valve needs to be replaced. it is located in the back, just follow the water line to it. to shut off water there is eaither a shutt off behind ref or in the basement. again try to fallow the water line
SOURCE: Ice maker panel came loose on LG LSC26905TT fridge
Please use the attched link to get the service and user manuals for your fridge. There are exploded views there as well so that should provide you suffiicient information to reinstall your panel. You can also get part numbers etc for replacements if that is necessary.. Hope this helps you...
http://136.166.4.200/contents/Fridge/LSC26905.htm
Regards,
Rick
SOURCE: ICE MAKER QUIT MAKING ICE ON MY WHIRLPOOL FRIDGE
I had a Whirlpool Model GD5SHAXNS in which the icemaker quit working about the same time (3 years old). I had water out the dispenser, I found that it was the icemaker itself failed not calling for water to fill it. I replaced it with a icemaker on-line for about $100 and problem fixed. I have been told his is a common problem with the icemaker in this model ref.
SOURCE: whirlpool refrigerator ice dispenser no longer workds
Ok, I show parts that are available for that model, sounds like the control board is defective for your dispenser, or possibly the Ice maker control board. It also could be a break in the wiring or the control itself. Below is a break down for those parts, wiring and the control behind the push to dispense ice or water. Hope it is not that control because some places don't provide that part. Now if it's a connection problem that we can find, I will do mu best to help you solve this.Could you insure the model number is correct as this is very important? [email protected]
SOURCE: kenmore refrig model #106-56232400 ice maker
the ice maker unit prob' bad and if you sure it is on and the flag is not stoping it from runing you might need a new unit but there are other tests you can do before..
call me 843.789.4824
Im in Charleston S.C but will happy to help you
www.911servicetoday.com
