Question about Jenn-Air JS48SEDBDA Stainless Steel Side by Side Refrigerator
Jenn-Air JS48SEDBDA, sn 1271791 will not cool both freezer and refrigerator
    Novelist:
  • 150 Answers
The number reason for the Jenn Air no cool situation is caused by a break down of hte PAG oil in the compressor, thus clogging the capilary tube at the filter drier area, and causing contamination within the system. Per the Maytag TSB, a new compressor kit, heat exchanger, and new liquid line drier are required to be replaced. The compressor kit should come with a new main logic board. The ramaining componants need to be completely purged with nitrogen till clean. The condensor coil must be clean and free of any dust. A new lower freon charge follows the completed repair, and replacement decal to show new charge.
Posted on Apr 11, 2014
  • 27 Answers
SOURCE: jenn air JCD2290HES Refrigerator not cooling
Try defrosting ther could be an ice buildup in the channel between the fridge and freezer.
Posted on Feb 23, 2008
docjohn174
  • 943 Answers
SOURCE: JENN-AIR BLOWS WARM AIR
hi thanks for the question the freezer is more than likely frosted up now with the door left open the drain hose from freezer is clogged shut down let thaw remove panel at the back of fridge allow 24 hrs to thaw clean out the drain tube re level the fridge so that if the door is left open the door will close by its self raise the front legs to achieve this thanks the appliance doc
Posted on Sep 17, 2008
  • 72 Answers
SOURCE: Jenn Air Freezer Works, Refrigerator Does Not Cool
check the damper which provides air flow to the fresh food side
Posted on Jun 07, 2009
SOURCE: Jenn Air side by side is not cooling
Compressor is running, how do I check for defrost problem?
Posted on Jun 19, 2009
woodchuck789
  • 4070 Answers
SOURCE: Jenn Air JCD2389GTB side-by-side refrigerator freezing & cooling
Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay. Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
Is the evaporator fan in the freezer running. It blows cold air into the fridge side through a damper in the wall between the freezer and fridge. Make sure the damper is open.
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
Posted on Jul 13, 2010
What are the typical reasons for excessive ice build up in the freezer of Jenn-Air model JS48SEDBDA? The fan is touching the chunk of ice and making a loud noise.
I have this problem with my fridge if I load the freezer up, and I am talking there is no room for anything else in the freezer. ( bottom freezer) I have to get my heat gun or use a blow dryer and go over the vents in the freezer and thaw them out ( if they look frosty ) this has solved my refrigerator problems.
Mar 07, 2015 | Jenn-Air Refrigerators
The freezer is not as cold as it should be. Is 2 the coldest setting? Shouldn't 4 or 5 freeze ice cream hard? Thank you. Jim
Hi Jim,
I am currently working on that model for a friend, the higher number the colder that compartment will get, it is not advisable to go any higher than 5 or 6, because this will reduce air to the refer section. Is the fan working in the freezer? I have seen problems with this model, and when the drain pan to the evaporator clogs, then the water freezes around the fan motor and stops it from functioning.
Get back to me and I could lead you in the right direction if needed.
Aug 14, 2011 | Jenn-Air JS48SEDBDA Stainless Steel Side...
My jenn Air refrigerator is not cooling
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
erwwer
Jun 10, 2010 | Jenn-Air JCD2389G Side by Side...
Jenn Air bottom freezer refrigerator not cooling properly,
This may be your compressor. You'll probably need a hard start kit put ont he compressor if it's not still under warranty. I hope this helps you out!
Aug 13, 2009 | Jenn-Air JBR2086HES Stainless Steel Bottom...
Jun 07, 2009 | Jenn-Air JSD2789GES Side by Side...
Jenn-Air JCB2389GRS Fridge not cooling properly
heatman101
puiodf
Mar 15, 2009 | Jenn-Air JCD2389G Side by Side...
Jenn air JCD2290HES Refrigerator not cooling
Feb 22, 2008 | Jenn-Air JCD2290HES Side by Side...
Refrigerators Logo
110 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
