Question about Sharp 27H-S60 TV
Tv sharp 27h-s60 valores de las resistencias marcadas ec chasis como r706 y r718
La tv no hbre la pantalla completa y necesito los valores de las resintencias marcadas en chasis como r706 y r718 graciaS.
  • 3 Answers
SOURCE: sharp model 27H-S60
on your remote that you bought there should be a button that says code search hold that button untill it lights up then press tv then put in the codes depneding on the model either it ahould automaticly put it in or press enter. Repeat untill it works
Posted on Oct 31, 2007
SOURCE: Sharp TV model 27H-S60 convergence
HI ,USE A PATTERN GENERATAR DOT OR LINES TYPE AND USE THE CONVERGANCE RINGS BEHIND THE YOKE OF THE SET ,THERE ARE THERE RINGS FOR EACH COLOUR RED GREEN AND RED .SLIGHTLY MOVE THE RINGS AND U CAN SE EIN THE PATTREN THE COCLOUS WHICH IS FRINGES EACH BY EACH U ADJUST ALL THERE RINGS FOR PERFECTION , FIRST LET THE SET BE SWITCHED ON FOR 1 HOUR AND THEN DO THE ADJUSTMENT. THANSKS
Posted on May 22, 2008
  • 4234 Answers
SOURCE: missing resistor
1.8 ohms at 2W
Dan
Posted on Sep 23, 2008
SOURCE: sharp 27H-S60 TV problem
I bought a replacement remote from ebay which controls video, changes channels, turns cc on and off etc...everything except turning the SAP off which is stuck on but I use my dvd player/vcr unit and change the channels thru it with no issues
Posted on Feb 27, 2009
SOURCE: necesito saber el numero de fly back de un sharp modelo 25f m50
f0008mezz
Posted on Oct 11, 2009
How do I get my aspire x3400 to work on my tv screen also
saludos usted debe ir a propiedades de pantalla en su pc y una ves all? pararse arriba del icono de pantalla secundaria y darle duplicas escritorio para q clone el escritorio y le salgan los iconos en las dos pantallas o simplemente elegir una de las dos pantallas y ponerla como principal para q la pc deje de usar la otra y le aparezca todo en la tv..
Jan 20, 2017 | Televison & Video
Necesito saver el valor de las resistencias R1013 y R1014 gracias
He needs schematic info about the values of the resistors, R1013 and R1014
I cant find a schematic for this amp. Anybody have one?
Sorry not a solution but might help.
Mar 19, 2011 | MTX Thunder 5-Channel Amplifier 895 Car...
Tengo un receiver denon avr1609 y quiero restaurar los valores de fabrica como puedo resetear
uno de los tres por debajo de las soluciones de trabajo para que el receptor
1. Para reiniciar el sistema, a su vez el receptor apagado por el peque?o bot?n on / off, no el bot?n de espera grande. Mientras que fuera de noche y pulse el bot?n directo puro, a la vez y sigue tomando con su mano derecha mientras presiona el peque?o bot?n on / off con la izquierda. Ver? el flash men? del receptor. Cuando lo ves flash dejar ir de la noche y botones de acceso directo puro y el receptor se reiniciar? si mismo a la estaci?n de radio 87.50.
2. Pulse el bot?n "Power" al mismo tiempo presionando el bot?n "Standard " y "Simulaci?n DSP" en el panel frontal de su receptor Denon. Estos botones tambi?n pueden estar ocultos debajo de un panel tir?n en funci?n del dise?o y el modelo de Denon que se utiliza. Algunos modelos de Denon requieren diferentes combinaciones de bot?n que se pulsa simult?neamente mientras se presiona el bot?n "Power", como el "Modo Surround" botones. Algunos modelos de receptor Denon no proporcionar? las instrucciones de restablecimiento en el manual del usuario, para encontrar las combinaciones de bot?n derecho debe ponerse en contacto Denon.
3. Pulse el bot?n "Power" para apagar el AVR-
Pulse el bot?n "Power" al mismo tiempo la tecla "altavoz A "y "Speaker B" botones. Espere a que el AVR-788 a la pantalla comenzar? a parpadear a una velocidad de alrededor de una vez por segundo.
