Question about Garden
Karcher 3.97. Leaking water from unit when on water cycle.
2 Suggested Answers
delgriffith
  • 97 Answers
SOURCE: karcher 3300 G water leak out rear of unit from white plasticplug
if its just a plug, remove it with an allen key and wrap a couple layers of teflon tape around it. That should stop, or at least slow down any leaks that are coming out of the threads.
Posted on Jun 19, 2009
Hi My karcher k3.65 jubilee is leaking water when the pump is switched off from underneath
Hi This could be just the water inlet channel broken or split. You will need to remove the yellow cover via the screws at the back of the unit and then connect the water hose to see where the leak is coming from. If the water comes from underneath the pump then you will need a replacement pump seal kit of which you can purchase on the Internet.
Jun 11, 2010 | Karcher 1750 psi Electric Pressure Washer
Leaking water
Screws, lots of them on the back side of the unit. May be torx type. Once taken out, the top cover should come off.
May 25, 2010 | Karcher Electric Cold Water Pressure...
Karcher is spraying water from inside the unit, it actually a k2.97, any ideas please
Hi I have water spraying from air vent/intake on side of my k370 can you help ?
Mar 01, 2010 | Karcher K2.26 Electric Power Washer
Just started using my kb4040 and water i s leaking
Sounds like the water seals are bad. For Karcher parts go here: LINK
Jan 18, 2010 | Karcher 1750 psi Electric Pressure Washer
My Karcher (K2.26M) pressure washer is leaking water from the ON/OFF switch and the bottom. Does anyone know what could have broken, and what part I would need to fix it?
I have had a dozen of these units, My advice is not to bother trying to get parts or fix it. Its designed to be a throw away unit!
Oct 31, 2009 | Karcher K2.26 Electric Power Washer
I've got a K2.55 Karcher , leaking
The gasket to the head is leaking. It is best to get a new Machine, Folllow the instructions for storage when you get the new one, do not leave water in it whan you put it up.
Sep 04, 2009 | Garden
Karcher 1650 leaking water from trigger
i believe the spring is the actual trigger spring that pushes the trigger switch back in place and the water leaking out is probably a seal issue
Aug 25, 2009 | Karcher Garden
Karcher 3300 G water leak out rear of unit from white plasticplug
Jun 19, 2009 | Karcher 2500 PSI Pressure Washer
Karcher K3.91 compressor run for a few seconds every 10-15 second
They have a problem. I removed both valves and lubed with lithium grease as I was told. Unit is now working for how long who knowes.
May 18, 2009 | Karcher PSI Electric Pressure Washer
Garden Logo
49 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
