Question about Broan-NuTone CV450 Central Bagged Central System Vacuum
My cv450 nutune vaccum wont shut off unless I pull power chord out of outlet
    Scholar:
  • 95 Answers
It is most likely your relay. You can buy new relays for about $60.00.
Posted on Jan 20, 2009
The unit turns on when hose is plugged in any of the outlets but we are getting zero suction.
Do you have suction at the unit? If you do not, then there is something blocking the motors in the unit. Otherwise it sounds like you have a severe clog.
You do not need to buy the tornado wipes, just use a paper towel.
http://www.centralvacuumstores.com/cvs/trouble_help.php
Jul 21, 2011 | Broan-NuTone CV450 Central Bagged Central...
Our cv450 wont turn on when plugging into the wall or using the rocker switch on the unit, there is power to the outlet, the unit is 12 years old,any suggestions to further diagnose?
Check the filter. If it's dirty, the motor will overheat, resulting in the machine shutting off.
Rinse thoroughly in warm water, and allow to air dry thoroughly before reinstalling. I recommend having two filters so you have one to use while the other is drying.
Other problems are possible, but generally entail taking the vacuum to a repair shop for diagnosis and repair.
Feb 12, 2011 | Broan-NuTone CV450 Central Bagged Central...
A Nutone CV-450 System with inlet nozzle switch issues
You are suffering a connection problem of the hose end fitting to the wall outlet. Either the hose is not aligned with the two pins in the wall outlet, or the pins in the outlet are dirty and not making good connection to the hose end fittting.
Jan 01, 2010 | Broan-NuTone CV450 Central Bagged Central...
My nutone vacuum system won't shut off when I pull the hose out of the wall...any thoughts
The relay that turns the machine off from any of the several places where you connect, is probably stuck.
The relay is operated by low voltage. When you connect your hose, you comlete the low voltage circuit and energize the 110 volt system, and the machine comes on. When you pull the hose out, the relay is suppose to release.
those are my thoughts
I hope this is of value to you.
a
Sep 27, 2009 | Broan-NuTone CV450 Central Bagged Central...
My cv450 nutune wont shut off, I have to pull the power switch
It should be the relay and that is very easy to change out yourself.
Jan 10, 2009 | Broan-NuTone CV450 Central Bagged Central...
My nutone cv556 wont shut off
It sounds like the relay is bad. This website has a pretty good trouble shooting page.
https://www.centralvacuumstores.com/cvs/trouble_help.php#wont_turn_on
Sep 28, 2008 | Broan-NuTone CV450 Central Bagged Central...
Unit will not turn on
Unplug the vacuum unit from the wall. If it is hard wired turn off the circuit breaker
Jul 30, 2008 | Broan-NuTone CV450 Central Bagged Central...
Pull Cord
CHORD STUCK , NOW FIXXED BUT METAL SPRING CAME OUT, WHEN WOUND BACK, HOOW DOES IT ATTATCH TO PLATIC COWL AGAIN?
May 15, 2008 | Euro-Pro PT205 Leaf Blower Powerful 12 AMP...
Broan-NuTone CV450 Central Bagged Central System Vacuum Logo
159 people viewed this question
Top Broan-NuTone Vacuums Experts
Steve
Gerry Harvey
Gerry Harvey
JoeVacs
Are you a Broan-NuTone Vacuum Expert? Answer questions, earn points and help others
