Toshiba 5540c scan to email - Office Equipment & Supplies
  • ernie_avila
    ernie_avila Nov 28, 2012
    button grayed out to send scan to email
How can i remove error code c 448 in toshiba e studio 5540c
Step 1: Remove all the paper that is jammed in the machine. Follow the steps on the touch screen to locate the jammed paper.
Step 2: Turn off the copier with the power rocker switch on the right side.
Step 3: Hold down the 8 and 0 on the numeric keypad while turning the machine back on.
Step 4: Enter 400 on the numeric keypad and then press the Start (copy) button. As you type the 400 will show up in place of the D
Step 5: Enter 0 on the numeric keypad and then press the "Enter" button on the touch screen.
Step 6: Power down the machine with the same power rocker switch as in Step 2.
Step 7: Turn on the machine with the power rocker switch.
Dec 31, 2015 | Toshiba Office Equipment & Supplies
Toshiba e studio 307 not print or scan becouse need to enebler sofwere
U need:
Print kit ( u can print or scan via e-filing/file downloader, cant use the SCAN button)
Print/scan kit ( Scan button let u scan to fileshare, scan to email etc...)
Apr 21, 2015 | Toshiba Office Equipment & Supplies
How do I scan into my email
Scan to email needs to be configured on the copier. Afterwards, you can select scan and choose email to send.
Oct 02, 2014 | Toshiba E-Studio 250 All-In-One Laser...
How do i scan and email a document
Ther is scan to email function there but you have to configure first you email address and other settings on the copier..
Sep 25, 2014 | Toshiba E-Studio 356 Multifunction Copier
How do I clear scans that did not send to email?
Maybe the file is too large? You can check top access scan log for more details. You can log in to top access by entering copier IP address into web browser.
Aug 22, 2014 | Toshiba E-Studio 356 Multifunction Copier
How to configure scaner of my toshiba 353 ,to scan on my pc
In order to allow the e-353 to scan to eMail, and PC, you must have an enabler (Scan, or Scan and Print), either on will allow you utilize the scanning function through network(PC and copier must be in the same subset).
Or you can use the USB connection, just install the unity from the CD, or download it from Toshiba.com
http://business.toshiba.com/support/downloads.jsp?site=usa#Utilities
Choose the e-bridge full installer, burn the ISO image to a CD.
Nov 01, 2013 | Toshiba E-studio 353 Digital...
How do you add and delete users' emails for scanning
U can store all the users emails on address books. Then when u want to perform scan to email, just press the email button on the particular to add, re-press again to remove.
Jan 08, 2010 | Toshiba E-STUDIO 650 Copier
Scan to e-mail toshiba e-studio 205
Easy reply would be to make sure you have an email application installed on your computer such as Microsoft Outlook or Outlook Express. That will have to be setup first, and might require some information from you internet service provider. Many people think that if they have a personal email account such as Yahoo or Hotmail, that this will communicate with the scanner. The scanner program installed on your computer wants to transmit your scanned documents to an email program that is also installed on your computer. Otherwise, scan the document to your hard drive, and then attach it to a yahoo/hotmail email manually. Hope this helps clear things up.
Mar 25, 2009 | Toshiba Office Equipment & Supplies
Scan to email
Go into the administration mode. Select network settings. Change your outgoing or SMTP e-mail server to the new source you are using.
Jun 30, 2008 | Office Equipment & Supplies
235 people viewed this question
jasbo
jasbo
