Question about KitchenAid 24 in. KUDI01TJ - Multiple Color Built-in Dishwasher
No power We had a power outage. When it cam back on it shutdown again. The dishwasher was on when this happened.
Dishwasher does not start
I had this problem and solved it by merely switching the associated circuit breaker off and on again. Something of a "hard reboot." Annoying ... and ... if it happens repeatedly (tonight was the first time), someting I will pursue fixing while hte d/w is still under warrwentey (It was purchased/installed less than three months ago.)
Dec 12, 2012 | Kenmore 18" Built-In Dishwasher -...
ADP 8450 Since a power outage I am now unable to switch my dishwasher on. The light flashes and it makes some sound but then nothing happens.
If this happened after a power outage just turn off the breaker to the washer for 2 hours, this will reset the unit to factory settings.
Jan 17, 2011 | Whirlpool Dishwashers
After a power outage my dishwasher has a "Er" code. I downloaded the manual and it says nothing about that specific code. Please help! "Er" code GE Profile Dishwasher GSD4930X66WW
the er means error. you may have a damaged control from the power outage. try to turn the power off to the unit for 30 min then put it back on. see if it resets it.
Jan 10, 2011 | GE Dishwashers
Dishwasher won't power on.
We're having the same trouble. What eventually happened?
May 16, 2010 | Frigidaire 24 in. FDB1050REC Stainless...
Dishwasher not working after power outage
Occasionally there is an isolated GFCI circuit for the dishwasher. If you can validated with a voltage meter that the unit is actually getting power.
I used to always install an isolated GFCI circuit for each: microwave, dishwasher, refrigerator, and garbage disposal.
So that is what i would check first
Mar 14, 2010 | GE Dishwashers
Power outage. Dishwasher shutdown. Display 2h
just means you have to reset the time
Jul 26, 2009 | Dishwashers
Just had a power outage, dishwasher is dead
althought e breakers apear to be on physcally turning them off and then back on especcially after power flashes(the breaker might of partially tripped, and needs to be reset(possible)
Mar 16, 2008 | Frigidaire PLDB998A Built-in Dishwasher
No power to control panel after power surge
Try turning the curcuit breaker off for a few minutes. Turn it back on and see if it resets itself. If not, the outage may have shorted out the main control panel.
Sep 30, 2007 | Maytag MDB7100AWB Dishwasher
KitchenAid 24 in. KUDI01TJ - Multiple Color Built-in Dishwasher Logo
48 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
