Hi just need to know how to get rid of that ghostly look on Phillips matchline projector tv everything else works fine I have been reading about it and says change the coolant my husband wants to try
  • Joulanda HABIB Nov 30, 2012
    it is a projector tv or else i would not say so
  • 26 Answers
The coolant needs to be changed in the green and blue tubes
Posted on Nov 27, 2012
Testimonial: "thanks for your advise "
Its not aprojector its a tv and you need to get anew one ?
5 Suggested Answers
  • 608 Answers
SOURCE: televions
You are not the only one I can tell you that. I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Posted on Dec 09, 2010
SOURCE: Hi we have a 42in philips matchline flat tv. When ...
mine is doing the same.... any solution to fix this problem?
Posted on Sep 27, 2010
  • 163 Answers
SOURCE: I have a vitical black line about an inch wide on
Usually it is not fixable, but sometimes there could be bad connection in x-buffer board or bad board.
Posted on Oct 10, 2010
zhyren
  • 136 Answers
SOURCE: MY MATCHLINE PHILLIPS TV WONT
Ok sir, is the power on light functions?
Posted on Jul 10, 2011
My Epson Powerlite 5350 has a ghost image. Any recommendation on how to adjust the projector to remove this symptom?
I've got the same problem on two Epson EMP7300.
I believe (from reading about other projectors) that the ghost image can be adjusted with RS232 codes.
Does anyone know how to do this?
Jan 24, 2010 | Epson PowerLite 5350 Multimedia Projector
Ghost vision
wel if the ghost vision is still there try and set the brightness and contrast from your xbox 360 console
May 20, 2009 | Microsoft Premium System for Xbox 360
Rgb connection not working
check tv manual for native resolutions and verify settings on laptop also verify progressive scan or interlaced and verify they both match output input
May 08, 2009 | Televison & Video
Ghost image
You will have to replace both the convergence IC's on your TV..
Oct 23, 2008 | Sanyo PLC-XR70N 70" LCD Monitor
Double picture on Mitubishi WS-65511, Year 2002 TV
Your tv requires replacement of STK393-110 as it creates convergence problem and its available Parts Store here. If you want to do the job at your own, you need to know good soldering skills or get service of nearest TV repair shop.
Sep 13, 2008 | Mitsubishi WS-65511 65" Rear Projection...
I have a 61 in sony that is projecting an ghost image.
May I know exact model number and brand name of your TV or Projector to help you.
Aug 16, 2008 | NEC VT465 Multimedia Projector
I dont find philips RC2033 code.
Don't know if you have the original codes or not, but here are the codes for Phillips TV's from the original manual. Hope this helps. Try them one at a time and see if they work.
002, 009, 102, 109, 309, 402, 408, 502, 508, 807, 901, 914.
Good Luck,
Chris :-)
Nov 10, 2007 | Philips PM-8FS LCD Touchscreen Remote...
Televison & Video Logo
67 people viewed this question
Top Televison & Video Experts
Electro Med Services...
