Question about McCall Refrigeration Commercial Freezer 11045UF01 Stainless Steel
Specs of tev for mccall freezer
Specifications of thermostatic expansion valve for mccall upright freezer
    Problem Solver:
  • 39 Answers
You need model number and serial number . refrigerant type and possibly the compressor model number to determine the txv type and capacity
Posted on Apr 18, 2013
I have a McCall 4-4070FC i need to find out how to turn on the Lights and Door Heaters?
Your light switch is white generally around frame... As for door heater it will be on as soon as you plug unit it. You can feel around door jam to see if heating... Should be warm not scalding hot. McCall was sold to manitowoc and some parts are no longer available. If you're able to do repair yourself try case parts.
Nov 30, 2014 | McCall Freezers
Upright whirlpool freezer is not freezing. fan motor comes on, light comes on but is not getting cold. how can I trouble shoot the problem?
Could be the cold control thermostat that is the problem. You didn't provide your model number so couldn't get specific here. I did find another forum thread that might give you more clues: http://www.applianceblog.com/mainforums/threads/36458-Whirlpool-freezer-cold-but-not-freezing
Sep 18, 2014 | Freezers
Why does my freezer stay at 38 degrees?
while i have no specific experience with this item, i did belatedly find out (after i threw out the a.c) that you can buy a valve that can be screwed into the refrigerant coil allowing you to charge up even a "sealed" system. so perhaps you just need to add some refrigerant. just a thought.
Apr 27, 2014 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
My Whirlpool freezer keeps freezing up inside at the back. I have to manually defrost it every other day. I have had it checked twice and have been told that the defrost timer and the heater are both...
Kindly arrange to check whether the refrigerant is charged properly or not (Overcharged in your case ) or may b an malfunction of expansion valve hope it helps
Sep 08, 2010 | Whirlpool 19.6 cu. ft. Upright Freezer...
My ge upright freezer is getting cold, but it is not freezing the food
check the door is closing tight first,,if it is try turning the thermostat down a bit more,,if that dont work you may need a new thermostat fitted and maybe even a re-gas and a new compressor
how old is the freezer???
Aug 21, 2010 | GE 16.7 cu. ft. / 473 liter Upright...
After a couple years of non-use, it started up but then quit and
The first thing to find out is what is running and what is not. If I am reading the specs on your unit right this is a frost free unit. There should be a fan inside behind the back wall.
Plug the freezer into a known good outlet and turn the dial up. If the fan comes on then go behind the freezer and down at the bottom is a compressor, you should be able to hear that running as it and fan should run together.
If they are running and no cooling takes place in 24 hours you have a problem in the sealed system, most likely the refrigerant has leaked out.
If nothing is running you have either:
- A bad thermostat, (the control behind the dial) It can be checked with an ohmmeter, with the power off and wires disconnected the meter should read 0 ohms when the dial is turned up
- A broken or chewed through wire (could be anywhere)
- A defrost timer that is stuck in defrost. It can be checked with an ohmmeter using a similar method as the thermostat.
Sorry this was not an easy answer
May 07, 2010 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Need to know the design superheat also normal pressures on this unit with 404A refrigerant
The McCall web site has nothing easily found on the 7-7045FT unit.
In answer to you questions, first, what is the expansion device. TXV, Cap Tube, or something else?
Low site pressure will be dictated by the super heat. The high side, in many cases, is usually ambient plus 30, then convert to psi.
Let me know if you need more info. And please double check the model number/ serial numbers.
good luck
Oct 17, 2009 | McCall Freezer 7-7045FT
Old hotpoint upright freezer only has 1 temp artic blast....
I would replace the thermostat because is the only thing that controls the temp. , also there's a timer and a terminator but them are only for defrosting the unit.
Aug 13, 2009 | GE 16.7 cu. ft. / 473 liter Upright...
Upright freeze made a popping noise like a thermostat
If you heard the noise at a fairly routine rate and time it was probably the defrost timer motor. Locate it and you should be able to engage it manually. It is a plug and go part to replace. Be sure to take the old one along with the make n model # with you to the parts house!!
Jan 17, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Unable to adjust temperature with control dial
YOU WILL most likely need a new thermostat for the unit. What evere tripped the breaker apparently welded the contacts on the thermostat. take the model number and the serial number and the thermostat you have here's the part and the model number for you 21 # 216788100 Control-temperature please be sure to rate this soilution after your done. Have a happy new year>
Jan 01, 2009 | Frigidaire 14.1 cu. ft. Upright Freezer...
McCall Refrigeration Commercial Freezer 11045UF01 Stainless Steel Logo
131 people viewed this question
Top McCall Freezers Experts
Dennis Boxerman
AJMAL KHAN
John Tripp
John Tripp
Are you a McCall Freezer Expert? Answer questions, earn points and help others
