Question about Vtech DS6151 Cordless Phone
Deregister cs-6629 handset - Vtech DS6151 Cordless Phone
    New Friend:
If your handset will not deregister, before registering it on a base. Here are the steps;
Menu/Select *7890#
It will display "Test Base" arrow up to "Test Handset"
Press Menu/Select It will display "SW Version"
Arrow up to "next page"
Menu/Select to display "Regstr Clear"
Menu/Select to display "Reg Clear?"
Menu/Select you should hear a beep.
Unplug battery and wait 10 seconds. Lug in battery and place phone in base to register it.
No other handset can be in use when you register new handsets.
Worked great for my 3 handsets that were registered to a base that went bad.
Posted on Sep 06, 2014
4 Suggested Answers
  • 8 Answers
SOURCE: vtech 6.0 deregister
do the same when you set up the phones ,find your phone menu and delete the hand set by there number
Posted on May 30, 2010
SOURCE: Vtech VT 2656 2.4GHz
Was looking for this for awhile as well, if you held onto them like I did the wait paid off, they must have put this up since I last looked.
http://www.vtechphones.com/vtechui/support/faq_problem.cfm?model_id=F0D43FC0-19FE-4ABD-BC22-C1306B1EC90A&type=problem&parent_id=133
Posted on Jan 02, 2010
SOURCE: I need to deregister all the handsets from the vtech i5867 base unit
My hand held still says "Searching for Base"???
Posted on Nov 08, 2010
Deregister AT&T SL82118 handset
The following is for the model ATT 5830.
Enter the following sequence on the base station including the * symbols.
**335782
This will deregister all handsets associated with that base station. Handsets can then be added back into the system by entering the base station ID into the handsets one by one. The base station ID is on the bottom of the base station itself.
Feb 06, 2014 | AT&T 5830 Cordless Phone
Deregister used panasonic handset without base
On another working handset do the following;
Menu #131
Scroll and select the handset you want to deregister
Confirm you want to deregister
"Deregister" screen will display and handset will be deregistered
Feb 15, 2012 | Panasonic KX-TGA650B 5.8GHz 2 Line...
I need to deregister a DS6101 without the base. I needed to replace the base and once we installed the new base, the extra handset that we had registered with our old base shows the following message...
Called the manufactuer.... To do this enter on the handset you want to deregister:
*331734# and press (Menu Key# 1 - top uppermost left button that is unmarked).
This will put the handset back into the register mode.
Hope this helps,
James Pavicic Jr
Feb 16, 2011 | Vtech DS6101 19 GHz Cordless Phone
Vtech 6.0 deregister
Getting startedReplace a handsetIf you want to replace a handset or reassign the designated handset numberof a registered handset, you must deregister all the handsets and thenindividually register each handset.To make deregistration easier, read all of the instructions on this page beforeyou begin. To deregister all handsets:Press and hold FIND HANDSET on the telephone base for about 101.seconds (until the IN USE light on the telephone base turns on and starts toflash), then release FIND HANDSET.Press and release FIND HANDSET again. You must press FIND HANDSET2.while the IN USE light is still flashing. The IN USE light flashes forapproximately seven seconds.All system handsets show CONNECTING... The deregistration process3.takes about 10 seconds to complete. All handsets show NOT REGISTEREDwhen the deregistration completes.If deregistration fails, you might need to reset the telephone and try again.To reset:1.Pick up the registered handset and then press talk/flash.Press OFF/CLEAR and place the handset back in the telephone base.2.-OR-1.Unplug the power from the telephone base, then plug it back in.You cannot deregister a handset if any system handset is in use.
May 29, 2010 | Vtech Cordless 6041 Phone
Remove parental lock on a mitsubishi CS-40503
model# cs-40503 default parental code is 6629
Nov 16, 2009 | Mitsubishi CS-40503 TV
I need to deregister missing handset #1
To de-register HANDSET #1:
1) Grab any working handset which is registered to your base (so HANDSET #2 or #3 in your case)
2) Press and hold the "END" + "#" key for 5+ seconds (wait for it to beep)
3) Choose the "Deregister HS" menu option
4) Pick HANDSET #1 as the handset ot de-register (since that's the "phantom" registered handset)
5) Once de-registered, you can de-register handsets #2 and #3 directly from each handset's "normal" menu interface (i.e. press "Menu", choose "Deregistration")
6) Thereafter, if you re-register your handset, they should start at HANDSET #1, then #2, and so on.
Aug 27, 2009 | Uniden TRU8866 Cordless Phone
NEED TO DEREGISTER LOST HANDSET
The "END" and "#" key combination can be used for several purposes:
1) If wanting to use an ALREADY REGISTERED HANDSET on an alternate base, and if if the INITIAL BASE isn't available to deregister the handset:
1a) Press "END" + "#" until it for 5+ seconds (wait for it to beep)
1b) Choose the "Base Unavailable" option
1c) That'll deregister the CURRENT HANDSET so that it can be re-registered on ANY base.
2) If a BASE has a handset registered to it which you no longer want registered but the registered handset is missing or broken:
2a) Grab another WORKING handset which is properly REGISTERED to the BASE in question
2b) Press and hold the "END" + "#" key for 5+ seconds (wait for it to beep)
2c) Choose the "Deregister HS" menu option
2d) Pick the REGISTERED HANDSET # to de-register. (Every other registered handset EXCEPT THE ONE YOU'RE ON will appear in the list!)
May 08, 2009 | Uniden TRU8866 Cordless Phone
How to set up uniden phone to base
If the handset has previously worked with the base - press the hangup button and the # key at the same time on the handset for five seconds and follow the prompts to deregister the handset. (System reset - deregister HS - which handset) It will tell you that the handset is deregistered. Then put the handset onto the base and it will register the handset.
Dec 14, 2008 | Uniden 5.8GHz Expandable Cordless Phone...
How to clear all registrations from the base
One has to completely deregister all handset by pressing end and # keys together till complete de registration is shown on handset screen. if the de registration is not done as above stated method the hand set will not register will show connecting on hand set screen.
Jul 16, 2008 | Uniden TRU8885-2 Cordless Phone
DeRegistering a Damaged Cordless Phone???!!!!
I have a Panasonic KX-TG6700 base unit and KX-TGA670B handsets. We had a similar problem where we were no longer able to deregister the handset using the handset itself. We wanted to be able to use that slot that the broken phone was still occupyng. The solution that we found in the manual online was to hold down the intercom button for 3 seconds until the "in use" light turned on. Then press and hold the number of the extension you want to deregister until it beeps. At this point the base unit has freed that extension.
Nov 05, 2007 | Panasonic KX-TGA600B Cordless Expansion...
Vtech DS6151  Cordless Phone Logo
397 people viewed this question
Top Vtech Lands Phones Experts
David Burbee
David Burbee
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
