Question about Marantz Audio Players & Recorders
Marantz NR 1403 & Preamp - Volume cannot be controlled by receiver
I recently hooked up a Audiophile TC-750LC phono preamp to my Marantz NR1403 receiver. I plugged it into the pre out ports and played a vinyl. The sound only comes out of the speakers and the subwoofer does not kick on. I am also unable to control the volume through the receiver - I'm forced to use the volume control on the preamp. Any thoughts?
  • Brian V Nov 27, 2012
    Thanks for the reply. I was able to resolve this by plugging the preamp into the receiver's CD inputs. I then set the preamp volume to about 15 out of 20 and then cranked the reciver volume to a little above average to get some solid tone.
    Sergeant:
  • 344 Answers
The newer surround sound recievers will not work no matter what you try with them the way you have it hool up, they are not design to be useing a turn table on them that has a mgnetic cartridge ,Evan if you buy a phono preamp for it, you are just wasteing your time end money, I was a electronic tech for over 40 years ,Before i retired this summer, End no lots of people who tried to do the same thing your trying to do ,End It would not work,
Posted on Nov 27, 2012
robotek
  • 1512 Answers
SOURCE: I have Marantz tuner &
Hi Andrew49
If all the amps are going into protection mode, then the preamp may be pushing a DC component with the signal. This is a little serious,and should be investigated further. There may be some deterioration in the electronics of the preamp causing this. I would suspect a leaky transistor or bypass/coupling capacitor in the DC coupled output stages. should not be too hard fix for a good HiFi tech.
I am more than happy to answer any other questions you may have about it, please get back to me here, or use the ASK function to go straight to me :) If you are still unsure, have problems, or we need to look at the situation more deeply, then before you give a rating for this advice, hit the ASK button Thanks for using FixYa, If you consider the advice I have given you as sound, a FixYa rating is a great reward for my efforts to help you. Cheers.
regards
robotek
Posted on Jul 13, 2008
robotek
  • 1512 Answers
SOURCE: Marantz AC 500U
Hi
Sorry for the delay in getting back to you, you have an odd problem happening there, the pre-amp being the common denominator to the syptoms. Perhaps you could try reducing the attenuators to say 60% and retry at the same levels you used to use at the preamp. It is unlikely that there is a fault occurring that would increase the output of the preamp, more likely to be a DC component getting through. It could also be possible that the amps if all the same make and model have through over the period of installation developed the same fault.
There will have to be a common contributor to the symptoms. It is not uncommon for the same problem to affect a particular model at the same point of its life. Best approach and easiest to fault find it would be to change out the preamp with something similer to test the system and see what happens. At least tyouy will know where to start looking. Hope I have been able to help you, still happy to discuss it further. In the Free section our only reward is a FixYa ratings. Cheers
robotek
Posted on Jul 24, 2008
  • 118 Answers
SOURCE: insignia stereo reciever inputs stopped working
check a button on the front labeled 'straight' or 'direct'
Posted on Nov 04, 2009
Grubhead
  • 5190 Answers
SOURCE: Selecting phono preamp for Onkyo HT-R510
The magnetic cartridge preamp should work with the turntable, as presumably it will have a magnetic cartridge in it. The only reason that the amp states "magnetic" is that some very old turntables have ceramic cartridges which should not be connected to that terminal. Even if the turntable had a "ceramic" it could be replaced with a magnetic one!
Posted on Mar 21, 2010
dunnbiker
  • 8546 Answers
SOURCE: I recently aquired a used rotel rx102 stereo
If the receiver doesn't have a function specifically named PHONO, yes. Very few AVR's have phono preamps. They're not expensive. I'd check eBay.
Posted on Jul 06, 2010
How can I connect a Thorens 145 turntable to it?
Your Harman Kardon AVR 85 doesn't have "phono" inputs. That means that you can not connect a turntable to it directly. You will need a "phono preamp" to amplify the very tiny signal from the phono cart enough for the HK receiver to play it. Something like this:
PYLE PRO PP444 Ultra Compact Phono Turntable Preamp
will do it. There are certainly better ones, like:
Amazon com TCC TC 750 BLACK Audiophile Phono Preamp Pre amp Preamplifier...
