Question about Avanti Art Deco 4-Cup Espresso Machine
Avanti stovetop exploded while on the stove
Could this have happened because it was not screwed together tightly? It made a huge mess - luckily no-one was standing near when it happened.
  • Chef Who Dat Jan 31, 2009
    Luckily for you maybe, but when mine exploded I was right there to take it in the face and man boobs.
Could this happen if you fill the bottom chamber over the pressure release valve so that the steam pressure built up and couldn't be released. Or perhaps the pressure release valve got blocked. Not sure. But it is important to take it off the stove promptly when you hear it make that gurgled hissing sound that indicates the top chamber is full and now steam is coming through rather than water.
Posted on Feb 28, 2010
Where can I buy the stovetop burner gaskets?
  1. Gaggenau Range/Stove/Oven Parts - RepairClinic.com
    www.repairclinic.com/Shop-For.../Gaggenau-Range-Stove-Oven-Parts Huge selection of Gaggenau Range/Stove/Oven parts in stock. Same day shipping. Open 7 days a week. ... Door hinge, top/bottom. OEM Part - Manufacturer # ...
Jul 11, 2015 | Gaggenau Cooktops
How do you connect the propane to the stove
Assuming you are referring to the Coleman Campers Grill Stove which is a side by side grill and stove unit than it is a pretty simple set up. All portable Coleman stoves set up basically the same. There should be a arm known as a regulator that came with the stove. The narrow end of this attaches to the right side of the stove and screws in. Then the propane bottle screws into the other larger end. make sure all connections are screwed together tightly. For more clarification check out these instructions:
http://www.ehow.com/how_2106008_use-coleman-stove.html
https://www.youtube.com/watch?v=dbYil-YQ8-Y
Good Luck!
Jul 07, 2014 | Coleman Campers Grill
I need to replace the glass cooktop on my Maytag electric stove
  1. Open oven door and remove two screws that secure top.
  2. Lift up front and slide forward about 8 inches so that you can disconnect two wire couplings.
  3. Place on table upside down(I put newspaper down to catch the broken shards of glass) and remove burner unit (1piece, 4 screws).
  4. Place old burners on new stovetop in the same position as original.
  5. Remove 4 white plastic shims (round) from old stovetop and put on new stovetop.
  6. Tighten all screws and then sit it back on stove (two front tabs fit into slots) and then insert screws into holes and tighten.
  7. Took about 20 minutes, including vacuuming broken glass from inside burners and cleaning grease form crevices between burners and old stovetop.
  8. Wrap old stovetop in the newspapers that are underneath it and place it all in a plastic garbage bag to avoid any broken glass from falling out.
Jan 21, 2010 | Maytag MER5775Q Electric Kitchen Range
Avanti stove top coffee maker 6 cup. Need to replace seal in lid. Can I buy separately
Take the rubber gasket out of the top of the pot and take it to a local kitchen shop or Department store. If not measure the internal diameter (the hole size) and the external diameter (size of the seal) and google stove top coffee and locate a supplier in your country. Email them with the measurements and make (Avanti) and ask for a price price and shipping cost. Look at the bottom of this page as an example if you are in the US http://www.fantes.com/espresso-stovetop.html
Nov 22, 2009 | Coffee Makers & Espresso Machines
Igniter on Avanti G20AW-1 stove fires by itself every 8 seconds
broiler igniter fires but lower burner igniter wont fire
Jun 15, 2009 | Avanti G20AW-1 Gas Kitchen Range
GE Oven no longer works but broiler does
With no model number given, it's kind of hard to help you beyond writing that Sears.com has a huge inventory on parts and illustrations of the devices in an exploded view referenced to each part number and can supply several million parts directly. If you go to their site with your model number, you find out quickly if they have what you need for your range regardless of manufacturer.
Most all later gas ovens us a 'surface' type of ignitor and in most cases, using the illustration, anyone a little handy can replace these.
May 01, 2009 | GE Kitchen Ranges
Control Lock light is on and nothing works on my stovetop
Hi. Research your stovetop on the kitchenaid website. You should be able to download a user manual for your model. The manual should tell you how to reset the lock. If a manual is not available, try disconnecting the power supply to the stove. This might clear the memory of the stove. Good luck. ricardok45
Feb 02, 2009 | KitchenAid KITCHEN AID 5 Quart Artisan...
Oven proof ???
Hi yes all stone ware is oven proof so you should have no problems using them just remember they stay hotter to the touch for longer than other oven products they stay hotter for longer once their out of the oven let me know if you need further assistance ok
Mar 19, 2008 | Crock Pots & Slow Cookers
Replacing control valve/burner valve switch
This just started to happen to ours too. It's because you can't get let water get into the valve/switch assembly. Ours got so much water in there that it was making huge sparks and flames which charred up the switches. You may have to replace the whole 5-burner igniter switch assembly. I think it's part number 74010753. To access, remove 2 screws under the front of stovetop. open Top oven door to access. remove the 2 screws that hold the gas valve assembly. Remove 2 screws out of each burner assembly. Remove the green grounding wire on the right hand corner of stove top. The stove top will come off revealing the 5 white igniter switch assembly which is all wired together in parallel. Remove the large metal panel on the rear. There are two wires that are off the 5-burner switch assembly that you unplug. Replace this whole assembly and the problem should be fixed. Hope this helps
Jun 18, 2007 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Avanti Art Deco 4-Cup Espresso Machine Logo
345 people viewed this question
Top Avanti Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you an Avanti Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
