Question about Toro Super Recycler Super Bagger Lawn Mower Rear Bagger 5
I flooded the toro - now it won't start - Toro Super Recycler Super Bagger Lawn Mower Rear Bagger 5
  • 23 Answers
SOURCE: I have the Toro 7.0 TP mower - ready start. I've
well there could be a number of problems the 2 things i would do is clean out the bowl and clean the jets on the carb clean the bowl first and if that does not work clean the jets before u do that make sure to shut the gas off to clean the bowl u have to unscrew the one bolt on the bottom of the bowl then take electric parts cleaner or starter fluid and spray the whole bowl with it then put it back together the way it came off then turn the gas on and try it if it still wont start turn the gas off take the carb off and the little screws on the carb turn them in and count how many times they went in then remember that number. unscrew the screws and spray some starter fluid or parts cleaner in there and screw the screw in all the way then unscrew the screw how many turns u remembered and do the other ones then turn the gas on if it still does not start take out the spark plug get a lighter or a propane torch an get the oil and **** out of the tip of it be careful don't touch it it will be hot let it cool down then put it back in and try again GOOD LUCK!
Posted on Aug 15, 2011
  • 6468 Answers
SOURCE: toro 52 inch walk behind blades won't engage
if it has a electric clutch check for power to the clutch if no check the safety switches
Posted on Apr 12, 2012
  • 256 Answers
SOURCE: toro 6.5 tecumseh won't start
replace your spark plug. it takes a Champion J19LM. If you left fuel in your tank over the winter then drain your tank and your float bowl. Add clean fresh fuel and it should go if not you need to clean your carb
Posted on May 17, 2012
  • 6468 Answers
SOURCE: Toro z master won't start
bypass the safety switches one at a time to test them
Posted on Sep 22, 2012
hunter19_46m
  • 7482 Answers
SOURCE: my toro lawnmower model 20331 won't start. I replaced the fuel, oil, and spark plug but it still won't start. whats wrong with it?
Hi dana
Make sure you are getting spark at the spark plug, to do this:
Remove your spark plug and check to be sure you are getting a bright blue spark at the spark plug.
You do this by grounding the plug on the head of the engine and cranking the engine or by pulling the crank rope...watching the plug for spark.
If you are getting a nice blue spark then skip A below and go to B.
A...If you do not get a nice blue spark then you may need to replace the electronic module.
Note: If you have to replace the module be sure to measure the position it is in, it is critical to starting.
Take a picture for later reassembly.
B...Also take some fine grit sandpaper (not emery) and lightly sand the flywheel where the magnet is located to clean any rust or corrosion from the magnet area.
Then follow the procedure below:
Sounds like you have dirt/debris in your caburetor jets,fuel passages or a diaphgram that is becoming non-flexible.
Check/Clean/Replace your Air Filter, a dirty air filter can make your engine run to rich with fuel.
Note: ALWAYS USE COMPRESSED AIR TO CLEAN YOUR JETS AND PASSAGES, VERY IMPORTANT.
Note:Before you disassemble the carburetor:
Write down on a piece of paper and or take a picture of how the linkage attaches to your carburetor for later reference when you go to reinstall your carburetor.
Mark each piece with a awl, or some kind of sharp instrument that will make an alignment scratch before you disassemble the carburetor into separate pieces.
That way you will know which way it goes back together when you reassemble it.
Sometimes you can get by with priming the carburetor or by using a very small shot of starting fluid and letting it run a few times like that, and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Be sure to check your fuel tank for water and dirt/debris, if there is water/debris then you need to clean your tank.
Check you fuel line/s condition...after a while they will degrade and need replacement.
Check/Clean/Replace your fuel filter if you have one.
When you remove your fuel lines from the carburetor be sure to make a drawing or take a picture of how the lines are connected to the carburetor.
Also a good time to take a picture for later reference for reassembly.
If the mower is over a couple of years old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
The diaphgram may look good and flexible, but it can be deceiving and not act as a fuel pump as it should because it has become too hard and will cause hard starting,start and run and shut off, etc.
When you clean your carburetor, I recommend that you use a laquer thinner type cleaner to clean and dissolve the laquer build-up in the float and needle jet passages.
Be sure to remove all plastic and rubber parts before using the laquer thinner because it can dissolve the plastic parts and render them unuseable.
Be sure to use COMPRESSED AIR to blow out all the fuel and air passages.The higher air pressure is needed to blow some of the trash/debris from the fuel or air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Keep in mind that the float (if you have one) for the carburetor must be level when you go to reassemble the carburetor or follow the instructions you get with the carburetor kit, or you could also ask the parts man that you get your kit from.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their original position before you started.
Once you have your carburetor cleaned/rebuilt that should solve your problem.
Please take time to rate me
Bud
Posted on Oct 30, 2012
Sep 19, 2012 | Toro 52" 27hp Z Master Zero Turn Lawn...
Toro lawnmower will not start because it floods out
sounds like the needle valve in the carb is not seating take it apart clean it and change the needle and seat inside the carb
Jun 27, 2012 | Toro Power Lawn Mower
Toro 6.5 tecumseh won't start
May 17, 2012 | Toro Power Lawn Mower
Proline toro commercial 32 inch won't run
try starting fluid that will see if its a fuel problem then check for spark
Apr 19, 2012 | Toro Garden
My Toro Personal Pace 22"
pull your spark plug and see if it will pull then, if so then it is hydro locked with fuel which can be caused y a bad fuel cap, not venting or a stuck open needle in carb causing gas to flood cylinder
Jul 27, 2011 | Toro Lawn Mower With Toro Power Tools
I have a Toro 1984-85 self propelled pull start lawn mower and I can get the fuel and air mixture just right it won?t stay started, it runs great but gets flooded now (I think), does anyone have the fix-it...
If the mower floods, it may be a float problem, if you have a carb with a float. New fuels can destroy older floats, dirt and gum can keep them from closing off the fuel supply. If you are comfortable taking your carb apart I would start there.
You will need the engine make and ID to get a manual.
Jun 03, 2010 | Toro Lawn Mower With Toro Power Tools
Toro Super Recycler Super Bagger Lawn Mower Rear Bagger  5 Logo
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
