Question about Craftsman Garden
Where do the wires connect on the ignition of a craftsman chain saw
Can't determine where the end of the wire goes on the ignition
    New Friend:
  • 22 Answers
Attaches to mounting screw securing to coil then to kill switch
Posted on Apr 28, 2014
tripletauto
  • 1450 Answers
SOURCE: how to determine chain size
the 16" has 54 links
this should be part number
McCULLOCH16" REPLACEMENT CHAINSAW CHAIN 91V-54
Posted on Oct 15, 2008
slohry
  • 87 Answers
SOURCE: Owners manual for Craftsman 20 in chain saw, needed
Parts manual, have model # available
http://www.searspartsdirect.com/partsdirect/index.action?sid=PSHx20080129x00001
Posted on Apr 09, 2009
dontbother10
  • 2220 Answers
SOURCE: Ryobi Elec Chain Saw ECS-2040
The number you provided don't cross to an exploded parts list.
The drawing can be found here:
Homelite/Ryobi.com
https://www.gardnerinc.com/recons/disclaimer-lg.php - Agree; Choose “Product Line”; “Select OEM” & “Select Catalog” both to “Homelite Consumer Products”. A drop down list appears; self explanatory from here.
I advise you find an authorized repair facility for your own safety. HTH
Lou
Posted on Sep 21, 2009
dontbother10
  • 2220 Answers
SOURCE: 16'' chain Saw wont fire
Ignition module gap
Place a business or index card between the fly wheel and coil, rotate until the magnetic attraction pulls everything tight together. Tighten the coil screws, rotate the flywheel until the attraction eases and remove the card. Ensure nothing contacts when flywheel is rotated.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Posted on May 02, 2010
Testimonial: "thats what I thought. thanks"
  • 4088 Answers
SOURCE: Poulan Pro Chain Saw Bar Chain Oiler Stopped Flowing
The filter can usually be caught with a hooked wire and drawn up far enough to deal with the filter. Oil filters are not prone to plugging unless the oil used is contaminated. If you run the engine without the bar and chain attached, oil should ooze out of the engine side port. If nothing, suspect problems with the oil pump. Some saws use a plastic gear in the pump and can strip the teeth of the gear. You should find it located behind the clutch assembly. Once you have oil flowing from the engine, clean the bar drive-end oil ports that go from the large holes out to the chain groove on each side. Finally, run the bar tip near some cardboard--it should throw off a thin line of oil. I have no idea what the plastic tube might be (a manual pumper perhaps?). Hope this helps!
Posted on May 23, 2010
How to replace a kill switch on a husky 288 xp
There should be only 1 screw and one wire connecting the kill switch. The kill switch simply grounds out the ignition. So it is difficult to install improperly. The wire coming from the switch goes directly to the ignition module.
Jun 21, 2014 | Husqvarna 288 Kill Switch Wire Chainsaw...
Wire diagram for craftsman 10" table saw
Hi there.
Prior to plug it try this.From your 3 prong grounded plug trace it up to your saw were you should have a black and a white from the same wire's end.Now the two whites are probably from the reset that you haven't replaced?Write back to let me know if this is right and I'll proceed.
Jul 25, 2013 | Craftsman 10" Table Saw
BROKEN SPARK PLUG IGNITION WIRE
If the lead is broken, depending on which saw it is, you can buy a replacement lead. Unscrew the wire from the ignition module and screw in the new one after you put the end and boot on it. If it doesn't unscrew then you will have to buy a new module
Nov 03, 2012 | Stihl Chain Saws, 017, 019, 021, 023 & 025
How to change the fuel line on a Craaftman 2.0 14
take the new hose trim it back to 1/3 of its the dia about a 1/2'' long feed a stiff wire threw the hole in the tank and out the gas cap opening slide the new hose over the wire and slide it back til the 1/3 end of the hose pops threw then remove the wire and pull the hose install the filter and pull threw into place cut to size and install on the carb
Aug 22, 2012 | Craftsman 2.0/14" Chain Saw Misc. Parts...
Electrical wire?
Because of the simplicity of the ignition system, there really is no diagram necessary. Husqvarna uses a simple two-wire harness in that unit (e.g., p/n 544 08 28-01) that has two female quick-connects at one end and one female quick-connect and a ring terminal at the other end.
The end with the ring connector is the magneto end. The female quick-connect there attaches to the magneto primary circuit control terminal, and the ring terminal there is secured under the head of one of the two magneto armature mounting screws.
The opposite end of the harness goes to the ON/OFF switch on the case side near the handle. This switch is a simple single-pole/single-throw switch that allows the engine to run when in its open position, and kills the engine when in its closed position. The engine shut-down occurs through the effective action of grounding the magneto control terminal to the magneto armature frame, as accomplished through the circuit through the ON/OFF switch when that switch is closed.
To identify the armature, harness and switch for your saw, go to the Husqvarna Manuals Download Page for your saw, identify the list by the build date of your saw, and download the desired list. (I like the 2009-02 version as it has the sections identified and bookmarked, but be sure you ID the correct parts for your saw. It might help to DL your manual as well as the 2009-02 version for reference purposes.)
The armature and harness will be found on the Ignition / Flywheel page (items 7 & 8, respectively), and the switch will be found on the Air Filter / Intake / Carb and Air Purge / On-Off Switch pages, as item 9 (e.g., p/n 504 00 34-01, includes retainer bail).
If you are getting no spark from the plug wire when cranking the engine with the ON/OFF switch in its ON position, the problem must be in one of three places -- the magneto or its mounting, the harness, or the switch. A short between the magneto control terminal and the magneto armature will kill the spark, as will any short between the two wires in the harness. Similarly, an ON/OFF switch that fails to open (internally) will have the same effect as leaving the switch set to its OFF position.
If the engine will not stop when the ON/OFF switch is moved to its OFF position, an open magneto circuit is indicated. This can be due to a broken wire in the harness, a loose or corroded connection of the grounding (control) wire to the armature frame, a break in the magneto primary circuit to the control terminal, a loose or disconnected wire at the ON/OFF switch, or an ON/OFF switch that fails to close (internally).
While broken or shorted harness wires are easily repaired without replacement, any magneto or switch failures will usually require replacement of the failed component.
Jul 21, 2012 | Husqvarna 450 e-series 18" Chain Saw
No spark when trying to start
If there is no spark with a new plug and the earth cut out wire diss connected from the ignition switch, then it will require a new ignition unit part no. 530039143 ( if it is a Husqy 36/41 )
Feb 26, 2012 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
Husqvarna 40 Chain Saw The saw has been unused for about a year -- before that, always served well. I purchased fresh petrol and a new spark plug, cleaned air filter etc. The I noticed: no spark at all,...
The model 40 has a single piece electronic ignition, it cannot be repaired it will have to be replaced, before replacing, check the air gap between the flywheel and the ignition unit, this should be 0.3mm, also diss connect the earth cut out wire from the terminal on the unit and try for a spark again, this will rule out any fault with the wire or the switch, the ignition works off speed of rotation so you will have to crank the start as if you were starting the machine.
May 13, 2011 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
Chain saw has no spark
If it has no spark there are only a few that will cause this, firstly dissconnect the wire from the ignition switch, try again for a spark, if no spark, remove the starter cover, now remove the cut out wire from the ignition unit terminal, try again for spark, if no spark, the ignition unit is bad and will require replacment.
Feb 14, 2011 | Craftsman sears 18" Chain Saw Chain (...
Stop switch
one end of the blue wire goes to the ignition coil and the other end goes to the stop switch.
Feb 22, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Garden Logo
35 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
