Disc won't spin or register on my koss pc36
    Top Expert:
  • Televison & ... Master
  • 74,136 Answers
Check and replace its sled motor
Posted on Nov 27, 2012
Shows no dics
Hi
Please check weather you have inserted the disc ,whose format is supported by your KOSS player.
If the formatt is not been supported /regonised by the player,It shows as NO DISC only.
check with some other disc which you previously played.If it plays the disc which you using has the problem.
Thanx
Jul 26, 2010 | Koss Televison & Video
DVD Tray stock closed Koss ks 2503
See if you can acquire the software upgrade that Koss engineers devised to solve the problem, I did have one(the upgrade) but misplaced the disc, if you manage to obtain it please e-mail me.
Art.
May 25, 2008 | Koss KS2503 System
Koss DVD
the humming noice is the dvd spinning trying to read the disc so we know that works take it apart and see if the laser is working d{dont look in the laser} and if that works take a q-tip and lightly wipe off the laser lightly move the laser up and down to make sure its not stuck and try to see if it works then
ps keep it off the carpit
Jan 22, 2008 | Koss KD250 DVD Player
Koss KD365 DVD - Says No Disc
Make sure the disc is spinning. This might sound crazy but try turning the whole player upside down and see if it plays.
Jan 02, 2008 | Koss KD365 DVD Player
DVD Player turns on spins says reading but there is no picture or sound.
I had same problem and once left the player on for 3 weeks (left for vacation) and it still never worked. Finally had to dissassemble body of player to get dvd out. There appears to be no solution to this problem. I have called it quits and this cheap piece of junk is now in the trash. Koss will never be on my list of best buys.
Feb 27, 2007 | Koss KS2503 System
Dvd player won't play-shows "bad disc" on screen
it did the same thing to me, it started to work again. it may be a memory issue. my koss player started to work again after it was unplugged for a while. Its something to do with the dvd disc not the player. if i find out , i will post again. good luck
Dec 25, 2006 | Koss KS4110 DVD Player
Koss KS2503 "MSG 04" problem
I had this MSG 04 problem. Opened the player up. Messed around. Figured out that the 5-disc tray was hanging up a little during the initialization. The issue is that the tray screws into and rotates around a stand-up beam. On the underside of the tray are gear teeth which are spun by a gear on the main unit underneath. The real culprit is the stand-up beam in the very middle. It is too long. The fix is to first try just tightening the middle black screw holding the tray onto the stand-up beam. If this tightens and MSG 04 goes away, you're done. If it does not tighten at all or much at all, then remove the screw (actually a bolt) and using a razor or sharp blade, scrape the top 1/4 millimeter off the stand-up beam. Apply some grease around the beam and on top. Note, you may have to remove the tray to do all this. If so, that is the most tricky part. Carefully lift on the tray on the front side as you rotate it. Try to free a disc circle edge over the top of the front DVD cover and free the tray. To re-set the tray, put it on the stand up beam with the front side of the tray slanted up and slowly rotate while setting it in and down. After re-seating the tray, screw the bolt down but do not tighten all the way. Tighten it enough to allow rotation and enough to rid the msg 04 problem. I shaved my stand-up beam and have never seen a MSG 04 since.
Apr 01, 2006 | Koss KS2503 System
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