Suelte los botones despu?s de la pantalla comienza a parpadear. El AVR-788 es ahora restablecer la configuraci?n predeterminada de f?brica.
Mar 15, 2011 | Denon AVR-1609 Receiver
Nececito el valor de la resistencia r5 ya que ésta se encuentra quemada y el teléfono no enciende gracias julio e-mail jucelfo@yahoo.com
necesito el valor de la resistencia r5 ya que ?sta se encuentra quemada y el tel?fono no enciende gracias flora e-mail: facy5@yahoo.es
Oct 07, 2010 | GE 26928GE1 Cordless Phone
Como puedo cambiarle la carcaza ami motorokr z6 yo misma? es q se le rompieron unas partes xq se m callo al piso, y ay q compre una carcaza nueva me gustaria saber si m pueden explicar como la puedo...
loba , tenes que conseguirte un destornillador especial, lo desatornillas de atras de la pantalla( la q sube). UNa vez que sacaste los tornillos, levantas la carcaza y la deslizas un poquito hacia abajo PERO NO LA RETIRES DEL TODO!!! porque la botonera esta unida al telefono. Con un destornillador plano desenchufa la botonera del telefono ( con cuidado) una vez que esta desenchufada ahi la podes retirar. Yo estoy haciendo lo mismo pero tuve q comprar la carcaza, los botones y el lente todo por separado , si la tenes completa solo tenes que enchufar la botonera al telefono , si no asegurate de tener todas las partes (el lente si lo sacas no se puede volver a poner) Espero que te sea de ayuda, a mi me resulto facil pero el problema es que ahora se me rompio la pantalla=( pero ya me fije como cambarla. Saludos.
Jun 12, 2010 | Motorola Mobility MOTOROKR Z6 Cell Phone
Fuente de poder
tv keiton modelo ktv.32l no prende
Jan 23, 2010 | Vizio L32 32 in. LCD HDTV
No enciende el tv y una resistencia no se el valor de ella
la resistencia es 112-1124 maxima los valores se depende al parte y numero de control tombien esta telivision tiene una marca de modlo por favor mandame los datos gracias,
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Apr 30, 2009 | Televison & Video
Ayuda
Sabes que pasa esta anulada porque quedo pegada la funcion de los ajuste en la pantalla.
Pero esa es la clave de la solucion.
Cuando estes viendo los valores esos que no conoces hay un comando en el control remoto que sirve para ajustar, o cambiar esos valores generalmente es (ADJ) pero en tu remoto no se cual es, fijate que debe haber una tecla que te haga salir de ese menu que es el que estas viendo.
Puede ser o la misma tecla MENU, o la tecla ENTER o la tecla de los canales < > o la del volumen, la que ajusta esos valores, y asi como hay una que los ajusta hay una que te saca de ahi.
Lo unico que tenes que hacer es tratar de salir de ese menu fijandote cual boton te saca.
Ese es todo el problema
Proba de nuevo
Cuando apretas la tecla de volumen
Oct 19, 2008 | Air Tools & Compressors
Help
Hola Ulises:
Los menus que te aparecen
Sharp 48=0(8)+u(40)
Brt 132=o(68)+u(64)
Cnt 84=o(6)+u(78)
Clr 60=o(8)+u(52)
Tnt 62=o(30)+u(32)
Son para calibrar a tu televisor, serian brillo, nitidez, contraste, color y tnt que es un ajuste para los televisores que son NTCS o sea los que se usan aca en EEUU.
Para sacar eso de tu pantalla, anda al frente de tu tv y presiona MENU y ahi lo sacas.
Tambien en ese menu, fijate que este la opcion CABLE seleccionada en vez de TV o AIR
Para conseguir eso tenes que luego de apretar menu, ir buscando las opciones que te digo y ver de que queden seteadas.
Sino tenes la tecla menu en tu tv.
Apreta tv en tu control remoto y luego MENU y hacelo desde ahi.
No te impacientes que lo vamos a resolver.
Hace lo que te digo primero y decime como te va y seguimos
Oct 19, 2008 | Tvone TV-207 Television
Televison & Video Logo
41 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
