Question about Element ELC-HS321 32 in. LCD TV
I have an Element 32 inch flat scheen tv Model ELCHS321
The TV's LCD screen is flickering it started about two weeks ago and to day it keeps on flickering and wont stop. What should I do to fix it?
  • 26 Answers
Check and see if any capacitors are domed over.
Posted on Nov 27, 2012
tvtek
  • 1284 Answers
SOURCE: I have Model ELCHS321 Element
If using cable with no cable box go into the Closed Caption settings on the TV and turn the TEXT mode off.
Posted on Sep 08, 2010
dsacco86
  • 1077 Answers
SOURCE: Element 32'' LCD TV, has picture but no sound
The S-video cable doesn't have hookups for audio, only video. It's better than the video coaxial cable. But, you still need to hook up the right and left audio coaxial cables.
Posted on Feb 09, 2009
pgh_pa_guy
  • 2992 Answers
SOURCE: element 32" flat screen tv has cracked screen
Sorry to say, when the display is broken you're best off looking for a replacement TV.
There isn't any way to repair a cracked display except to replace it. You can try a Google search or check websites like shopjimmy.com that sell parts removed from junked sets. It's almost impossible to find replacement displays (unless you are a warranty servicer and get them right from the manufacturer) since most TV's are junked because of broken displays. And if you do find a display, there are still potential problems. Besides the cost (the display is the most expensive part, most of the set's cost), you need to be sure the display is exactly the same part as the one you're replacing. The same model of TV can use different displays depending on when and where it was made, and there may be differences in other parts in the set as well.
Posted on May 27, 2009
  • 126 Answers
SOURCE: i have a flat screen element 32 inch tv and my
if your using cable then the tv is probably on an input instead of TV or antenna
Posted on Dec 04, 2010
caroldon
  • 17129 Answers
SOURCE: my element ty model no
This is a fault solution which can be checked and corrected by you assuming that there is no component failure. There is a high possibility that the components over a period of heating and cooling, tend to bring on a problem of dry soldering. So my advice is to check the set for some loose joints that have played on to give you these erratic shut downs or poor performance.
The best way to check for loose connections is to tap lightly when the set is powered on , If there is change while tapping then it seems that there are DRY solder joints. Remove main plug, the covers - with caution of high voltage, check for dry joints, use a good soldering iron to solder all suspected points.
Sometimes the fault occurs when the set warms up, if so you can simulate the heat using a hair dryer on the suspected areas, try with the power supply, distribution, Processor controller, driver controllers on the A/V related sections. Also the use a FREEZE-IT spray can simulate the components to cool and show up the fault.
Based on the above method you must be able to locate the area of fault and solder the sections. Sometimes large IC's- ones with more pins- tend to have drying in some pins and so cause faults related to the IC's protocol. Have a rough idea of looking into the areas to reduce the time of probing.
Check for tips to look into the SMPS unit with some of my tips:
http://www.fixya.com/support/r5826301-working_switch_mode_power_supplies
Thank you for using Fixya.
Posted on Sep 19, 2011
Element 32 in tv
Element 32 in tv - Fixya
www.fixya.com > Forum > Flat Panel Televisions > Element
38 mins ago - element 32 in tv Need a code to run the volume and on off shaw direct sat. - Element Flat Panel Televisions question.
Remote Control Code for Element LCD TV -- & Direct ... - Fixya
www.fixya.com/support/t1101060-remote_control_code_element_lcd_tv
Remote Control Code for Element LCD TV -- & Direct TV Haven't been able to find the right code to program the - Olevia LT32HVM 32 in. ... It is annoying to turn the TV on and the volume with the Element remote and then have to use the ..... Need the codefor a 42 inch LCD TV model ELDTW422 to program our Direct TV ...
Element 32" 1080p TV (ELDFW322): Unboxing & Setup ...
? 6:40
https://www.youtube.com/watch?v=EKtjBnx6EG0
Mar 27, 2013 - Uploaded by PureLegit
This is a new video on this TV that I got from Element. If you go back on my channel you will see my first ...
Jan 20, 2016 | Element Televison & Video
Need fix how do i make it stop flickering
Coby lcd tv keeps flickering Flat Panel Televisions ... - Fixya
www.fixya.com > ... > lcd tv keeps flickering > Flat Panel Televisions
Coby flat panel televisions lcd tv keeps flickering related questions and answers. Ask your Coby ... Why does my Coby 40 TFTV4028 LCD TV keeps flickering.
Coby adjust air fuel mixture Flat Panel Televisions ... - Fixya
www.fixya.com > ... > adjust air fuel mixture > Flat Panel Televisions
Coby flat panel televisions adjust air fuel mixture related questions and answers. Ask your Coby ... Coby 32 in tv ... to last channel, and will stop, and will display the first channel it has got. Then we have to make adjustments on channels. ... Ad. Question about 40 TFTV4028 LCD TV. 1 Answer ... Flickering can be adjusted.
Won't turn. on red standby light changes to on but then
Jan 04, 2016 | Coby 40 TFTV4028 LCD TV
Rescan channels
Element ELCHS321 Manuals Check this link to download the user manual to your device. It has all details Electro help
Dec 07, 2014 | Element ELC-HS321 32 in. LCD TV
I have this model N3735w Viewsonic LCD flatscreen TV and it is flickering. The screen is also getting darker.
Try turning off the automatic brightness feature . This mode adjusts the brightness according to the light level in the room.
Dec 26, 2013 | ViewSonic N3735W 37 in. LCD TV
I have a 32" RCA LCD tv , rlc3210 power input says
Is it hooked up with HDMI cable?
If so try unplugging the HDMI cable and re plugging the cable in, sometimes those cables work loose and if they are not tight, it will cause your screen to flicker. Happens to my TV once in awhile.
Aug 23, 2013 | Televison & Video
My tv has no picture just turned off still had soundmodel number# elchs321
check for two leaky capacitors in the power supply section. Should be two 10uf 250V caps with bulging tops. If you see this, that's your problem.
Apr 19, 2013 | Element Electronics FLX-3211B 32 in. LCD...
I have an ELCHS321. My backlight started to flicker. The inverter board is JLS-05-32EI. I have the back open and noticed that the LED on the inverter board was blue and flickering as well. As the set...
I would suspect and check first the voltages going there to see if low when cold and come up and if they are moving up and down when it flickers----points to problem in power supply
Oct 16, 2012 | Element ELC-HS321 32 in. LCD TV
Vizio start blue/yellow flickering screen
If you wish to get some details; visit the site linked here. Pull up older posts.
faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Jul 01, 2017 | Vizio VW42LF 42 in. LCD HDTV
Element HDMI 32 inch. Left half showing picture, right half only showing vertical rainbow lines.
One of 2 things happened here. Either your T-con board is defective and needs changed, or your Panel is defective and you need a new TV.
Apr 11, 2011 | Element Electronics FLX-3211B 32 in. LCD...
Element ELC-HS321 32 in. LCD TV Logo
458 people viewed this question
Top Element Televison & Video Experts
Joseph Hoffmann
Are you an Element Televison and Video Expert? Answer questions, earn points and help others
