My sunbeam large room ceramic heater just stopped working, I havent even had it for 2 months what can I do
It at first would start cutting off, and now it wont even turn on, what can I do to fix this I can not afford another one and the store wont let me return it for a new one. please help if you can
  • 84 Answers
Can't you exchange it at the store where you bought it and get a different one? It certainly shouldn't stop working after only two months of use.
Posted on Nov 27, 2012
Buffalo12980
  • 625 Answers
SOURCE: Can someone please tell me what is the lowest temperature setting a Fahrenheat 3000 Watt Large Room Fan-Forced Wall Heater Model FZL3004 will turn on at ?
about the only way I can figure is to let the room get very cool and adjust the thermostat to its lowest setting. now turn on the unit. monitor the heat until the stat just opens. the thermostat bimetal will be closed and will open when the bimetal expands and opens its contacts. another way is to hitch up a chart recorder to measure temperature with its output connected to the heater. [too expensive for you or the DIY to accomplish]
Posted on Dec 14, 2007
Buffalo12980
  • 625 Answers
SOURCE: Mr. Heater Buddy Portable Problems...
ok, your unit must be propane. look on the back where the propane line feeds the nozzle. there should be a very small copper line with two spade connectors on it. this is your millivolt generator line. with a flame at the nozzle the generator makes a very small electrical current which feeds to the main valve and keeps it open. take a piece of wire and jumper these two spade connections together and try lighting the unit again. if it stays on, the hi limit is shot. you can get by with the connections jumped out, you just don't have the safety margin if it were connected. IF with the spade connections jumped out the unit still shuts off, the generator tube needs to be changed.
Posted on Dec 26, 2007
SOURCE: Rinnai freestanding Royale ETR flame fire (mains
I had the same problem with this unit and had the heater serviced which fixed the problem. The problem is caused by the pilot flame not being big enough to keep the thermocouple hot, so the heater thinks the flame is out and it turns the gas off! The thermocouple is effectively a switch that is on when hot and off when cold. The pilot flame is supposed to keep it hot, so its on and the main burner will get gas. When its off (ie cold) gas is blocked from the main burner for safety reasons! This manual is for a very similar heater: http://www.rinnaisales.co.nz/tradesmart/rinnai2/pdfs/service_info/171.pdf
You need to get at the pilot and clean it out!
David
Posted on Jul 14, 2009
  • 10 Answers
SOURCE: lasko5840
The 5840 has a problem with dust getting on the heater element and turning itself off after 2 minutes running. HERE IS THE FIX. Unplug the unit from the AC outlet, Then using a can of dusting air ( the kind you use to clean a computer key board) aim the compressed air INTO the middle louver of the upper adjustable heater vent and blow out the dust that has gotten on the heater element. ( You are actually blowing into the unit, clearing off the lint/dust that has gotten on the backside of the heater element that you can not see without openning the entire case).You can see the front of the heater element inside the louvers, It's the shinny metal part that looks like a small radiator.It sits behind the middle louver. After blowing out the dust, shake the entire unit to allow the dust to settle to the bottom of the case. Using a vacum cleaner try to vacum out any dust from the LOWER FRONT intake. Once the dust has been blown OFF the heater element, the unit will work just as new and not shut itself down!
Posted on Oct 16, 2009
  • 36 Answers
SOURCE: Hi, Honeywell (HZ-341BL) Ceramic Heater stopped
when most ceramic room heaters stop working, the blower is clogged with lint and dust from floor use . get an air compressor, or a can of air. take unit outside using a small head philips driver remove screws while laying on an old sheet .disassemble cover carefully and blow dust away from you and clean blade without bending with a toothbrush in vinegar water not gettting any liquid on the electrical parts. reassemble. thanks karl
Posted on Dec 14, 2009
When heater works electric line trip off
You're drawing more amps than your line is equipped for. Rather than modifying your electric, unplug something on the same line to reduce the current draw.
Dec 18, 2012 | Sunbeam SCH2101UM Ceramic Electric Heater
I have a sunbeam SCH2101-UM Ceramic Electric Heater. How do I get it to rotate?
It doesn't Oscillate on it's own,but if you want to swivel the base up to 180 degrees, just grab the base and turn it.
Nov 19, 2010 | Sunbeam Heating & Cooling
Hi, Honeywell (HZ-341BL) Ceramic Heater stopped working. Can i get help
Dec 14, 2009 | Honeywell (HZ-341BL) Ceramic Heater
SUNBEAM WATER HEATER/COOLER WITH WATER FILTRATION BOOTLE
i am having the same problem and i lost the model number for it but can you please share the modle number if you have it because i call sunbeam and they need it so they can find it for me! thaky e mail @ hateandlove_1988@yahoo.com
May 23, 2009 | Whynter FX-6SB Free Standing Hot & Cold...
Heater shuts itself totaly off as soon as the room is warm
Difficult to guess what the problem might be due to the amount of electronics the unit has that could cause inconsistent or illogical functioning.
I noted one product review that said "if the room is too large the auto shutdown will engage".
I suggest you revisit the instruction manual and specifications before deciding whether to call a service engineer....
Sep 24, 2017 | Bionaire BCH-4138 Ceramic Compact Heater
Not enought heat
I have the same heater and it works great in my bedroom (with a door). the room is about 12 x 14. For my living room and dining area I use 2 or 3 oscillating, ceramic, fan forced heaters spaced out.
As you say, logically...since heat rises, the heat comes off the top. Only 3 things that I can think of would make that heater not work: First, a factory defect (it doesn't heat period). Second, if you have it a room that is too large for that size heater. Third, if the room has no doors (such as a living room).
If you have a draft it can work to your advantage. By placing the heater in line with the draft it will actually accelerate the heat exchange process and distribute the heat faster for you.
Dec 11, 2007 | Heating & Cooling
Heating & Cooling Logo
41 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
