Question about LavaMind Gazillionaire Deluxe
Gazillionaire deluxe won't install
I keep getting a compatibility error but it won't run in any compatibility mode either. Can't even do setup.
MOST GAMES WON'T PLAY THEY WILL BE INSTALL BUT WON'T RUN
is it compatible?
Right click on the game icon and select properties. Click on the compatibility tab and tick the box in the compatibility mode section. Select xp and click apply.Start the game and hopefully it works.
Sep 26, 2012 | Video Game Consoles & Games
I HAVE WINDOWS VISTA AND IT DOES NOT INSTAL ON MY COMPUTER
Print Shop 22 is not compatible with Vista (or Windows 7): this is the official Microsoft position.
https://www.microsoft.com/windows/compatibility/windows-vista/Search.aspx?type=Software&s=The%20Print%20Shop%2022%20Pro%20Publisher%20Deluxe
Basically, you need to get a 'free' upgrade if you bought the product as the program will also not work in 'Windows XP' compatibility mode.
If you are technically inclined, you could install a 'Virtual Machine' (such as the free Oracle VirtualBox) and install Windows XP under it: this should permit you run PS22 in the virtual machine.
Hope it helps.
Sep 21, 2011 | Broderbund The Print Shop 22 Deluxe Full...
I cant install T-Shirt factory deluxe on mu computer windows 7
The following are your options for running this software:
1) Run your software in (XP) Compatibility mode - set in Program Properties-> Compatibility
2) Run in XP Mode if you have the appropriate version of Windows 7 (Professional and Ultimate) and Hardware (CPU must have Hardware Acceleration).
3) Install a Virtual Machine (such as the free Oracle VirtualBox) under Window 7 and then install an alternative Operating system (e.g. Windows XP) in this Virtual Machine and then the required software.
Hope it helps & Good luck!
Jun 12, 2011 | Nova Development Art Explosion T-Shirt...
Installed The Print Shop 2.0 Deluxe on my Windows XP, SP3 & seemed to install fine. Won't run, gives me error message - "The configuration file is missing or invalid; you may have to repair...
Hello there, At first, go to start menu, all programs, accessories, system tools, open System Restore. Restore your system to restore point created before installing The Print Shop. After that, try to install it again. Otherwise, you can try to install it from different CD, or installation file. Sincerely, Steve TM
May 28, 2011 | Computers & Internet
I have the full version of print shop deluxe22 and it won't let me install it on my hp laptop HP G71-442nr Notebook, Running windows 7
Print Shop 22 Deluxe is not compatible with Win 7 (x86 or x64bit) Operating.
You have to use the Print Shop 22 Deluxe version 23.1 - compatible with Win 7 & Vista.
Hope it helps.
May 25, 2011 | Broderbund The Print Shop 22 Deluxe Full...
I have the print master gold deluxe software and I'm not able to use it with window 7. please help
All you need to do is download & install Windows XP Mode for Windows 7
http://www.microsoft.com/windows/virtual-pc/download.aspx
Once installed you will be able to run all your favorite old programs , if you run into any compatibility issues , right click on the .exe file & select "properties" , compatibility mode , & select the settings your program is known to work with .
After all this if you still can't run the program , try using " virtualbox " or " vmware virtual machine " & install a copy of windows xp as a virtual machine .
Apr 16, 2011 | Broderbund PrintMaster Gold 16 for PC
This used to work perfectly on windows XP. I now have windows 7 & after downloading the Photo Explosion 2.0, it won't open & the programme just freezes. Help.
Downloading means you retrive any files and save to your PC/Laptop from any web source!
Installing means you install any software/programs to run on your PC/Laptop.
As for your software "Photo Explosion 2.0" could not run on Win 7 due to software "Compatibility Issues".
You can try, using "Win 7 compatibility mode" installing older software read this LINK
NOTE**
"There is no guarantees older software will work using Win 7 compatibility mode!"
Hope it helps.
Nov 11, 2010 | OnDemand Photo Explosion Deluxe 2.0 for PC
Making printshop 21 run properly on win 7
You can either get Broderbund Print Shop Deluxe 2.0 which is Win7 compatible or use a virtual/dual boot computer with WinXP. (The Vista compatible version was Print Shop 23; so you are dealing with some significant changes in the OS. Thus the compatibility mode probably won't work. You can try right clicking on the installer and choose Properties and the Compatibility Tab. Check Run as Compatible with XP then right click on the installer again and choose Run as Administrator. Then do the Compatiblity mode again with the actual program.)
With Win7 Pro and Ultimate, you have an option to download and run XP mode which takes two programs that you download from Microsoft and install. This lets you run a virtual XP computer inside the Win7 computer for free. All other virtual computer programs or dual boot systems require a licensed version of XP.
I hope this helps.
Jul 31, 2010 | Broderbund The Print Shop 21 Deluxe Full...
Print Shop 2.0 Deluxe will not load.
Have you tried installing them in Compatibility Mode? If not, look in
Vista's Help
& Support for how to try this. If that doesn't work, you can
try installing them as Administrator by right-clicking on the installer
executable and choosing "run as Administrator".
If none of that works, I'm sorry but you'll need to update to a current
version of the program that the mftr. says will work in Vista.
Jan 30, 2010 | Broderbund The Print Shop 20 Deluxe for PC
Old alchemy game will not install
Try this:
Right click on the D:/Poppack-setup.exe -> Properties = Compatability Tab.
There should be a box that says "Compatibility Mode" that you need to chek, and then select Win95 and hit OK.
Try installing again.
If it still gives the same error, go back to the tab and go lower than the Compatibility Mode box, to Display settings, and chek "Run in 256 colors" and "Disable Visual Themes"
Try again.
If it still wont work, please respond. If it gives a different error at any time or a different problem, please respond.
If it works, please rate. :)
Dec 12, 2008 | TalonSoft Video Game Consoles & Games
Video Game Consoles & Games Logo
157 people viewed this question
Top LavaMind Video Game Consoles & Games Experts
James Wishart
Are you a LavaMind Video Game Console and Game Expert? Answer questions, earn points and help others
