Question about Toshiba 57H81 57" Rear Projection Television
Convergance Issue - Red bows inward on ends in Service Mode
I have replaced both stk392-110 chips and verified that all six resistors are still good but still unable to get a clear picture. When first replaced chips the picture was perfect after going through service mode and using touch focus. Then about a day in a half it started again with the red. Service mode would fix the issue then shortly after the red issue would come back until touch focus error would not let me correct it anymore. Need help as I don't know what I missed or need to do. Chips must be overheating but resistors are ok and I did use thermal paste with chips. I do have a question as to why the fuse resistors read 2.6 ohms when they are labeled as 1.8 ohm resistors. Resistors on board read 2.6 as well as new resistors. Please help as I really don't want to go out and buy a new tv right now.
  • Toshiba Master
  • 5,138 Answers
There is a good reason as to why you are having problems STKs110s most of the time they are no good even NEW!! Replace them with 180s.
Posted on Jan 10, 2009
  • Chris Sep 20, 2011
    I also replaced my convergence ics in my Toshiba 57h81 with 150s, worked for a minute... then after a few minutes, the red went back up a few inches from the bottom, everything else tested good.... any suggestions now?
The screen bows inward from top and bottom with a multicolor blurring around the edges it does this more often than not as of late. On top of this issue, white squiggle lines run horizontally on the screen...
hello,the convergance ic are the problem 2 large chips the sit a metal frame called heatsink usually located behind the tuner, also in front of the ic are some resistors these need to be tested and the capacitors at either end will need to be tested as well if you get an engineer to do it may cost about £300 to 450 pound if can do your self it could about 40 to 80 pound. you will need a good multimeter and good desoldering and soldering skill. hope you can get it fixed.
regards
shaun
Nov 29, 2010 | Televison & Video
Panasonic PT-47WXC43G green ONLY is bowed on bottom and top
It still convergence chip problem, check big resistors nearby these chips that would be open or devalued and causing problem, specially in green convergence area, your green tube/ gun is just fine and just not getting convergence output signal to show correct image.
I would suggest to download service manual copy of this tv for small fee from any website and fix the issue with schematics help.
Thanks.
May 02, 2010 | Panasonic PT-47WXC43 47" Rear Projection...
Samsung SP42W4PHX convergance problem
Hi
The resistors are 39 ohms, metal oxide.
Usually both the stk392-010 ic`s (on heatsinks )
want swapping. You can get them off ebay..
Dave H.
Jan 17, 2009 | Toshiba 53H71 53 in. Rear Projection...
Convergence issue
Solution:
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kit for your exact model. The kit inlcludes a photo instruction guide, original Sanyo STK chips, convergence resistors, pico fuses, etc. Everything you need to fix it yourself. Its an easy fix.
Jan 06, 2009 | Sony KP-57WS510 57" Rear Projection HDTV
Red convergance
You will need to replace both convergence ICs they are STK392-110 and you will also need four 6.8 ohm 1watt resistor. You can get replacement ICs and resistors at the following link with free installation instructions.
http://servicemanuals.vstore.ca/
Sep 21, 2008 | Philips 43P8341 43" Rear Projection...
KP-46WT510 - Red has shifted away from blue and green.
hi,
first replace the 2 convergence chips they are the big ones with heat sink atached,they start with stk letters and like six numbers,change'em with same ones you can buy'em at www.pacificsemi.com for cheap and original parts,friendly people,ok and that should fix problem,you won't need service manual,or you can get that too at www.asm-service-manual.com for cheap too,ok,let me know how was evething,your friend,faradio.
Mar 29, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
Convergance issue still exists
did you ever solve this?
v_incent_mills@hotmail.com
I have the same problem with mine.
Mar 21, 2008 | Toshiba 50H72 50" Rear Projection...
Convergance?
An STK IC chip = large,soldered in, requires chassis pull.
Replace both IC's for reliability,usually no major alignment
after repair. Sometimes, a resistor or two burns or changes value
This repair usually done by skilled technician.................T.
Dec 15, 2007 | Samsung HCL473W 47" Rear Projection...
Convergance/bowing
most like tes thats all your going to have to replace + the silicon as if you dont thet wil not last as long as they should. Also you may have blow fuseable resistors next to the ICs make sure you check them as well.
Aug 16, 2006 | Philips 9P6044C 60" Rear Projection...
Toshiba 57H81 57" Rear Projection Television Logo
63 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
