Question about Plumbing
My Fontaine Monaco kitchen faucet just sprays water, never a seadystream or way to switch it. Have tried Lowes different areators but to no avail. What do I need?
I just moved in and the faucet just sprays so it is difficult to fill a bottle or anything. I have taken off the end and brought to Lowes . I have been sold different parts but nothing works. I can not find this model on Fontaines web site. The house was new 8 years ago but the man redid thekitchen since. I would imagine he didn't do it right away as it was new so I can't figure the faucet is more than 5 years old. Nice faucet but annoying.
    Top Expert:
  • 45,112 Answers
The faucet has the wrong aerator or an aerator that has been installed incorrectly or is missing parts or is cross-threaded.
Posted on Jun 11, 2017
  • 171 Answers
SOURCE: kitchen faucet , reduced water flow / pressure
Hi ssam1
I'm Harvey the Master Plumber.
You want to know if you can fix a sudden low volume /pressure delivery problem on an American Standard model AS4205100 H7, one hole / single lever with pullout spray And is it fixable by owner?
Yes and maybe!
All plumbing systems are plauged with debrie buildup. Every time you turn on a faucet the water starts moving and will bring bits of debrie up from the water main or well. Most are small and will pass through to be caught by the screen in the aireator. Sometimes a relatively large piece comes along and dosen't make it through to the screen. It is stuck in the body of the valve.
Fixing takes a little mechanical ability.
First, turn off the water to the faucet in question. Then carefully disasemble paying close attention to the order of disasembly so you can reverse the order when putting back together. As each part is removed inspect it for that troublesome bit. I find that a little bit of wire or a paper clip is helpfull. Carefully reasemble. If the volume is still low then you missed finding that bit. Try again or call in a local pro.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 10, 2008
arealplumber
  • 33 Answers
SOURCE: delta kitchen faucet mixed spray...diverter problem???
No a pull out sprayer problem is different.
First try this. Pull out the sprayer and remove from hose by turning nut that connects sprayer to hose. If you can get someone to help you it would be nice since the hose can go down into the faucet and might be trouble to retrieve. Look in the connection on the sprayer where the hose connects and look at the screen. If the screen is plugged or dirty clean and reinsert. If you can't clean it replace it. If this isn't working go to the next suggestion below.
In the spray head of the faucet there is a build up of deposits from use and or water hardness. Here is the link to the Delta site.
Delta Faucets
If you find you faucet model order a new spray head. Once these go bad they usually need replacing.
Hope this helps and please rate this!
Posted on Dec 09, 2008
  • 3600 Answers
SOURCE: I have a moen pull out kitchen faucet that leaks
You have a bad internal o-ring or the sprayer o-ring is leaking, if you look under the sink turn it off and then turn it back on, if you see it leaking out the center shft where the water pipes go into then the faucet may have a broken pipe or loose pipe. check and tell me where it's leaking at. You can buy kits to repiar them they are inexpensive.
Posted on Aug 30, 2009
SOURCE: kitchen faucet single handle pull-out. The base of
I have the same problem with an American Standard Reliant Kitchen Faucet that wont swivel anymore. I called American Standard and they are sending me the replacement parts to fix it free of charge, I have had mine 6-7 years and they said it was under warranty. Call 800-442-1902. Good Luck
Posted on Apr 05, 2010
  • 26 Answers
SOURCE: i have a blanco kitchen
behind the handle there should be an allen screw under a crome cap . once you reove the screw the upper metal ring should just unscrew then there are a series of o rings that can be replaced
good luck James
Posted on Dec 26, 2010
For kitchen faucet Fontaine NF-RSPK the spray function is broken/inoperative.
time to replace it the internal parts are not available as repair parts
Nov 12, 2016 | Fontaine Plumbing
Fontaine NFKHI4AC Faucets Hiarc Kitchen Faucet With Sidesp the finish as worn off the faucet holding ring and sprayer were can I get these parts
call Moen they will send yo new parts for free
How about that :)
Thanks Tom
Oh they take abot 3 days to ssend out new parts, and the price is right
Sep 16, 2011 | Fontaine NFKHI4AC Faucets Hiarc...
Model number NF-PDSH the braided hose is leaking thru the seams
you need to replace the hose once the braided ones start leaking , turn off the water source, remove the hose, Its gonna leak some so be careful,, take that hose with you to a Home depot or lowes, some place like that so you get the correct size end pieces
Jun 14, 2011 | Fontaine NFKPDSORB Faucets Luxury...
Low water pressure in my grohe bridgeford kitchen faucet what could be the problem
The first thing to check is the areator at the end of the spout...
They often plug with dirt and drop the water pressure...
Take that off and check out the water with it off...
Then if it is still low then it is dirt trapped internally in the faucet...
heatman101
Sep 26, 2010 | Grohe Classic Kitchen/Bar Faucet ...
Fix diverter valve sprayer No water pressure Can I soak in CLR? Where to buy Parts ?
CLR usually works great. Replacement parts are available at Lowes Home supply stores and perhaps Home Depot. I've had better luck getting parts at Lowes.
Mar 09, 2010 | Price Pfister Marielle Kitchen Faucet with...
I have a pfister 536-e series Pfister/catalina colletion kitchen faucet. Low water pressure from both the hot and cold water. How do I fix the water pressure? Water pressure in the rest of the house is...
First unscrew areator from faucet spout, you might need pliers for this. Make sure the areator is clean, sometimes sedement from water lines can slow water down.
Sep 27, 2009 | Plumbing
Need a shower valve replacement cartridge
I found the cartridge at globeunion [nooutgoing@email.com], 888-328-2383. They told me they are shipping the cartridge to me today at no cost ("lifetime warranty") and they immediately emailed a part diagram of the whole Fontaine NF-VCTST-BNV-TSRVH Single Handle Pressure Balanced Tub and Shower Trim and Valve with Rain Showerhead (from the Monaco Series).
Larry
Jan 29, 2009 | Fontaine NF-VCTST-BNV-TSRVH Brushed Nickel...
Plumbing Logo
375 people viewed this question
Top Plumbing Experts
Andrew Bugbee
Tom Chichester
Gil Shultz
Are you a Plumbing Expert? Answer questions, earn points and help others
