Question about Dell Dimension XPS T (500821F) PC Desktop
Computer Problem On my computer, it has this problem where it is will suddenly turn into caps lock and I would be unable to use numbers and symbols such as the comma and the comma and the period. I used to solve this problem by just pressing, shift+fn+alt or ctrl+fn but lately it hasn't been working.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 87 Answers
You have a faulty keyboard.
Try another keyboard.
Posted on Jan 12, 2009
My Lenovo laptop types symbols when I type figures. I also need to use caps when I need uncapped text and visa versa. Can you please help
sounds like your keypad is not set up right try going in to control panel and click on keyboard and try to set from there.
Oct 08, 2016 | Lenovo Essential G500 Laptop Computer -...
Tip
Laptop LED Blink on Startup There are many reasons that a computer does not...
There are many reasons that a computer does not startup or boot into the Windows operating system. If your computer will not start or boot, you will see or hear symptom to indicate the general area of the problem.
Startup Symptom: LEDs blink but does not start
The blinking LED lights on newer computers, or the beep tones on older computers, will help support agent determine what hardware component is not responding properly. The exact meaning of each code varies with the model, and the user cannot change any of the blink or beep codes.
DO THESE FIRST - Perform a hard reset.
If a PC suddenly fails to boot properly, you should perform a hard reset as the first procedure.
1. Disconnect all peripheral devices and remove all USB devices and media cards. You want to test the computer not the accessories!
2. Disconnect the AC power adapter, remove the battery and then press and hold the power button for at least 15 seconds.
3. Reconnect the AC power adapter (but do not connect the battery), Press the Power button, Look for glowing LEDs near caps lock and num lock keys, and Listen for sounds of a disk drive and fan turning.
Identify the number of blinks or beeps
When there is a start-up problem and you see LED lights on the keyboard blink a few times (between 1 and 8 blinks) do the following actions.
Table of Sample Blink Codes
The following table illustrates the meaning of blink codes used on some notebooks. The blink or beep codes on your computer may have different meanings.
Meaning of Sample Blink Codes for some EFI Notebooks:
1) Number of Blink: Continuous Glow, Blinking LED: Battery power LED, Component: Battery,
Error Condition: The AC adapter is attached and the battery is charging, but does not yet have sufficient charge to power the notebook.
2) Number of Blink: 1, Blinking LED: Caps Lock/Num Lock, Component: CPU,
Error Condition: CPU not functional
3) Number of Blink: 2, Blinking LED: Caps Lock/Num Lock, Component: BIOS,
Error Condition: BIOS corruption failure
4) Number of Blink: 3, Blinking LED: Caps Lock/Num Lock, Component: Memory,
Error Condition: Module error not functional
5) Number of Blink: 4, Blinking LED: Caps Lock/Num Lock, Component: Graphics,
Error Condition: Graphics controller not functional.
6) Number of Blink: 5, Blinking LED: Caps Lock/Num Lock, Component: system board,
Error Condition: General system board failure.
7) Number of Blink: 6, Blinking LED: Caps Lock/Num Lock, Component: BIOS,
Error Condition: BIOS authentication failure.
8) Number of Blink: Continuous blink, Blinking LED: AC power adapter LED, Component: Power adapter,
Error Condition: Insufficient power
Common solutions for issues that cause blinking LEDs or beep tones
When the computer can boot into the BIOS, run the memory test to identify other issues.
Check for loose connections and test the memory
Blink codes are often displayed after a user adds memory to the computer but does not seat the module properly. The LEDs may also blink error codes if a hardware component is loose because the computer was dropped or jarred. The problem could be that the stick of memory or one of the memory slots has a bad connection.
Check for loose memory modules
If a memory module is loose or is not making good contact with the memory slots, the computer does not recognize all of the memory. Reseating the memory module may resolve memory failure errors.
on Mar 21, 2011 | Computers & Internet
What is wrong with my laptop? It is as if the shift key is stuck
Go into device manager in windows and delete it and reboot. If it comes back when it detects the keyboard and it works then it was a driver, if it does detect it or it wont work correctly then it is a bad keyboard. You can also try a plug in keyboard to see how it behaves, ps keyboards are not that expensive.
Oct 11, 2015 | Toshiba Computers & Internet
Can't sign into my new Dell Inspiron 15 with windows 8 because it keeps typing caps
open hotmail in any browser then change your password in capital like"ASDREWSDF" then save it and then again log in through it from windows live account
Feb 04, 2013 | Dell Inspiron Computers & Internet
Security unlock?
try pressing the buttons:
There are 3 lock symbols on the keyboard:
- the NUM LOCK that has the number 9 in it
- the CAPS LOCK that has the letter A in it
- the SCROLL LOCK that has the arrow down in it
- NUM LOCK is always turned on by default
Dec 18, 2009 | Dell Inspiron 1525 Notebook
When i try to type numbers i get the symbol instead cant seem to get off caps lock
turn off the computer and turn it on again everything will go back to factory settings
Aug 14, 2009 | HP D8597A Keyboard
Unable to use keyboard
try to press caps lock and see if light goes on and off.
try to turn off the computer , check that the keyboard is connected to the purple port in your computer all the way, then turn on the computer.
Mar 24, 2009 | Computers & Internet
Machine keeps napping I guess is a good way to say it
its probably a sleep button , dont touch it.
you can also turn off sleep as well as hibernate in the power options in Control Panel
hope this helped
Jan 25, 2009 | E-Machines AAFQ50400000K0 Keyboard
Dell Dimension XPS T (500821F) PC Desktop Logo
46 people viewed this question
Alun Cox
