Question about Asko D1706 Built-in Dishwasher
Not draining all the way
It drains but leaves about an inch of water. It has drained all the way in the past
  • 641 Answers
SOURCE: F2 error message flashes, cannot reset.
Try to find out from where water leaking from (pump or inlet valve). The leaking one, should be replaced. Good luck !
Posted on Jul 27, 2007
  • 351 Answers
SOURCE: ASKO 1475 Does not not pump out and drain at end of cycle.
If dishwasher drains ok into bucket then fault is with the house plumbing
Posted on Feb 29, 2008
dragonsthatk
  • 547 Answers
SOURCE: i am from Montreal quebec,
follow the drain hose to dishwasher it is attached to pump
Posted on Feb 19, 2009
  • 14 Answers
SOURCE: Water in drain pump for ASKO D5122XXL dishwasher
Yes, Asko dishwashers can leave a small amount of water in the sump after a cycle completes. At the beginning of most cycles the sump is pumped and new water added.
Posted on Jun 19, 2009
  • 145 Answers
SOURCE: drain pump runs continously
Sounds like you have a leak under the unit. There is a float in the bottom that turns the pump on when it has water in the lower pan. It won't let any water fill until it is dry.
Posted on Jul 27, 2009
Water from washer in bathtub
Either your drain when plumbed wasn't installed with a y that allows smooth flow past the tub... or it bottle necks too much and needs the over flow to get down the drain. Or the drain size should be enlarged to 2 inch instead of 1 1/2 inch. If the existing drain is galvanized then it narrows with age. The drain lines may not have enough lean and have deposits on the bottom that need a plumber with a root cutter bit on an electric eel to get removed. (rental eels are just not good enough). Also is this drain vented properly to allow the air to move aside so as to allow the water to run down smooth?
Oct 20, 2013 | Magic Chef Washing Machines
Dishwasher won't drain leaves about 11/2 inch of water in the bottom
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Sep 14, 2010 | Bosch Dishwashers
The washer leaves water remaining in drum after the entire wash cycle, it becomes stale and makes my clothes that I was smell. My father's front loader, GE, does not leave any water in the drum
Hello
Check the drain tube,it needs to be 30 inches above the floor.
Also if the drain tube from the washer is too far into the drain the washer will not drain completly.The drain tube should be 1 inch into the wall drain.
Also check for kinks or obstructions in the washer drain tube.
May 13, 2010 | Samsung WF203ANW Front Load Washer
We bought a washer yesterday. When I went to fill it up this morning the water would not fill but just drains, while the water is running, please help, I think it is something simple/
The drain hose is too far down the drain. Pull out excess hose from drain and leave only 8 to to 12 inches. Using zip tie or other method, secure drain hose to water hoses to prevent drain hose from jumping out.
Jun 08, 2008 | GE Washing Machines
Drain problem
If there's water in the drain line this is normal. There is roughly about a half a gallon of residual water that remains under the wash basket, drain line and drain pump combined. That's why it is important to leave the washer door open when not in use to allow the tub to air out. It will not evaporate the water, but will help reduce the build up of mold, mildew, and odors.
Now, if you look inside the wash tub and see standing water, then you may have some drain line issues. Make sure your drain line does not exceed 10 feet in length. Excessive lengths can cause backwash. Also, make sure the standpipe at the wall is at least two inches in diameter, a minimum of 34 inches from the floor and does not exceed a height of 72 inches. All these conditions can cause slow drain problems and/or backwash.
I hope this answers your question and that you find this helpful. Please post back if you need further assistance.
PS Make sure the standpipe is draining properly. It should be capable of draining approximately 17 gallons per minute.
May 28, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Water not fully draining during washing dishes. Stays approx 2 inches.
heres some few other simple checking & steps, that will guide you to the process...
1st
Remove the cover from the air gap at the top of the sink (usually a short chrome domed cylinder that sits at the back of the sink) and, using a wire, clean it. Also check the entire length of the drain hose for kinks and blockages, especially at the drain connection to the disposer or drain line.
2nd
Once the dishwasher is cool, shut off the power to it, and--if your dishwasher is made to allow this-- remove the strainer, located under the bottom spray arm at the base of the cabinet. Unscrew the hubcap, lift the spray arm off, and remove any clips that hold the strainer to get it out. Scrub it clean with a brush, then replace it.
3rd
Determine whether the sink trap or house drain line is clogged
4th
If it still doesn't drain properly, the drain hose may be clogged or the drain valve may need replacement. At this point, it's usually best to call a repair person. You can check the drain hose for obstructions, but this sometimes involves pulling the dishwasher out from under your counter to access the hose, disconnecting the hose at both ends, and flushing it out with a faucet or garden hose.
Let me know..
Thanks
Apr 19, 2008 | Dishwashers
MACHINE DOESN'T CYCLE OUT OF RINSE
Does it spin if you move the timer manually? ist it being used on a delicate cycle@? if so it will stop in the last rinse water
Jul 10, 2007 | Ariston Technologies AWD 121
Asko D1706 Built-in Dishwasher Logo
71 people viewed this question
Top Asko Dishwashers Experts
John Tripp
John Tripp
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
