Question about Whirlpool 30" Self-Cleaning Freestanding Electric Range - White-on-White
When i set my whirlpool oven to self clean it flashes a e1 and f5. what does that mean?
  • Anonymous Feb 06, 2009
    when I set my whirlpool oven to self clean it flashes an e1 and f5. what does that mean?
    President:
  • 2,559 Answers
Error is fo the door lack switch.
Posted on Jan 10, 2009
I have a whirlpool accubake self cleaning oven.. when trying to use the self clean option it now states e1 f5 in the digital screen what do i do know?
Most commonly that is a runaway temperature error which usually means the temperature probe is bad and needs to be replaced. If you need more detailed instruction or help making this repair visit the link below:
Appliance Repair Help With Live Chat
Mar 26, 2017 | Whirlpool Ovens
Trying to clean my whirlpool oven. when it start button, an E1 - F5 comes up. What is this telling me.
What the F5-E1 error code means is that the door lock asm. is not operating so when its suppused to close and lock the door to self clean it cant do it since something is wrong with the latch/lock assambly
Some of the things that would need to be checked to see why the latch isn't working are;
the latch position switch,the latch itself to be good and opening/closing, & the part called the soloniod that is what operates the latch so it could open or close
GENE
Sep 18, 2011 | Whirlpool Ovens
Trying to selfclean oven and getting error code E1 F5. What does that mean?
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
Feb 20, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
We used the self clean setting and when it went off a e 1 and f5 came up and the door will not open
Hello & Welcome to FixYa
Error F5-E1 means bad door latch-switch assembly and replacing this part is recommended repair. Please get back to me if you have any other questions.
Kevin
Feb 10, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
Whirlpool Gold Self-Cleaning Oven Error Message: E1 F5. What does it mean and can I fix it?
E1-F5 means the self clean latch will not lock.
Try pressing down any key and hold for 1 minute, see if this clears it. If not you will most likely need the latch switch replacing.
Dec 20, 2010 | Ovens
Selfcleaning won't come on E1 F5 keeps flashing with a beep
Hi
Thanks for using FixYa. Error F5-E1 means that the door latch/switch has gone bad or is not operating. To resolve this issue check the door latch and replace if its not working. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 05, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Trying to get gas self clean/oven to start. Getting error E1 F5.
E1 F5 is bad door lock assembly. Only way to repair is to replace the locking assembly completly. Sorry. Hope this helps.
Mar 06, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Oven door locked E1 F5
hi..
The manual says F5 means "failed circuit in control". This means that the control panel is burned out.. So just replace this..
Thank u
rate me!!
Jul 25, 2009 | Kenmore Ovens
I used the self cleaning oven and now it wont unlock and it keeps beeping f5, e1 what does this mean and how can i unlock the oven?
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.&URTGF
Mar 27, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Self cleaning oven wont work
On your model it should mean a defective door latch switch.
It will have to be replaced.
Feb 22, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Whirlpool 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
237 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal De GO PATS
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
