Question about Treadmill Doctor Proform 5.2 Treadmill Drive Motor
How to test motor bearings on pro form 550s treadmill?
    Top Expert:
  • Treadmill Do... Master
  • 12,223 Answers
Please see my personal TIPS and fix it. However see the video .God bless you
Posted on Nov 27, 2012
Motor not coming on
Use a 9v battery to test your drive motor...if it turns...replace the controller provided the wiring harness is not damaged.
Dec 27, 2013 | Proform Pro-Form Power 995C Treadmill
Sudden Stoppage of my Treadmill
see the video and fix it. Lube too the rollers bearing front and rear+test the drive belt motor and replace if necessary. tight a little.
God bless you
Jun 15, 2013 | Proform Exercise & Fitness
Cybex 530t treadmill speed slows down intermittently anyone help
Please LUBE deck belt + rollers bearing too
2) test the input voltage motor, if there are the motor need repair.
3) test the output voltage board, for input voltage motor, if there are NOT the board is faulty.
God bless you
Dec 17, 2012 | Cybex 530T Pro Plus Treadmill
Pro form 550s only runs for 1/2 second and shuts itself off!
This happen because the LACK of LUBE , you must LUBE every 5 hours aprox from use. The design shut down the machine for protection electronic. Now lube.mAYBE YOU have a WORN deck belt and need replace.
2) LUBE the rollers bearing too.
3) Test the main motor bearing and replace if necessary.
God bless you
Nov 15, 2012 | Exercise & Fitness
Treadmill pro-form 705 not starting
All that I can think of is to check that the motor is getting power.
Sep 19, 2012 | Proform Pro - Form Treadmill 705 CST
Treadmill Problem
I believe that your must LUBE the deck belt firt, this happen when the lack of maintenance, shut down. Can be the deck worn.
2) LUBE the rollers bearing.
3) if the problem persist you must to test: input voltage motor, if there are the motor need REPAIR.
4) measure the output voltage board, for input voltage motor, if there are NOT the board is faulty. see the block.
However you must RUN the software calibration for diagnose, troubleshooting.
God bless you
Jul 25, 2012 | Exercise & Fitness
My pro form zt3 treadmill is making a noise whenever it's running...I've looked under the hood, but I don't know what's causing that noise.
Dear Sir:Please Lube THE machine in according with the instruction manual maintenance, May be you have a worn Decknad replace it.2) Test the rollers bearing and lube front and rear 3) Test the main motor for bearing Lube 4) Drive belt test and replace if necessary.
sincerely. God bless you
May 03, 2012 | Exercise & Fitness
My pro-form crosswalk 397 the track will not work. The lights display and it makes a sound but the track stays in place. I bought this on Black Friday and have only used it 3 times. Help!
INMEDIATELY LUBE the deck belt, maybe is WORN. and adjust the roller bearing see the diagram attached.
2) Test the input voltage motor, if there are the motor need repair.
3) Test the output voltage board, for input voltage motor, if there are NOT voltage the board is faulty.
Apr 23, 2012 | Proform Crosswalk 397 Treadmill
Ifit treadmill will not incline but everything else works, how do I fix the incline
You may need to calibrate the incline. Do this with the following procedure.
Safety key out
press the stop and speed up buttons at the same time while inserting the safety key. (you are now in diagnostics)
press the stop button one time only.
now press the incline up button (incline motor should start moving up)
incline will go up to the top and then all the way to the bottom. when it gets done you can remove the key. Reinsert the key and you should be operating normally.
Good luck Tim
Nov 23, 2009 | Proform Quick Burn Pro Treadmill with 12...
I have a proform xp 550s treadmill. The belt
change drive belt proform xp 550s treadmill
Aug 26, 2009 | Exercise & Fitness
Treadmill Doctor Proform 5.2 Treadmill Drive Motor Logo
657 people viewed this question
Top Treadmill Doctor Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Electro Med Services...
fordexpert
Are you a Treadmill Doctor Exercise and Fitnes Expert? Answer questions, earn points and help others
