Question about Panasonic Viera TCP50ST30 50 3D HDTV Plasma TV
Ipad2 with dr05-ipa 5 in 1 kit do not work on my hd tv help?
Plugging my ipad2 with dr05-ipa on my tv with an A/V cable
My ipad air model1475 its got the first owners apple ID.what do I do?
you can restore it using itunes. basically your deleting everything and installing new IOS.
Jun 22, 2014 | BestOfferBuy Multifunctional iPad...
My Comcast remote quit working with the cable box. The guide wont come up any more and my hd doesn't look like hd....just standard. I went to look in the back and I thought I had hd but I only have coax....
You need an hd cable between your cable box and tv. They don't provide them for free. Once you plug in your hdmi cable to the tv, change its input to the hdmi port you just plugged into. The guide is updated by the cable system on their internet but over the coax. Give it time, it should come back. If not, reset the cable box by unplugging itfrom the wall power, wait 5 seconds, plug it back in. It should come back.
Sep 02, 2017 | Televison & Video
Not work on ipad
I am unable to zoom in and out, there is a very tiny increase in size when I tap the screen but I have low vision and always need zoom, all settings are in order for soom
Sep 25, 2013 | BestOfferBuy Multifunctional iPad...
USB not recognized
most likelly is the tv that does not support the ipad. try connecting it to a different tv with higher resolution.
Feb 22, 2012 | Sylvania LC320SS8 32 in. LCD Television
Keeps blowing the plug fuse and/or triping the circuit breaker when plug in? Been working fine for 5 years until now
That must be the mains cable or the filter box as it enters the TV.
The TV is fused internally so suspect the supply cable or mains filter capacirors.
Hope that helps.
Dec 10, 2010 | Hitachi 32PD5200 32 in. HD-Ready Plasma...
Connecting my new DVR
i dont know what kind of dvr you have, but mine has component terminals to plug my cable box in, and out plugs that go to the tv.
Dec 31, 2009 | Audio Players & Recorders
Toshiba 52 inch TV turns on then blacks out.
Unplug the power to the TV and HD cable box, wait 5 min. Plug TV and HD cable box back in.Everything is working like new. Go figure.
Sep 29, 2009 | Toshiba Televison & Video
When i connect psp to tv(hd) the screen apears red. Pls help.
It sounds like either the cables are reversed, loose, or possibly bad. This is what happens when a cable connection is not "solid". Please make sure all the cables are attached securely and in the correct order, if they are you may need to replace the cable. If it still happens with a new cable, it is probably the input on your TV that has an issue.
Aug 30, 2009 | Sony PlayStation Portable (PSP) Slim...
HD cable question
It sounds like you dont have the right HD box. When connecting HD you will use an HDMI cable or a component cable consisting of 5 cable total 3 for video two for audio. Coax cable is not used to connect HD to your TV / Monitor.
Mar 27, 2008 | Televison & Video
Panasonic Viera TCP50ST30 50 3D HDTV Plasma TV Logo
116 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
