Question about Worldwide 2000 Ford F350 Super Duty Pickup 6.8L Alternator - 130 Amps
2000 ford f350 v10 sticking throttle
Throttle sticks while driving. take your foot off the gas and its like your foot is still on it
    Sergeant:
  • 170 Answers
The IAC may be the issue.
I removed it and cleaned it. It ran OK until I tapped it with my screwdriver. The RPMs shot right up and I could hear the air rushing through. My scanner showed that the voltage to the IAC did not change. I pinched the hose that comes off the intake to feed the IAC and the throttle dropped to normal levels.
Posted on Aug 09, 2017
Changed #5 & #6 coil on 2000 Ford Excursion v10 and it still misfiring. No check engine light
check to see if rocker arm is broken on those cycl this is a common problem with v10 pull valve cover youll see it
Sep 20, 2013 | 2000 Ford F350 Super Duty Super Cab
1993 ford f350 with 7.5 liter gas sticking on high idle i changed the tps and map sensors and new vacuum lines
check your idle air controller, they usually get a heavy carbon buildup on them and stick-easy to remove and clean.
Oct 04, 2011 | 1993 Ford F350
How do you clean the air intake throttle on a 2005 Ford Freestyle?
if its drive-by-wire, remove the intake pipe to the throttle body. have someone get into the driver's seat, turn the ignition ON, and leave ENGINE OFF! have the driver put the acclerator pedal all the way down to the floor as that will open the throttle bodys butterfly valve. Now grab a rag, spray some carb cleaner on the rag and wipe that throttle body's insides clean! be sure whoever is in the drivers seat with there foot on the gas does not let go while your hands are in the throttle body as it can pinch and it does hurt! hope I helped, please rate!
May 12, 2011 | 2005 Ford Freestyle
I have a 1991 f-350 with a metric transmission . I parked the truck for 1 month and when I drive it it will not shift in auto, when I shift it manual and it shifts well . The transmission has about 2000...
THERE SHOULD BE A CABLE THAT GOES FROM THE THROTTLE BODY DOWN TO THE TRANS MAKE SEE IF IT IS NOT MOVING THEY WILL STICK ON THE TRANS AND THE CLIP WILL BRAKE AT THE THROTTLE BODY
Oct 13, 2010 | 1991 Ford F350
Help me
You need to check the Idle Control module.
I think it is sticking closed. Is the check engine light on ? Is the fuel pressure good ? Is the gas gage reading the correct amount of fuel in the tank? Did you tune up the vehicle lately ? Is the throttle body full of carbon ? You need to have the vehicle check by your local mechanic.
Mar 27, 2009 | 2000 Dodge Durango
2000 f350 v10 missing all the time need help
Only one.Your problem is 1 (or more) ignition coils or spark plugs.You need someone with a scan tool to check this out for you.
Feb 22, 2009 | 2000 Ford F350 Super Duty Super Cab
Back fire while driveing
check for vacuum leaks at your throttle body, intake manifold gaskets and vacuum line, or you could possibly have a sticking valve. if I am understanding you rite the truck sat for 2 years. also check the wiring to your sensors as for a rodent may have chewed some insulation off, this happened to my sons car.
Oct 11, 2008 | 1990 Ford F350
Worldwide 2000 Ford F350 Super Duty Pickup 6.8L Alternator - 130 Amps Logo
117 people viewed this question
Top Worldwide Electrical Supplies Experts
jhnolson
wadingriver
wadingriver
ka4iup
ka4iup
Are you a Worldwide Electrical Supply Expert? Answer questions, earn points and help others