Feb 23, 2016 | Harman Kardon AVR 85
Carver TFM 35 amp what is the best way to hook it to a Marantz AV8003 pre app
No. You should use the line(or preamp output) to the Carver input. The only way you could use the tape output is if the Carver has input volume controls.
Dec 21, 2014 | Marantz Audio Players & Recorders
Marantz nr1402 how to connect turntable
Connect turntable out to phono preamp In
Conect Phono preamp out to your Marantz NR1402 vacant analog input.
On your TV , if audio out is available connect it also on the Marantz
vacant analog input 2
Aug 01, 2012 | Marantz Nr1402 Av Receiver
How do i attatch preamp to marantz sr9200 for phono
If you are talking about a phono preamp, take the output rca cables from the turntable, "red and white" plug it into the preamp input, "labled" next take a red and white cable wire male ends, "3 to 6" feet long, and plug the one end in the output of the preamp, "labled" and finally plug the remainder into the AUX input of the Marantz receiver matching the colour codes so the left and right channels don't get mixed up, you now should be good to go.
Apr 15, 2012 | Marantz Audio Players & Recorders
I have a Technics Quartz SL-10 Direct Drive Automatic turntable and I need a pre-amp to drive it through a JVC RX-6012VSL Audio Control System.....preferably a Technics pre-amp.
Technics Preamps on eBay:
http://shop.ebay.com/i.html?_nkw=preamp+technics&_sacat=0&_odkw=preamp+technics&_osacat=0&_trksid=p3286.c0.m270.l1313&_rdc=1
There are, of course, many non-Technics PHONO preamps out there.
http://shop.ebay.com/?_from=R40&_trksid=p3984.m570.l1311&_nkw=phono+preamp&_sacat=See-All-Categories
If you already have the central receiver and amplification part nailed down you really only need a Phono Preamp to boost and shape the output of the Phono Cartridge. Otherwise you're paying for source switching, volume and tones controls you don't need.
Mar 03, 2011 | Technics SL-DZ1200 Turntable
How do I hook up a home theater system to my sansui record player? DO I need any special hook up? Where is the volume controlled?
Some make and model numbers would have helped.
A traditional turntable requires a preamp inline with it to PRE amplify and frequency-balance (*) the minute signal produced by it's cartridge. Most stereo receivers and preamps have Phono connections and internal preamplification strictly for that purpose. Lacking a Phono Preamp you will have unusuable very low, tinny sound.
* Google "riaa equalization" for some background
Some of the newer turntables come with selectable internal preamplification to solve the lack of it in modern equipment.
Volume is always handled at the electronics.
Jan 30, 2011 | Audio Players & Recorders
I recently aquired a used rotel rx102 stereo receiver and onkyo cp101 A turntable. I bought a new stylus needle for my turntable, and plugged the turntable into the phono jacks on the receiver and from...
Jul 05, 2010 | Nakamichi AV-7 Receiver
I have a phono preamp hooked up to my Yamaha receiver for a turntable. My tall speaker tipped over and knicked the receiver and now my turntable will not produce any sound. Could this have blown the phon...
Let's figure out which hardware is failing. Connect the phono preamp to the CD or tuner input to see if it works there. It should. If it does, your receiver is at fault. Did the front panel controls get damaged?
How did the turntable fare in this accident? As a basic test of its ability to produce sound, hook it directly to the CD input and raise the volume slowly while playing an LP. If it's alive you'll hear a very weak, tinny sound, but I assume you know that or you wouldn't have a phono preamp in the first place and would probably be asking why the TT sounds so poor. :-)
Jan 19, 2010 | Audio Players & Recorders
Insignia stereo reciever inputs stopped working
Nov 02, 2009 | Insignia 200W Stereo Receiver
When I hook up the RCA cables from the Phono to minimal volume
PHONO requires a phono-equipped receiver, which the STR-DE598 appears to NOT be. AUX will not work because it requires Line Level inout. Traditional old-school turntables put out a very tiny drastically-altered signal which needs preamplification to raise it and flatten it out for use by downstream circuitry. THAT is the job of the PHONO section in a preamp or receiver. You need to find a phono preamp or an older receiver to run the TT through. You could slave it to the STR through its AUX then.
Apr 30, 2009 | Sony STR-DE598 Receiver
829 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
