Question about Frigidaire Refrigerators
I unpluged my refrigerator for 5 months now its not cooling what could be the problem please help
Model number is LFUS2613LEO seriel number is 4A02815928
    Top Expert:
  • Frigidaire Master
  • 9,472 Answers
What is the model number of the unit?
Posted on Nov 26, 2012
Testimonial: "i took the relays out they dont rattle. can u please give me another solution"
  • 1 more comment
  • Richard Roth
    Richard Roth Nov 28, 2012
    Have you checked the defrost timer and try to advance it?
  • jackie maylone Nov 28, 2012
    no sir i havent couldyou tell me wherere its located and how to advance it im really not an expert at these things. my regrigerator aint even to yrs old...thank you so much
  • jackie maylone Dec 02, 2012
    How do check the thermostat to see iff its bad? we r thinking that the problem is its stuck in self defrost mode? can u please tell me how i can check and fix it thanks
SOURCE: Profile refrigerator section not cooling
We are not sure what precipitated the temperature swing up; however, within about an hour of emptying quite a lot of foodstuffs from top and bottom sections of the unit, I felt the cold air start to flow out of the rear vent. Within two hours, the upper section had dropped to about 50 degrees and by the next morning to 36. The freezer seemed to recoved on its own too, having risen to almost 8 degrees and then recovering to 0. Just patience and a smaller food payload?
Posted on Oct 02, 2008
22yooper
  • 828 Answers
SOURCE: LG refrigerator not working
Check and clean the condenser. Unplugging the system allows it to cool off. when you plug it back in it will cool until the heat rebuilds if not rejected through the condenser. Make sure the condenser fan comes on when the compressor runs. A faulty fan motor will cause the same type of problem.
Posted on May 19, 2008
Krazytech
  • 725 Answers
SOURCE: amana refrigerator not cooling
you may have a bad defrost thermostat .. it is on the evapator check it with a ohm meter and see if its open..
let me know
Posted on Jul 08, 2008
  • 125 Answers
SOURCE: Whirlpool refrigerator model ED5GTN cooling problem.
With the unit unplugged, take off the back cardboard panel. On the lt rear side you will find the compressor. On the lt side of the compressor you will see a white box mounted on the side, this is the relay, and it most likely will have a zip tie holding it on. Cut the zip tie or unhook the clip. Gently pry the relay from the side of the compressor. If it is badly burnt make sure there are 3 connectors on the compressor, sometimes they will burn one off or burn it so bad the compressor will need to be replaced $$$$ if not in warranty. If its not burnt thats hopefully what you will find, hold out your hand with the compressor side of the relay pointing down. Shake the relay like a salt shaker into your hand. If you get grey flakes/chunks in your hand the relay is bad and will need to be replaced. easy fix for about $45 - $50.
Posted on Apr 18, 2009
SOURCE: Refrigerator not cooling
We had a similar problem - it was the compressor start device. Ordered a new one from repairclinic.com, and it works great now. The old start device rattled when we shook it. We opened it up and found lots of burnt little bits. Check to see if your compressor kicks on & off a lot. Ours would run only about 10-15 seconds, then go off for a minute or two - then back on for a few seconds. If that is happening, it could be the start device. Hope this helps.
Posted on Aug 13, 2009
What is wrong with A fridge that went completely dark but restarted after being unplugged for 10 minutes
A control board problem. What is the model number?
Kenmore model numbers look like this=> 109.1234578
Appliance 911
Jan 02, 2016 | Kenmore Refrigerators
My electrolux dff 44 high temprature light is on regularly on and the cooling is slowly slowly low
Good Afternoon Friend,
I understand that your Electrolux refrigerator, model# DFF44, has the high temperature light on regularly, and it is not cooling as it should. In researching your model number, I have found that it was manufactured in Argentina. I suggest resetting your refrigerator, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Give your refrigerator 24 hours to stabilize at the set temperatures. If this does not work, I suggest contacting the manufacturer. Hope this is helpful.
-Best Regards-
WP
Jun 15, 2014 | Electrolux Refrigerators
My model 106.53206202 compressor stops working about every six months. The interior light lights so there is power. I unplug the power cord and when I plug the power back in the compressor works fine. ...
I think the defrost timer/control board is hanging up...
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Feb 09, 2011 | Kenmore Refrigerators
Defrost heater mnot completely defrosting
unplug it and get your hair dryer remove the panel again and blow dry the entire thing untill all is melted be carefull not to over do ad not to put dryer in the freezer stand back where the water will not splash on the dryer after leave it off for 1 hour than turn back on and put setting on number 3 for 2 to 3 hours than adjust to your normal setting not higher than 5 or it will repeat problem.It is getting very well cool causing to over cool to fast.
also air spray out back side and bottom of refrigerator is always a big help
Good Luck
Apr 08, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer and refrigerator doesn't cool properly
Sounds like a main control board bad . A model number would help .
Jul 18, 2009 | GE Profile Arctica Stainless Steel Top...
Amana refrigerator not cooling
let me know
Jun 17, 2008 | Amana SXD524VW Side by Side Refrigerator
Refrigerator will not cool
also the complete mod number would help
May 21, 2008 | Refrigerators
Error message er if
Hi. Error FF is your Fresh Food Fan. Otherwords, the evaporator fan motor has failed. You should replace the motor and motherboard. You may get by just replacing the motor. Sears doesn't manufacture the refrigerator. They just pay extra to have Kenmore put on it. Its the manufacturer that needs to back their equipment. If you bought it from Lowes, you can't hold Lowes responsible for the ongoing issue. They sell the same refrigerator. Anytime this model refrigerator displays an Error code, unplug it for 5 miniutes and replug it. Sometimes it was a computer misfuction. Good luck! Mack
Dec 28, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerators Logo
428 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
