Question about Admiral Washing Machines
HOW TO REMOVE LINT FILTER ADMIRAL WASHER TOP LOADER
PLASTIC COVER WILL NOT COME OFF?
  • 105 Answers
SOURCE: Crosley CAWC529JQ1 top load washer LEAVES LINT ON CLOTHING
try washing on a shorter time as this washer may have too good of wash action and the lint is fabric coming off your clothing
add more soap powder and do not buy the cheapest soap as the soap is important in the washing cycle of your machine
towels that are not too soiled brobably need 6 minutes at most on wash
if this machine has a delicate wash cycle use that for tee shirts etc
water pressure is important in rinse cycles
do you have high pressure and water only trickles in check water inlets on back of machine where the hoses screw on
good luck
Posted on Mar 16, 2008
SOURCE: can't find Lint filter on a Whirlpool 8255e super capacity Plus Washer commercial quality top loader,
The Topload whirlpools are designed to take the lint out by reversing the water to drain out.any lint should be drained out.
Posted on Nov 01, 2008
  • 28 Answers
SOURCE: Whirlpool top-loader LSQ9200LQ0
Im no expert, just pretty handy with all things mechanical...hope this helps:
http://www.appliance-parts-warehouse.com/whirlpool-parts/Whirlpool-Washing-Machine-Parts/Whirlpool-Parts-LSQ9200LQ0/Whirlpool-Parts-82574.cfm
Posted on Jan 26, 2009
SOURCE: Cannot find lint filter in washing machine. Is there one?
I called Home Depot where I purchased the washing machine and they told me newer washers do not have filters any longer.
Thanks for your response.
Posted on Apr 16, 2009
SOURCE: remove lint holder on ge front loader dryer
I have the exact same problem. I am amazed at had been the engineering is for such a simple process. The user guide just says to clean the lint filter. Even when doing so, there is still an excessive build up of lint beyond reach. There are no instructions that mention how to clean this part. It is obvious that GE did not test this part of the machine.
Posted on Jun 07, 2009
Admiral washer atw4470tq0 lint issues on clothes
clean the lint filter in the machine
remove any tissues and papers from pockets before washing
Nov 07, 2017 | Admiral Washing Machines
Where is the lint filter on a Simpson Eziset 950 top loader washer?
lint filters for simpons top loader is at the bottom of the center lift out piece in the agitator
just pull the lot up and the lint filter is a small pocket at the end of it
Dec 10, 2015 | Simpson Washing Machines
Our front end loader stinks and we have to leave the door open. We have the exact same problem where I work. How do you get the smell out?
The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the hose you see. The white filter cover is right in front. Get yourself a bunch of towels or a good big plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully.
Next: You can use Affresh to clean your front loader. Deposits of soap and other such things can be stuck around the inside tub of your washer. Try this product, it works great on all front loaders. Use hot water with the Affresh pellet with no clothes and run the machine through a cycle. Also helps with any stagnant water smells. Have you cleaned out your pump lately. Put the pellet inside the machine, not in the soap dispenser.
Pl give me a good rating for the free help, thanks.
May 21, 2010 | Kenmore 44042 Front Load Washer
Where is the lint trap on the front loader
There is no lint trap. There is a coin catcher on the pump. The design of the wash action on a front loader is such there is less lint than on standard machines. One of the bennies of the design.
Eric
May 20, 2010 | Kenmore Elite 45986 Front Load Washer
The washer will not wash all
Brand of washer, model; front-loader? You can try this:
FO2 is the code for long drain. The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the drain pipe you see. The white filter cover is right in front. Get yourself a plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully. Check your pump too, comes after the filter.
Apr 11, 2009 | Washing Machines
I have a front loader whirlpool duet #ghw9100lw2
The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the drain pipe you see. The white filter cover is right in front. Get yourself a good plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully. Check your pump too, comes after the filter.
Apr 08, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer not spinning
Plug off the mains. The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the drain pipe you see. The white filter cover is right in front. Get yourself a good plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully. Check your pump too.
First check your kitchen drain (or wherever your washer is installed)by pouring a good amount of water into it, to see if it is clear. Try snaking it out.
Apr 06, 2009 | Washing Machines
IT IS AFROUNT END LOADER THAT WILL WASH GREAT BUT
The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the drain pipe you see. The white filter cover is right in front. Get yourself a bunch of towels, a good big plastic bag or a wet vac to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully. Pl post back as to how it went.
Apr 01, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washing machine
The filter on your pump is probably clogged with lint and other stuff. Lift washer up a bit. You have to remove the bottom front panel, 3 screws. The panel will drop and come off. Drain off excess water from the drain pipe you see. The white filter cover is right in front. Get yourself a bunch of towels or a good big plastic bag to collect water or a wet vac. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in.
Nov 27, 2007 | Whirlpool GHW9150 Front Load Washer
Washing Machines Logo
124 people viewed this question
Top Admiral Washing Machines Experts
Dan Webster
Dan Webster
Sal De
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
