Question about Sony KDF-E42A10 42 in. LCD Television
No signal i have a 42 flat screen bravia tv was working just fine until i accidently push somthing setting down the remote now i get no signal on screen and alot of snow no picture or sound any suggestions i have had for three monthes no problem
  • 133 Answers
You have to take the remote, find the input button, push the input button untill your picture comes back, you should see the input go from cable/antenna, to vid 1--vid2---vid3---if pushing the button a couple of times dont change it, you will have to hit the input button, then arrow down, and select the nexy one, do that untill you find the picture
Posted on Jan 10, 2009
Turn demo mode off on Sony Bravia TV 40"
Here'show to turn off the demo mode,
Power ON the television
(Use remote Commander)
1.Select "TV" mode (not AV, demo mode can't switch offwhen you are in AV)
2. Press the "home" button on the remote.
3. Select "settings"
4. Select "set up"
5. Scroll down to "factory setting" and restore them.
6. When it asks home or shop display select "home".
Feb 14, 2011 | Sony BRAVIA KDL-40S2010 40 in. LCD...
My tv doesnt respond to the remote any more. I fitted new batteries but nothing - not even to stich it off> TV works fine from the on set controls
Testing remote control:
The remote control puts out IR (InfraRed) signal that human eyes cannot see, to find out if the remote is sending out the signal or not you just point the remote at the digital camera's Lens (Digital Camera can detect IR), you should see flashing light on the camera's screen when any one of the remote button is pushed. If you do see the flashing on the camera, then the problem is in the TV IR receiver or the main logic board; more troubleshooting with scope will be needed to look at the signals.
Parts: www.shopjimmy.com
www.remotes.com
Oct 21, 2010 | Philips 42PFL7403D/27 42 in. LCD TV
Sony Bravia No signal plus flickering image and
You know how to reset the tv to its factory setting, I think you are a technician. Second thing you can do is software update. Go to http://esupport.sony.com/US/perl/swu-list.pl?mdl=KDL42V4100&LOC=3#div_pos_30 . If it doesn’t work. Replace the Main board (UB board). Part # A-1547-086-A Cost approx $320.
Knowledge obtain from: Repair experience on same symptom.
Parts reference: Andrews electronics, 800 289 0300.
Apr 18, 2010 | Sony Bravia KDL-42V4100 42 in. LCD TV
TV says lost signal and turns itself off
Unplug the TV from Wall, wait a bit and plug back in. Should be reset.
Feb 09, 2010 | Vizio L42HDTV 42 in. LCD Television
Charter MOXI Remote doesn't work with Sony Bravia 42'' Flat Screen
Hold down the moxi and ok button until the remote flashes twice,then enter 9910. The remote will then blink twice again.Then go back and fourth pressing the mute button and the up arrow key(the one above the ok button)this will go thru all the codes,when your tv finally mutes,press ok that means you found the correct code.Hope this helps
Mar 26, 2009 | Sony Televison & Video
My 42 inch Haier Plasma has a no signal on screen it's only a year old can someone help I bought a new remote and that did not help ?
i had the same problem and i bought the new remote control and it did work at first i thought it was going to do the same thing but then i pushed the tv/use button and it worked perfectly.
Mar 13, 2009 | Haier HP42BB 42 in. Plasma TV
Blue screen - no signal - turns off [visio tv L42hdtv10a]
With out turning on the T.V., Push the [Input] button on the remote control. The TV should turn on and activate the input menu, just continue to push [Input] until it is set on TV (or HDMI, etc.). this should solve your problem.
Oct 29, 2008 | Vizio GV42L 42 in. LCD Television
HDMI-No signal input
Turning the power off shouldn't have caused the problem.
Make sure the TV is set to the correct HDMI (1 or 2) by pressing AV on the remote and moving up and down the list.
Check the laptop is set to output through the HDMI socket.
Right click on the desktop -----> properties ----> settings
Actual options depend on your graphics card.
Jan 02, 2008 | Philips 42PFL5332D 42 in. LCD Television
T.v. will not stay on
Power on your TV and press the INPUT button on the side of the TV repeatedly and rapidly until you can change it to a different input, such as AV.
If this does not work. Try this: With the TV off, press and hold the input button on the side of the TV for about 5 seconds. The TV should power on and the input list will appear. Let me know if either of these work.
Nov 14, 2007 | Vizio P2 42 in. HD-Ready Plasma Television
Sony KDF-E42A10 42 in. LCD Television Logo
182 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
