car Subwoofer
Televison & Video Logo
54 people viewed this question
Top Televison & Video Experts
Electro Med Services...
