Question about Epson Stylus Nx420 Color Ink Jet All-in-one C11ca80201
HOW I CAN PRINT WIRELESS - Epson Stylus Nx420 Color Ink Jet All-in-one C11ca80201
  • 2,878 Answers
Printer needs to be on the wireless network, then setup the PC with printer wizard using the IP to identify the printer. You may even try entering it in the Run / Search for auto setup by Windows. Both have to be on same network.
Posted on Nov 28, 2012
How do I find the Printer IP address
Test the wireless connection
Print the wireless test report for information about the printer wireless connection. The wireless test report provides information about the printer status, hardware (MAC) address, and IP address. If the printer is connected to a network, the test report displays details about the network settings.
To print the wireless test report
1. From the printer control panel, touch (Wireless), and then touch Settings.
2. Touch Print Reports
3. Touch Print Wireless Test Report.
Apr 09, 2016 | HP Officejet Pro 8610 Wireless All-in-One...
Will not work unless I disable my current wireless connection internet connection. Can not get computer to recognize wireless print server.
You need to use the SSID of the wireless router on the print server. Any wireless security applied to the router must also be applied to the print server. Otherwise you have two seperate wireless networks.
Aug 30, 2010 | D-Link DP-G321 Print Server
I have an unwireless printer (Canon mx700)-what the cheapest and easist way to make this devide wireless?
The easiest and cheapest way to make this printer to work wireless is to go get a wireless print server like the one from Linksys its model is WPS54G you just connect the printer to the print server that is configured to working wireless on your network and that's it you can now print wirelessly from any computers that you have on your network.
Apr 17, 2010 | Canon MX700 Office All-In-One InkJet...
Can I wireless print with this model?
no you cannot wireless print with this printer
Mar 31, 2010 | HP LaserJet 1022 Printer
How do i set up my wireless canon printer to my laptop? I keep getting messages saying can't find the printer.
Difficulty: Moderately Easy
Instructions
Things You'll Need: · Wireless print server
· USB printer
· Ethernet cable
· Computer
1. Step 1
Obtain a wireless print server that is compatible with both your wireless network and your printer. While the printer’s documentation may not explicitly say that it is compatible with a print sever, many are compatible, and this can be verified by checking the website of the print server’s manufacturer. If you have a multifunction printer, only the print function will work with most wireless print servers, though a few have recently added support for scanning and the printer’s other functions.
Step 2 Read all of the documentation that came with the wireless print server. The manual will detail the specifics of the installation routine.
Step 3 Connect the printer to the wireless print server via the USB cable. Connect the print server’s Ac adapter and turn the unit on.
Step 4 Connect an Ethernet cable between the wireless print server and your computer. This will be used for the initial setup only.
Step 5 Insert the CD supplied with the print server into your CD-Rom drive. Start the software if it does not start automatically. The application will walk you through the installation process, which includes setting the unit’s IP address, setting an access password, configuring it to connect to the wireless network, installing the drivers that allow the print server to use the printer and installing the print drivers on your computers.
Step 6 Choose how your print server will be addressed. Most units are set up to use dynamic addressing by default, which means that your wireless router will assign an IP address to it. This allows the server to be easily installed on the network, but it also means that the IP address of the printer may change over time. The other option is to assign a static IP address to your print server. This option is more reliable, because the print server will always use the same IP address, making it easier for the computers to find the printer and easier to access the print server’s online configuration application. If your router has the IP address of 192.168.0.1, for instance, set the print server to something like 192.168.0.2 or 192.168.0.3, as long as another device does not use that address.
Step 7
Set a password to be used to access the unit’s online configuration application.
Step 8 Configure the print server to access your wireless network. Give it the same SSID network name as your router and set it to use the same wireless channel. If encryption is used on the router, enable encryption on the print server, and enter the encryption key or password.
Step 9 Follow the instructions given by the print server’s software for installing printer drivers on the unit.
Step 10
Disconnect the Ethernet cable and allow the unit to connect via the wireless network.
Step 11 Install the printing drivers on each computer that will use the printer.
Step 12 Access the print server’s online configuration application to verify all settings by entering the IP address of the unit into a web browser, using the “http://192.168.0.2” format. Enter the administrator name and password.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 21, 2010 | Canon PIXMA MP600 all-In-One InkJet...
WHAT KIND OF WIRES DO WE NEED TO HOKUP A LEXMARK X3350 ALL IN ONE PRINTER.
Standard Ports USB Compatible with USB 2.0 Specification (Type B)
Optional Network Ports Lexmark N4000e Fast Ethernet (Print Only)
Lexmark N4050e 802.11g Wireless Print Server (Print Only)
According to:
http://www.lexmark.com/lexmark/product/home/277/0,6970,204816596_653399443_473191701_en,00.html?tabId=1
Sep 10, 2009 | Lexmark X3350 All-In-One InkJet Printer
I have a netgear wireless network. I am trying to
you can use sharing printer.. even your are using wireless can print as long as you are connected on that network and secondly the same name of workgroup.
Sep 09, 2009 | Linksys Wireless-G WPS54G Print Server
Problem with Linksys Wireless-G WPS54G Print, PS can't be found.
Check the settings on your wireless print server. And as well check your router.
Jul 26, 2009 | Linksys Wireless-G WPS54G Print Server
Unable to setup wireless print server with wireless router
The issue was the wireless print server not properly connecting to my home network and thus being unable to see my modem/network. This was because my linksys wireless print server generates its wep key with a different algorithm than the Motorola surfboard SBG900, this also explains why when I was using my old linksys wireless g router, things worked without any issue (same wep key algorithm). Once I figured out how to manually configure the print servers wireless settings and manually enter the wep security settings I was able to connect to my network and the configuration found the print server and I was able to finish setup.
Nov 27, 2008 | Linksys WPSM54G Print Server
Cannot configure the wireless USB Print Server
first delte all the programs that u have installed about the print server and the printer.then connect the print server on ur laptop and run the installation .search for the wireless netwrk and connecting to it using the wpa key.After tats done connect the print server to the printer and run the printer installation ,,hope that shud resolve it,,best of luck
May 06, 2008 | Port Incorporated Wireless 11Mbps...
Epson Stylus Nx420 Color Ink Jet All-in-one C11ca80201 Logo
88 people viewed this question
Top Epson Computers & Internet Experts
teamtech
teamtech
Are you an Epson Computer and Internet Expert? Answer questions, earn points and help others
