Thyristor bbc cs1 equivalent
Semiconductor used in motor speed control an Pfaff sewing machine.
  • Bill Thomson Nov 28, 2012
    The semiconductor is used in the motor control card of a Pfaff 1222E sewingmachin which is quite old.
SOURCE: Pfaff sewing machine 463
how do you thread a Pfaff sewing machine
Posted on Jun 15, 2008
Mimito7
  • 128 Answers
SOURCE: The Pfaff 332 sewing machine is seized up
Well Wayne, If you can remove the outer cover of machine without a headache, then I would spray it with WD-40 and let it sit for a day and then try it again. It may also need to be timed.
Posted on Apr 22, 2009
  • 13 Answers
SOURCE: Manual Sewing machine Pfaff 1229
http://www.sewusa.com/Sewing_Machine_Threading_Diagrams.htm
Posted on May 27, 2009
SOURCE: Pfaff Creative Vision embroidery/sewing machine says motor overload then shuts down
I had the same problem and it was my power supply. I've had more than my share of problems with this machine and it's only 3.5 years old. Good luck.
Posted on Aug 14, 2011
SOURCE: how do you adjust timing on pfaff 138 sewing machine
Take the foot off the machine
Remove the needle plate
Remove the feed dogs
rotate by hand until the needle is at the lowest position
continue rotating until the needle rises 2 mm
the hook assembly should be passing exactly by the scarf of the needle
if not loosen the two screws that secure the the hook assembly and rotate the hook assembly by hand until it is exactly at the scarf of the needle and the distance between the hook and the scarf is .1 mm (almost touching the needle)
tightened the two screws, replace the feed dogs and foot and it should sew perfectly
Posted on Sep 22, 2012
Pfaff 1222 part
Search for:
Pfaff 1222 parts
(may find it on eBay or some online sewing machine vendors)
Foot Control Pedal 90 222040 08 For Pfaff 1212 1221 1222E Sewing Machines...
Aug 01, 2017 | PfaFF Sewing Machines
I have a pfaff 1222E machine and it is sewing very slowly, is there only one speed?
Most likely is is seized due to lack of regular oiling. If this is the case, AVOID trying to run the motor until the issue is addressed or the motor may be damaged.
Wheel on right side that controls the needle up and down is very tight...
Jul 15, 2017 | PfaFF Sewing Machines
Hi, I have a PFAFF Hobby 420 sewing machine. Its motor is not working and there is no service centre of PFAFF in our city. Could you please guide me opening the motor??
Maybe it just needs new carbon brushes. My Bernina 830 Record resembles the Pfaff very closely. I had issues with the motor stuttering. Changed the carbon brushes and it runs like a top!
PFAFF Mail Repair Garry Machine
http://www.ebay.com/itm/Pfaff-Hobby-301-420-Serger-Overlock-Service-Repair-Manual-/171310126409
Jul 15, 2016 | PfaFF Sewing Machines
My pfaff 1222e is running slow
1. Remove any stuck material from the feed dog, bobbin area including the hook (pointed object under bobbin). Lubricate as you go.
2. Remove top and end of sewing machine to look at the motor and belt. Place pressure on the foot pedal. Still slow?
3. With bolt attached to motor release the pressure on the belt. Now, place pressure on the foot pedal. Did you notice any increase in speed?
4. Apply pressure on the foot pedal and simultaneously adjust the motor. Adjusting means tightening of the belt and making it move in a straight line. (If it doesn't move straight it puts pressure on the motor so it will move slow.) When you have adjusted the motor to the right position the motor will be at it's highest speed.
5. If the pressure foot is the problem it will require a pro to take care of it.
Apr 16, 2015 | PfaFF Sewing Machines
A merritt sewing motor controller compatible with a Pfaff hobbymatic 807?
I wouldn't use a pedal from another machine. WHile they may do the same thing, the voltages that flow through them can be very different. Get on EBay and search for a used pedal for the right machine.
Cheers,
Kelly
San Diego, CA
Embroidery Services
Nov 04, 2014 | Sewing Machines
Hesitates at start
Industrial machines are usually clutch motors. Some have speed settings right on the motor. But if you want something that works more like a home machine with a variable speed control.... You might want to locate a servo motor for it...
Jul 24, 2012 | Sewing Machines
Last year I changed the machine engine (PfaFF 1222 E). I noticed immediately that the machine sewed too slow and I thought it was a problem of the kind of engine the repairer had put into the machine. But...
If the machine did sew fast the the replacement motor, then the problem might be that the machine is getting gummed up somewhere. Pull off the top cover, remove the 5 screws from the bottom of the base plate, (4 large screws, 1 small screw), remove the base plate remove the 1 screw from the bottom of the free arm cover. Now you can see most of the moving parts. Spray a little WD 40 on all the areas that you see metal to metal rubbing together, both on the bottom side of the machine and the top side. Don't flood the machine and stay away from the motor area. Plug the machine in, lay it on it's back and run it full speed, or at least till it runs full speed. After you free it up, blow out the machine with compressed air, and reoil with tri flow all the areas again. Run the machine again, and you've started your own tail gate repair shop.
May 05, 2011 | PfaFF Sewing Machines
Nov 08, 2008 | PfaFF Sewing Machines
Televison & Video Logo
225 people viewed this question
Top Televison & Video Experts
Electro Med Services...
