Question about Amana Easy Reach AFD2535DE Bottom Freezer Refrigerator
No water comes automatically to the ice maker
After four years of trouble free use, no water is now coming to my ice maker (model IC6 in my Amana Fridge, model TX18VW). The amount of water that made it to the ice maker lessened over a period of 10 days or so, and now there's nothing. I checked the water line and vacuumed everything clean. I also poked an insulated wire in the holes marked L & V and water came into the ice maker. But obviously, I don't want to manually do that everytime I want ice. Any advice? Thanks a lot for your help.
    Scholar:
  • 58 Answers
What you need is a new ice maker the front gear is not engaging the contacts, you can buy the front module only ( what u put the wire in to on the l & v contact ) but a whole new ice maker assy is the same price.
Posted on Jan 10, 2009
NO ICE FROM ICE MAKER
You have a bad water valve or the fill tube where the water comes into the ice maker is frozen full of ice. Check the second problem first then if the fill tube is clear the valve needs to be replaced.
Apr 25, 2012 | Amana Refrigerators
Ice cube from icemaker have recently had a bad taste. Filter to service? Amana Mod BG20T2W Ice maker IC6
Bad taste or odor from ice cubes most likely a filter problem. If filter has not been changed for at least 6 months, that is where I would start.
Apr 01, 2010 | Refrigerators
Outside ice despenser is dripping, no ice
water dispenser -Your water inlet valve on the back where the water supply comes in is probably leaking. disconnect the water line coming out of it and see if you have a slow drip. Try the dispenser to see if it's just drips after use.
ice maker - If it overfills and drips, look for an adjustment behind the plastic endcover with a +/- on it. - is less water.
If it continuously drips, replace the water inlet valve on the back where the house water supply comes in.
Sep 30, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Water leak from ice maker
The fill line internal to the freezer is likely frozen up from the elbow inward.. When the icemaker calls for fill...pressure builds up on the plastic tubing causing it to pop out of the elbow. Check the tube inside the freezer by removing icemaker and running a long thin screwdriver or a rigid wire up into the tube until you feel ice or the plastic elbow outside.
Clear ice, if present, by squeezing hot water in from freezer side with turkey baster until cleared and water comes out back.
Aug 21, 2009 | Amana Refrigerators
Amana ic6 ice maker
sounds like your ice maker is working properly and that maybe you pinched the water line when you reinstalled it back into the elbow.. is the elbow clear of any ice build up or foreighn matter that would restrict the flow of water into the ice mold tray? If so..that's your problem.. ( thaw it out or melt it and then you should be OK) Hope that helps..
Aug 18, 2008 | Amana Easy Reach AFD2535DE Bottom Freezer...
I have a AMA IC6 ice maker and the ice is stuck together form water running over into the catch tray.i have removed the ice maker and let it thaw then reinstalled and the same thing happened. any...
Having problemAMA IC6 Icemaker. Water leaking into tray as it is making cubes causing previous cubes to freeze together and to the bottom of the container. Trying to defrost to see if that helps. Any suggestions appreciated.
Jun 09, 2008 | Amana Refrigerators
IC6 ice maker
No, completly deforst the freezer for 24hrs this will resolve the problem, i know its frost free, but still try to defrost this usaully resolves this fault Regards Advisor
Aug 21, 2007 | Amana Easy Reach AFD2535DE Bottom Freezer...
Ice maker not working on Amana Side by Side refrigerator
On most Amana cabinets the water supply for the water and ice are from two solenoid valves. The water coming in goes to a double water solenoid valve splitting the incoming water so the fact there is water coming through as chilled water is not verifying that there is water supply for the ice maker. If technically minded you could locate this valve (normally at the back rhs ; compressor section) and try switching the supplies to check the solenoid valve. If you have water coming through then it may well be the icemaker module not asking for the water supply. As the simplest first step I would try defrosting the whole machine overnight and see if there is an improvement. I do know that checking the module is time expensive and would really need to be done by an engineer or alternatively replace this item. Hope this is of some help.
May 07, 2007 | Amana ASD2622HR Side by Side Refrigerator
NO ICE - IC6
George, the ice maker will cycle about every 2.5 hours. Sometimes it takes a couple cycles to prime the lines. You can remove the white cover of the ice maker. On the module you will see two ports, one marked L and another marked V on the left side. Take a insulated jumper wire and jump these two terminals. You are now sending 120V to the valve. See if the water starts coming in. Also make sure the bailing arm is down. Catriver...post back.
Nov 05, 2006 | Amana Easy Reach AFD2535DE Bottom Freezer...
Ice maker freezing up
If it is only the fill tube that is freezing up, or getting full of ice, than your water valve is leaking (letting drops of water thru to your ice maker and filling the icemaker fill tube up and freezing). If this is the case, replace the dual water valve (part # 1071263) located in the back of the refrigerator, just follow the water line from your wall into the refrigerator. Make sure you turn off the water to the refrigerator and also unplug it. The dual water valve is the one that has two water lines, one going to the icemaker and one going to the water dispenser. On this model, I think you only have one water valve. On some you have two, the primary water valve and a secondary water valve (the dual valve). If this is your case, I would highly recommend you replace both. As far as the Refrigerator side freezing things up, I think that is a whole different issue. Please post back.
Oct 16, 2006 | Amana Easy Reach AFD2535DE Bottom Freezer...
Amana Easy Reach AFD2535DE Bottom Freezer Refrigerator Logo
318 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
