Question about Nikon D80 Digital Camera with 18-135mm Lens
My Nikon D80's viewfinder stays black when camera is on. Playback
Feature works fine. My battery is fully charged and I can take pictures. Please help
  • 1 more comment
  • izik13 Jan 28, 2009
    I have the same problem on my D80. LCD does not show preview. I can check all pictures taken and I can adjust menu. Also, my beep (which is set to 'ON') does not make any sounds anymore. Please help.
    Izik
  • Anonymous May 02, 2009
    My viewfinder is dark also when camera on, altho functions for picture review and menu items.  Just tried reset (+/_ and AF buttons) which did not work.  Batteries are charged.  Any other ideas?
  • Randy Wheatley
    Randy Wheatley May 11, 2010
    djfaux,
    Let me know when is it black, all of the time or always until you take a photo? The later is normal, esp. if you can press the menu button and see and go through the different menus. You can set the display to stay on a little longer for your viewing afteer the image has been take.
    randy320sgi
    Novelist:
  • 121 Answers
Dj & izik13,
If you can both acces the settings menu let me know if you can change any of the settings. Have you tried to reset? To do it you have to turn on the camera and hold down the two buttons that have a green dot by them on the top by the shutter release (the +/- ) and the AF button by the top menu display for longer than 2 seconds, just remember you'll have to reset some of your favorite setting all over again, but it will get things back to the original factory settings. Let me know if that worked
randy320sgi
Posted on Jan 29, 2009
I am new user for DSLR, using old 50 mm 1.8 manual focus on D80, unable to see any inmage on playback (shows information). Will this lens work with D80, using settings as manual mode, f22 . Please guide...
Turn the aperture ring to its smallest setting (largest f/number). You control the aperture from the camera body, as on a lens without an aperture ring. Turn the mode dial to M (manual). The camera's exposure meter will not work with this lens. You can use another lens to get an approximate exposure, or take pictures and review them and/or use the histogram to fine-tune the exposure. The camera won't autofocus, of course, but the in-focus indicator in the viewfinder will still light up to indicate proper focus.
Jun 17, 2011 | Nikon D80 Digital Camera with 18-135mm...
Nikon d80 dslr camera working fine and then one day turned it on to take pictures only to find an err message flashing and when the shutter button depressed it says r04. The shutter sounds but no pictures...
HiI am sorry to hear, but you will have to some professional. Regarding your d80 has common problem of sequence unit defective. I believe that is the problem and your local repair shop would charge around $75 to 235 depend on what they really want to charge. Thanks and best regard!
May 27, 2011 | Nikon D80 Digital Camera
How can i used the LCD monitor during taking pictures? as of present i am only using the viewfinder? pls help me set my cam...
The D80 does not have the LiveView feature to allow using the LCD monitor for taking the picture. Nikon introduced this feature with the D3 and D300, which came out well after the D80. You have to use the viewfinder.
Sorry if this wasn't the answer you wanted to see, but that's just the way this camera works.
Jan 08, 2011 | Nikon D80 Digital Camera
I recently purchased the D80 and had no problems, it worked great and took magnificant shots. However, the other day I turned it on and the viewfinder was now, dark and out of focus. The battery was fully...
Check the mirror. The image you see in the viewfinder comes through the lens, and is reflected by the mirror. If it's dirty, it will affect the image you see. When you take the picture, the mirror lifts up, the viewfinder image is interrupted, and the light from the lens goes to the image sensor. So...if the mirror is dirty, the picture will be fine but the viewfinder image will be dark or out of focus.
Jan 23, 2010 | Nikon D80 Digital Camera with 18-135mm...
Nikon D80 - LCD screen goes blank in the mountains
In the mountains, are you subjecting the camera to wide swings of temperature or humidity? These could cause your symptoms.
Sep 04, 2009 | Nikon D80 Digital Camera with 18-135mm...
CCD FAILURE! D70 's and D80 's 90's all have this problem
Call NIKON for Free Repairs it is a known manufac fault in thousands of cameras , dont worry just call them see this for info on this problem
Kindly Rate me WELL !
this applies to all products with same problem dont worry u r included just call them and tell them abt BAD CCD !
Good Luck !
May 31, 2009 | Nikon D80 Digital Camera with 18-135mm...
Power switch
Make sure you are using a fully charged Nikon battery. Problems may sometimes happen with generic batteries. If you are using a Nikon batt, then seems you may need to bring this in for servicing
NOTE: Please rate our help to keep this free service online
May 09, 2009 | Nikon D80 Digital Camera with 18-135mm...
D80 with nikkor 18-200, no picture
raatl, You mean the LCD on the back of the camera right?  The image that shows up (playback) can have the duration changed in the menu settings, it may have been turned off which is a choice as well that mode (not having the LCD on) extends shooting time which used to be a problem with the earl D70 and the earlier battery type.  The D80 doesn't have that issue, try experimenting with how much time you really need to have the display on, if you shoot and like to show the image to people set it longer or just hit the playback a couple of times as you are showing people.
randy320sgi
Dec 20, 2008 | Nikon D80 Digital Camera with 18-135mm...
Nikon D80 Digital Camera with 18-135mm Lens Logo
797 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
